2006 5.9 no start cold/ plugged in starts? - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 03-29-2011, 03:46 PM Thread Starter
jrosp23's Avatar
I saw some posts regarding this issue, but did not see any real prices and or places to buy an intake heater grid.
My truck has been impossible to start this winter without being plugged in. this weekend i was not near electricity to keep it plugged in. it was 25F and sat for about 24 hrs. it cranked but would not fire at all. i took it to the dealer and they said that the heater grid was bad and they needed $600.00 to continue the diagnosis. I spoke to a friend with the same truck and has a delete kit and his truck starts no problem?? He was thinking i have a fuel pressure issue, as even on hot days in the summer, it takes 5 or 6 cranks to fire. i have had this truck for about a year and had to have $4500.00 for injectors, now a heater grid and possibly an $800 fuel pump. pretty discouraged with the bullet proof cummins right now. any insight would be appreciated before i dump another $2000 in this thing. thanks, Jeff
2006 Quad CAB 2500 CTD, ATS ARC Flow Intake, K&N Filter, 4" MBRP Turbo Back Stainless, FASS 150 lift pump, Bully Dog Triple Dog Programmer, Hell Bent Steel 2.5" leveling kit, 2" Rear lift. 305/65 R17 Pro Comp Xtreme AT's Stock Wheels
jrosp23 is offline
post #2 of 3 (permalink) Old 03-29-2011, 05:15 PM
TECH SPECIALIST
steelhead01's Avatar
present start temps?
if above 0d F, no need for the grid heater. Cummins has no problem starting to below 0d F with good batts and injectors
Dodge dealer "New Rebuilt" injectors are not worth putting in. haven't seen a Dodge dealer shop yet that could reliably troubleshoot and repair these Cummins HPCR and they overcharge.
mileage and fuel filter used?
take it to a diesel pickup shop that specializes in Dodge Cummins work. have the injectors pulled and tested at a Bosch certified HPCR injector shop that has a common rail test machine.
can pull and send in yourself.
can waste time, money and sanity with replacing onzys twoseys but I'd do all 6 at the same time
guaranteed New Bosch only
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #3 of 3 (permalink) Old 03-29-2011, 06:11 PM Thread Starter
jrosp23's Avatar
Western, NY, 0 to 25 F , no go, without plugging it in over night.
I had all 6 injectors replaced with New OEM replacements 6 mos. ago. I had leaky injectors that had the motor pulsating and hanging at like 2,200 RPM.
Fixed under warranty. truck has always taken 3 or 4 cranks to start. Runs good except the long crank start and the no cold start issue.
Truck has 85 K, change oil and fuel filter every 5,000, Rotella 15-40, air filter change at 10K. Napa Fuel and Air.
I spoke to a local high performance diesel guy and explained the issue, he is thinking fuel pressure (he was "familiar" with my previous injector problem).He too, explained the grid would not cause a no start, as he has many high performance trucks with delete kits that fire up no problem.
i still have 15k on my 100k warranty, so i am in a predicament on who can complete the repair work..... without draining the bank account....
jrosp23 is offline
