Temperature Gauge fluctuating and No hot air. - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 05-19-2011, 01:18 PM Thread Starter
Last week I noticed my heater wasn’t blowing any hot air out, but my temperature gauge said 190 (normal)…then my temperature gauge went to 245 and hot air started coming out finally and then dropped down to 170 then backup to normal. (In town driving). Last night it did the same thing…sort of worried about it… Would this be a thermostat issue? No, hot air blowing out is where I get confused.
'06 Dodge 4x4 Quad SB, LoneStar, G56, Whistler, Workhorse Module, AMSoil All,
'96 Dodge 2x4, 12v, Single Cab Dually
BrandonCooper is offline
post #2 of 4 (permalink) Old 05-19-2011, 01:23 PM
mjensen's Avatar
Change your thermostat. It sounds like its stuck closed and with no warm coolant running through the heater core no hot air.
2013 Ram 2500 Laramie Crew Cab Auto 4x4
mjensen is offline
post #3 of 4 (permalink) Old 05-19-2011, 05:18 PM Thread Starter
Ok I will give that a shot first...appreciate it..
post #4 of 4 (permalink) Old 05-19-2011, 06:20 PM
TECH SPECIALIST
steelhead01's Avatar
was the coolant recently changed?
air bubble in cooling system, probably trapped in block and heater core.
park with nose 2 ft higher than rear bumper.
put large cardboard in front of radiator blocking flow.
run heater on max/high setting
run engine with rad. cap off
let it work out the bubbles thru the cap hole.
make take half hour goosing the throttle ocassionally. be careful of too high rpms, she'll blow like a whale. 1500 rpm max. does fine.
when bubbles stop, fill and cap.
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
