| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#37 (permalink) | |
#38 (permalink) |
Hey everybody, I'm new to this forum and have a minor problem with my 06' 5.9. When I first start the truck and let it warm up, my lights dim for 3 to 5 seconds then go back to full power, and my amp meter goes down to 7 to 9 volts then back. Is this an indication of a bad alt?
#39 (permalink) |
John is right! I have really black oil right after changing it. Even before starting it the first time after the change! Just how they are..... (I was told they hold a quart or more in the pan because of the way the drain is threaded in the pan. I will look when I change in the next few days.) I mis understood when I first read about this and checked my wires. I will have to go back and look at the pics at the beginning of this thread and then recheck the truck. I may have put wire loom on different wires. I may still have this problem or it may still be a potential one for me. This is one of those things that is gonna happen. It is just a question of when. May happen under 50,k miles; may wait till well after 100,k....... I was under a newer '08 and it had the same design problem. Dodge in their infinite wisdom, placed a stand off hanger on this wire (The one behind the A/C compressor). Problem was, the hanger was positioned wrong and holding the wire against metal so it could still rub through and ground itself out! I tell you, you have to watch them all the time! I guess at least they realized this has been a problem and they tried to fix it! 4bymike, This is perfectly normal. It is your grid heater cycling after you start the truck (Known as 'after glow') It will do this each time you start the truck even if the engine is already fully warmed up (Like if you just stop for fuel). It will continue to cycle for about 2 minutes after each start up when the outside temp is under like 60F or until you go over 18 MPH. Hope this helps. As long as your lights come back up to full brightness your alternator is probably just fine. The grid heater is a 200 amp draw so it will pull the volts way down and dim all your lights. |
#40 (permalink) | |
Local Rotor Head....
I prefer to leave my headlight off while idling with the grid heater on.. but thats just preference.
2005 3500 SRW 4X4 QC LB NV-5600, Jake Brake, Smarty Jr Revo, Airiad MIT, GDP Intake Horn, GDP MK2+ w/ Cat 2um, Baldwin BF1212, Amsoiled, Pricols
#41 (permalink) |
04 short bed over the past 6 weeks little more time to start the other day started her up to warm up noticed a lumpy idle only through the exhaust and a bit noisey on top end more like a diesel nock but stiil running ok run a banks six speed and speed loader i was going to that check tomorow but will check the wires under the oil filter hope that fixes the problem this is the best forum always good help in england uk dodge do not import diesel rams if you go to a dealership it like you are from another planet |
#42 (permalink) |
Thanks everyone for the quick answers to my questions. I thought my alt was going out on me.. Is the dealer the only one that can recalibrate my speedometer, and activate my high idle? The dealer where I bought my 06' wants $100. Thanks 4bymike.
#43 (permalink) |
![]() Join Date: Oct 2008
thats pretty neat
2004.5 2500 Long bed Reg Cab A/R Teflon Coated Rims,Wrapped in 33" Hankook M/T's,BHAF,smarty,Ts Performance Ramifier 100hp Pressure Box.4 inch exhaust Rat Rod style. Autometer boost,egt,tranny.Isspro fuel pressure.w6. Valve body,input shaft,T/C stb. |
#44 (permalink) |
I have 03 with hard start problems . Grid heater not working . Will not start without little shot of either in the air cleaner. Can shut it off in 33degree weather and 30minutes later needs either to start. Runs rough idles rough but when warm runs fine seems like it might have a little miss .What you all think? Thanks in advance. New to site . After I get it running right I can hit you all up for performance mods.
#45 (permalink) |
Does anyone know if the headlights on my 06' are adjustable (up-down). I'm getting alot of middle fingers when I drive by people at night, they think I have my high beams on..Thanks
#46 (permalink) |
![]() Join Date: Mar 2009
issue with starting, starts fine, runs smooth, but, will not accelerate for a few seconds, ( feels like a dead pedal)
2006, 3500 Big Horn dually 4x4, mega, 6 speed manual, triple pod pillar gauge, valentine1 radar detector, gps, bd ultrax, OLD-- 2000 4x4 dually, quad, 6speed manual, pillar gauges, centerforce clutch, VanAaken tuner, +-240,000 miles, for sale. Last edited by fuzzy645 : 04-16-2009 at 12:31 PM. Reason: spelling |
#47 (permalink) |
My rig has a bit of a rough idle at times. More or less the whole truck shakes you feel it in the seat. This past winter I thought the truck was going to die. I was plowing and just idling the truck at the time and it wanted to die. Only other Issue besides the other issues like water pump & injector pump going on a 07 with 40'000 miles is the truck does a burp or a hick up sometimes after start up. Then today it threw a code P0103 mass air flow high currant. I played with the plug a lil and the CEL light is gone. More concerned about the hick up. Any ideas about that?
2007 5.9 4x4 Quad Cab Straight piped |
#48 (permalink) |
Drove my truck today... almost had to call a cab to get home... thought maybe I should park it and put flowers around it POS... died FOUR times... just quit dead no petal and shut off. sat for a while and I got it going again then dies a mile or so down the friggin road.. I am so sick of this problem, I dont even want to use it for a short trip. Much less if I really have to go somewhere.. Good thing we have a 97 Wrangler at least that runs. It is a 2003 3500, I put a new lift pump on a month ago.. it was better not 100% but better for a few days and then we are back dealing with this crap all over again... I am tired of this.. I checked those wires by the AC compressor and did not see any nicks but I will look again and tape them and wire loom them. Maybe I should not have put on the stock pump as a replacement. I start it and it just idles between 700 and 800 rpm's and then dies like you shut the key off. I am totally at a loss as to what the fix it for this. Any other ideas out there? Please any help would be great.
