Code P0336? - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 04-11-2011, 04:18 PM Thread Starter
Code P0336?
I was wandering if having old batteries and bad corrosion would cause this code maybe because of low volts maybe or do i need to replace my crankshaft position sensor.
2001 dodge cummins 5 speed 4x4, extcab shortbed, white, 5 inch exhaust, moto metal 951's, new injection pump and raptor 100 ,autometer gauges fuel,egt,boost, edge drag comp, bd stealth plate, southbend clutch. Dfi 7x.010 injectors !! hx35 turbo
white04dodgecummins is offline
post #2 of 16 (permalink) Old 04-11-2011, 04:29 PM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
are you running a chip or box on the truck? TST, and Banks will both occasionally cause that code.
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #3 of 16 (permalink) Old 04-11-2011, 05:20 PM Thread Starter
Nope my truck is bone stock.
post #4 of 16 (permalink) Old 04-11-2011, 05:38 PM
Have you ever had a belt come off? Or any road debris kick up?
That sensor is kinda out in the open on the bottom of the motor and is susceptible to both of those.
post #5 of 16 (permalink) Old 04-11-2011, 05:49 PM Thread Starter
no i have never had a belt come off sense i have owned the truck the code just popped up the other day when i pulling my tractor up a hill and the my check engine light came on and the code p0336 came up?
post #6 of 16 (permalink) Old 04-11-2011, 05:50 PM Thread Starter
I also have P0191 code and a P2607 code.
post #7 of 16 (permalink) Old 04-11-2011, 06:08 PM
P2607 Category Powertrain Definition Intake Air Heater "B" Circuit Low
You have a relay or element that is bad in your grid heater... most likely a relay.
P0191 Category Powertrain Definition Fuel Rail Pressure Sensor "A" Circuit Range/Performance
This can be caused by a dirty fuel filter or a bad rail pressure sensor if it comes back repeatedly.
Does your truck ever give a hard crank to get it started or does it always just fire right up? Usually when a crankshaft angle sensor starts to go out, you'll have long cranking times or hard starting.
post #8 of 16 (permalink) Old 04-11-2011, 07:45 PM Thread Starter
Well Every once in a while i will start the truck and it will take about 3 seconds to fire up. sometimes which is annoying. also my fuel filter only has about 600 miles on it.
post #9 of 16 (permalink) Old 04-11-2011, 07:50 PM
I'd say that warrants an inspection anyway. Take the crankshaft angle sensor out and clean it off, clean the mounting ear off that it mounts to and the connector really well.
You'll be looking for cracks or nicks of any kind on the sensor head.
post #10 of 16 (permalink) Old 04-11-2011, 08:19 PM Thread Starter
ok thank you very much.
post #11 of 16 (permalink) Old 04-12-2011, 02:01 AM
Like Shibby said road debris can get on it and cause it to miss read or even a cord from the belt can fray off and whack the CPS and damage it. Try taking it off and cleaning the face. Also look at your balancer. If it is wobbling it could also set off a P0336. I bought a new crank position sensor when I started throwing the P0336 code and a month later the code came back. It ended up being that the bolts holding the balancer to the crank had loosened up causing the balancer to wobble, also causing the balancer bolt holes to oval out. Bought a replacement balancer and hone ring from a junk yard for $100 and problem solved.
05 3500SRW 4Dr Long Bx 4x4, NV5600, S&B Air intake, 4" turbo back, SB clutch, Smarty Jr, 60hp injectors, BD Super B, Edge CTS, GDP 2micron, 420k Miles roll'n.
baru is offline
post #12 of 16 (permalink) Old 04-13-2011, 01:09 PM
I sort of got the same problem right now and have a new crank sensor to put in. Unfortunately I'm not quite sure how to remove it. There is a red tab on bottom to push out of way however it still seems stuck. I have noticed a black cap on top where wire comes in but not sure if have to turn/push, etc. Didn't want to break it.
Anyone know how to remove it out of wire harness?
[IMG][/IMG]
ED VR
EdVR is offline
