My 03 Cummins Will NOT Start! - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 04-18-2011, 02:17 PM Thread Starter
Just got it a week ago. Its a 03 2500 auto, 4wd, 192k. It ran great Friday, let it sit over the weeknd and it will turn over normal but will not run. Fuel pressure gauge in cab says normal and can hear the pump working. I dont really know much about diesels this is my first. I hope it doesnt need injectors. Any ideas would be greatly appreciated!!
wiesel_time is offline
post #2 of 12 (permalink) Old 04-18-2011, 06:47 PM Thread Starter
I came home after work today and I tried it again and it started first time. Think its my intake heater messing up? It was 52 deg this morning and about 73 deg in the afternoon. I'm stumped, I just hope it doesn't do this while I'm away from home. Any help would be appreciated.
post #3 of 12 (permalink) Old 04-18-2011, 09:34 PM
Mikeh1725's Avatar
Do you have a way to check for codes? Also is the fuel filter dirty?
Could be the injectors letting go also
2004 F250 6.0 delete underway
1998.5 sclb donor/toy
Mikeh1725 is offline
post #4 of 12 (permalink) Old 04-18-2011, 10:18 PM Thread Starter
Yes I checked for codes but nothing showed up. I have a Superchips Flashpaq and I changed the setting back to stock from performance and didnt drive it and let it sit all weeknd. When I went to start it this morning it would not start only spin over. I set it back to performance this morning and tried it but nothing. It was making me late for work so I got in the old tundra and made it to work. Came home and before I tried anything I tried to start it and it fired right up like it should. ??
post #5 of 12 (permalink) Old 04-24-2011, 11:55 PM Thread Starter
I started it again the other day and it cranked up and ran good. Ive noticed tho that if you rev it up a little in park it revs good, but when it comes down to idle it idles up and down a few times then smoothes out. It doesnt smoke when cranked/running and no engine codes, FCA maybe?
post #6 of 12 (permalink) Old 04-25-2011, 12:31 AM
waywardtravel's Avatar
FCA maybe but I have read of about countless people changing the FCA with no result including myself. I don't think I've ever read of the FCA fixing the problem as a matter of fact, not to say I know all. Do you see any smoke on start-up or when it's doing the choppy idle down?
04.5,QCSB, Goerend full billet, 4:10's, MPI 63/475,Engineered diesel 63, Exergy 40%'s,Dual CP3's, gauges, Airdog 2 165, S-06 TNT R and Gordon's UDC,edge JWA CTS, Top Gun Customz 3 1/2", Carli BJ's, BIG steering box, 5100's, Helo 791's with 35's.
When all's said and done there's usually a whole lot more said than there is done.
waywardtravel is offline
post #7 of 12 (permalink) Old 04-25-2011, 04:07 AM
I bet you have injectors sticking open making it impossible to get to 6000psi for the injectors to fire to start the motor. Get a contribution test run at the dealer to find out.
2005 Ram 2500 QCSB, S&B Filter, 4" Cat Back, BDTD, Edge EZ, Raptor LP w/2mic & WS, Custom Intake Horn SS, 35" BFG KM2's, 1 Set of Smoking Tires
Cummins_4u is offline
post #8 of 12 (permalink) Old 04-25-2011, 09:22 AM
TECH SPECIALIST
steelhead01's Avatar
do you have the original fuel lift mounted on the back of the fuel filter housing?
when you have a no start condition, open the fuel drain valve on the bottom of the filter, drain all fuel, close valve. crack open 1 or so turns on the filter lid. have someone crank engine. watch filter for diesel overflow, should occur in less than 5 seconds and pour out in good stream.
or you can run fuel filter drain tube into large plastic bottle, open drain valve, hit key then release- fuel pump on for 30 seconds, should be more than 1/2 quart in 20 seconds, deduct amount that was static in filter
if lots of fuel from lift pump?
pull injectors and send in for testings
if they're the original factory injs., i'd just replace all 6 with Bosch Cummins brand new from Cummins parts counter, ya know what you're getting there for your hard earned money and they cover their warranties, no games
some areas have Bosch parts counters that sell to the public retail or if you have business license, can get a discount
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #9 of 12 (permalink) Old 05-02-2011, 12:08 AM Thread Starter
Thanks for all your info guys! It doesn't do this all the time. If its fairly warm outside and I drive it everyday it does fine. Today it wouldnt start, the temp said 59f, truck would spin over good but not fire. Then when I came home later it was around 73f and it took a few more revolutions to get goin but it did start (no ether). I'm thinking its something electrical, solenoid, or sensor, but it doesnt have any codes. Im going to see what the local shop says tomorrow to see if they can figure it out.
post #10 of 12 (permalink) Old 05-02-2011, 01:33 PM Thread Starter
It seems to start ok when its warm outside (60f or above). I tried one trick I read on here, to rev the motor to redline and see if it stays there or comes down fairly quick. Tried that and it blew white smoke like I was doin a burnout and came back down to idle and sounded like crap, took prob 15 secs to smooth back out, tried it again and it blew smoke but didnt idle as bad, sounds like injectors to me, im gonna try to take it to a shop today. Thanks.
post #11 of 12 (permalink) Old 05-02-2011, 01:34 PM Thread Starter
also it didnt rev to the redline smooth at all, like it missed all the way there
post #12 of 12 (permalink) Old 05-13-2011, 05:38 PM Thread Starter
Took it to the local diesel shop and he said it was the lift pump, so now getting a fass system installed, should get it back maybe on monday
