48RE won't shift 2-3 - Dodge Cummins Diesel Forum
post #1 of 37 (permalink) Old 04-28-2011, 06:36 PM Thread Starter
torqueaddict's Avatar
I know there are a lot of trans threads going on... but it seems like everyone is having shuttle shift issues. I definitely don't have that. My issue is that it's not shifting from 2-3. It was just happening when the trans was cold, now it's happening randomly. I can sometimes shift to N and back to D quick and it'll go to 3rd. When it does shift, it slams into gear. Whenever I accelerate normally, it will hold 2nd until 2300 RPM and then slam to 3rd. If I get on it, the shifts are actually perfect. Much smoother and exactly the right points. What the crap! I adjusted the bands, didn't help. I see threads about TV cable.. and I don't know what that is or how to check it. Any ideas?
I took it to a local trans shop today, and I wasn't impressed. They didn't really have any thoughts other than put it on their diagnostic machine, but they didn't think it would show anything. I also asked if they did any upgraded transmissions, and they said "No, these Dodge transmissions get expensive". No crap.. I didn't say I didn't want to pay for it LOL. If you know any good shops in Northern IN I'd be interested in that too!
2006 Megacab 2500 - 6" Superlift, 35s, Airaid, BDTD, 5" TBE
2008 Pontiac G8 - Procharged
torqueaddict is offline
post #2 of 37 (permalink) Old 04-28-2011, 08:08 PM
mine was doin that for a few months and now my entire secong gear took a crap and now needs another tranny guess u better get urself a nice one
jason72 is offline
post #3 of 37 (permalink) Old 04-28-2011, 09:10 PM
cerberusiam's Avatar
You don't have a TV cable, you have a TTVA motor. The only way to mess with its settings is using a shift enhancer or advancing the gear drive.
That doesn't sound like your problem any way. You would need to run pressure test to tell but it sounds like your gov pressure may be sticking high. Evidently the trans shop you went to is not up on current diagnostic procedures.
If you haven't done it, change out the gov pressure solenoid and transducer, and, while your at it an output speed sensor might be the problem. They all control, along with wheel speed, how the transmissions shifts 1-2 and 2-3. A problem in one can throw glitches all the way thru.
cerberusiam is offline
post #4 of 37 (permalink) Old 04-29-2011, 09:50 PM Thread Starter
How hard is it to change those? Just drop the pan? How expensive are they?
post #5 of 37 (permalink) Old 04-29-2011, 09:55 PM
Simple to change, 3 bolts and 2 wire connections after dropping the pan.
The transducer and solenoid can be found here A500 42RE A618 46RE 47RE 48RE Transmission governor pressure sensor 56028196AD,Transmission solenoids
post #6 of 37 (permalink) Old 05-01-2011, 05:07 PM
I'm havging the dame issue with 07. I have a billet goerend with a DTT shift enhacer. My probelm is it didn't do until I loaded my smarty. I was wondering if it has to do with torque mang or just part of the tune? I'm going to get a hold to DTT and ask if they have an answer for the issue.
richards2100 is offline
post #7 of 37 (permalink) Old 05-01-2011, 05:15 PM
If you reduced the TQ management then yes that is the likely problem. I am currently Smarty TNT SW1 with TQ 3, upgraded GM comversion solenoid, lower stall TC, TranGo SK, and a DTT Shift Enhaser. On settings 1 and light footing it shuttle shift is rare, like almost never.
Since you have about all the good pieces there are, a DTT Shift Enhanser set for your build might be a good investment.
post #8 of 37 (permalink) Old 05-01-2011, 05:31 PM
I'm just having problems with the 2-3 shift when i'm just driving slow around town. It will hang in second gear until about 2000 RPM. It just sucks when your trying to pick up a little extra milage. It even says in the smarty manual somewhere that you will have to let off for a while for it up shift sometimes. But even under moderate to low throttle it shifts perfect. I was just hoping I could fix it with the DTT shift enhancer.
The Following User Says Thank You to richards2100 For This Useful Post:
Goat11 (04-30-2013)
post #9 of 37 (permalink) Old 05-01-2011, 05:44 PM
That sounds more like a problem with gov solenoid or possibly front band adjustment. It just depends on how the VB was setup a lot of times.
post #10 of 37 (permalink) Old 05-01-2011, 05:48 PM
I'll have to make some calls. Someone from goerend or one of the smarty guys should know if it is common. Thanks for the help.
07' 2500 5.9. smarty TNT, s&b intake, 4" turbo back to 5" stacks, airdog 150, goerend triple disk billet, DTT shift enhancer, auto meter gauges, 35" BFG all-terrian
post #11 of 37 (permalink) Old 05-01-2011, 07:48 PM Thread Starter
let me know what you find out. That sounds similiar to mine, except mine doesn't matter where the programmer is set or even if it's on. Mine also waits until about 2300 rpm to shift, even higher than yours. It's funny though, even if i let off the gas it won't shift. If I punch it, then it shifts. I might just try the parts Cerberusiam suggested. For $100 it's probably worth a shot.
post #12 of 37 (permalink) Old 05-01-2011, 08:49 PM
Cummins Crazy
nightfiref7's Avatar
I would also like to hear what you find out.
Bully Dog PMT(For Gauges), SSR, BD Performance Plus Trans, BD Triple Disc Torque, BD Flex Plate, BD Intake Horn, BD Boost fooler, AirDogII, Flux 2's, II Turbo, 5" FLO~Pro Turbo Back, TNE Diesel Tuned, Recon everything
nightfiref7 is offline
