how to check if fuel is in my oil? - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 06-16-2011, 07:14 PM Thread Starter
I was wondering how to check if fuel was in my oil? could I get some pics too please. Thanks.
2001 dodge cummins 5 speed 4x4, extcab shortbed, white, 5 inch exhaust, moto metal 951's, new injection pump and raptor 100 ,autometer gauges fuel,egt,boost, edge drag comp, bd stealth plate, southbend clutch. Dfi 7x.010 injectors !! hx35 turbo
white04dodgecummins is offline
post #2 of 4 (permalink) Old 06-16-2011, 07:21 PM
Dodgezilla's Avatar
iTrader Score: 18 reviews
Pull the dipstick and smell it. If you smell diesel then there's fuel in the oil. Also, if the level is way overfull then there's likely fuel in it...
04 Ram 2500,Green/Silver-305/555HO,48RE,3:73s, QC,LB,4x4,Roadwire Leather,Laramie Interior,Infinity, HE351 Turbo,Magnaflow 4" Exhaust,VA C3.2,Westach gauges,Torque Tube,BeCool Fan,Fogzilla,TRM,4th Gen 20" Rims w/ 265/60 tires,118,000 miles
Dodgezilla is offline
post #3 of 4 (permalink) Old 06-17-2011, 04:41 AM
clean piece of white paper put a drop of oil out your engine on the paper a drop of clean oil and a drop of fuel the the fuel in your oil will make a lighter ring around the dark oil spot the other drops clean oil and fuel are just to help u compare what u are seeing
06 stock
02 stock
97 stock
truckndiesl is offline
post #4 of 4 (permalink) Old 06-17-2011, 04:56 AM
TECH SPECIALIST
steelhead01's Avatar
oil analysis test labs.
ask your local big rig CAT and Cummins shops where they send oil samples for testing.
most large cities have at least one lab.
pick a close lab to cut down mail ship time.
about $20 for basic test includes fuel in oil results.
many email and present the result online, saving access time.
don't want more than 2% in a Cummins HPCR.
http://www.machinerylubrication.com/...sis-laboratory
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
