4 wheel drive squeaking when turning - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 03-02-2011, 02:52 PM Thread Starter
ak_cowboy's Avatar
The subject speaks for itself. Driving in two wheel drive I don't get a sqeak, but in four wheel drive it squeaks when I turn either direction. I assume stub shaft u-joint but I cant find a zirk fitting to lube it. Any ideas?
2006 2500 Mega Limo 5.9 CRD w/homebrew Biodiesel Triple Dogged w/ Outlook 2 inch level kit, AFE Torque tube, Racor 490, Amsoil BHAF 4510, CFM+,Transgo, Revmax Single disc. Sonnax front and accum pistons, 45% extruded nozzles and the damn muffler just fell off!
ak_cowboy is offline
post #2 of 6 (permalink) Old 03-03-2011, 02:28 AM
tryNto's Avatar
Yes Axle u-joints... No Zerk fitting on OEM, Replace them...
2003 QCLB 2500 305/555 NV5600 3.73 4x4, Edge CTS Evo/Gauges, DPP Cool Tube, Baldwin PF7977 FF, GDP W/Donaldson P551313 FF, Steering Box Brace, On-Board Air W/Horns
tryNto is offline
post #3 of 6 (permalink) Old 03-05-2011, 06:08 PM
Yep axle u-joints. Just replaced my right one. The left one was two years ago.
wildbeast is offline
post #4 of 6 (permalink) Old 03-05-2011, 06:26 PM Thread Starter
ak_cowboy's Avatar
How many dodge engineers does it take to fill up Lake Michigan... I am not sure but lets try and find out. WTF Dodge no grease fittings are you kidding me. OK, I am done venting now. Time to replace then. Thanks guys.
post #5 of 6 (permalink) Old 03-05-2011, 07:35 PM
donperk's Avatar
if your replacing the u-joint yourself be careful of the speed sensor in the hub.its plastic and if removed pull straight out ,dont twist it will break.
donperk is offline
post #6 of 6 (permalink) Old 03-05-2011, 07:50 PM Thread Starter
ak_cowboy's Avatar
thanks for the heads up on that
