Feed tube extraction tool - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 03-03-2011, 02:16 PM Thread Starter
hi-boost's Avatar
does anyone have a part # for the extraction tool to remove the feed tubes on a 2006 5.9L cummins? and where to get one?
i'm going to need one come April when my new injectors arrive.
THX!!!
06 Big Horn Edition 2500 SLT,HD,5.9L,4X4,QC,SB,48RE,3:73,5" MagnaFlow/6" tip,BDTDPP V2.4.3,Quad BF,moded stk airbox w/Cool hose,Stk turbo,Pwr-Flow,Defiant,Thuren,6"lift,Carli,37x13.5-17 Toyo O,C,bagofparts,EBC,MK-2,Warn,Viper16.5T w/syn line
hi-boost is offline
post #2 of 16 (permalink) Old 03-03-2011, 02:20 PM
Only in a HEMI
BBRam's Avatar
iTrader Score: 13 reviews
You shouldn't need it (or at least I haven't)
But Miller Tool makes it. BRB with the part #
2012 Ram 2500 5.7L HEMI
2012 Dodge Challenger SRT8 6.4L HEMI
2015 Hellcat, and ya, it's got a HEMI
BBRam is offline
post #3 of 16 (permalink) Old 03-03-2011, 02:22 PM
Only in a HEMI
BBRam's Avatar
Miller 9015 connector tube extractor tool.
BBRam is offline
The Following User Says Thank You to BBRam For This Useful Post:
hi-boost (03-03-2011)
post #4 of 16 (permalink) Old 03-03-2011, 03:32 PM
MotorCityMadman's Avatar
Just take a fuel line from the rail and attach one end to the tube. The other end must be free. Hand tight is fine. The nut on the line should give you enough purchase to pull the tube by hand.
98 2500,4x4auto,48re vb,billet single,shift kit+, Super B, 4" ss,#10 ff,4gsk,.024s, 5x.014, BHAF,16* gauges,WVO, B164 bypass 2004.5 3500, SRW, FASS WVO, B164 bypass, Edge@1 Sold 96 2500 eclb 3gsk
MotorCityMadman is offline
post #5 of 16 (permalink) Old 03-03-2011, 04:44 PM Thread Starter
hi-boost's Avatar
ok guy's, i'll try the trick with the fuel line, THX!
hi-boost is offline
post #6 of 16 (permalink) Old 03-03-2011, 05:18 PM
rgaskell's Avatar
This is the way I did mine. Might have to use a screw driver to help them come out.
2016 3500 Asisn Megacab Stock for now
rgaskell is offline
post #7 of 16 (permalink) Old 03-03-2011, 05:21 PM
World Champs!!!
MoparProud's Avatar
I disconnected the whole rail. Of course I was tearing down for a full rebuild, but I do believe I caught a couple threads on the injector lines, then popped the tubes out with a screwdriver.
Cummins says to replace the tubes with new injectors. Real bold words too, with the word "must" in there as well.
'07 3500 SRW QC/LB-EFILive w/Silverbullet Tuning-Goerend-WOP triple turbo-200% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
post #8 of 16 (permalink) Old 03-05-2011, 07:06 PM
I got one from Sears on-line.
wildbeast is offline
The Following User Says Thank You to wildbeast For This Useful Post:
hi-boost (03-05-2011)
post #9 of 16 (permalink) Old 03-05-2011, 08:10 PM
Mopard's Avatar
I just had all 6 injectors replaced under warranty and my truck now rattles like crazy, along with a new noticeable tick and knock ... the rattle is the worst under moderate throttle under load. I asked the mechanic at the dealer about replacing the connector tubes and he said no. Can you show me where Cummins says the tubes must be replaced at the same time?
2012 2500 4x4 RC/LB / 68RFE / 3.73 LSD / HBS 2" leveling kit / Bilsteins / 285 BFG AT/KO / Boss 9'2" VXT / Line-x
Traded - 06 2500 HD 4x4 RC/LB
Mopard is offline
post #10 of 16 (permalink) Old 03-05-2011, 09:19 PM
Is your timing altered but any programmer or mod? After I installed my 6 new injectors my cummins rattled too. To eliminate the rattle I backed off the timing and got it closer to stock. With 6 new injectors your truck will definitely sound different.
post #11 of 16 (permalink) Old 03-05-2011, 10:55 PM
i bought the miller tool, but i have always used a lug nut off the truck, i run the long splined style lug nuts, and they work prefect for the feed tubes, just remember to replace the lug nut when your done.
04,3500,auto,silver Quad,4x4,62/475,air boss,TC rail,flux4.5,pusher,magnaflow,firepunk,Fass,gauges , mag hytec diffs and trans,air bags,amp reasearch,FF front bumper,welds,37"toyo MT,ATS flares,coolant bp,UDC,dual CP3,thuren,carli
pullinhard is offline
post #12 of 16 (permalink) Old 03-07-2011, 10:53 AM
feed-tube tool
THX!!!
snap-on no. cj149 around 20.00dollers canadian.
2004.5 silver quad cab,48re,banks ram air/super scoop,smarty/commander,hell bent 2"leveling kit,gdp 2 micron filtration system,transgo shift kit,trans. rebuilt /billit converter
fl dodge is offline
