locking hubs - Dodge Cummins Diesel Forum
post #1 of 15 (permalink) Old 01-25-2011, 06:46 PM Thread Starter
locking hubs
hey guys, new to the forum and new to diesel trucks, so be gentle.
my question is: do they make a locking hub kit for our trucks? and would how much would it help us?
thanks
06mega: confused013:
o6mega is offline
post #2 of 15 (permalink) Old 01-25-2011, 06:49 PM
rgaskell's Avatar
Yes Danyatrac is one that comes to mind right off the bat. But there are other companys that make the kit to. Go onto the non-powertrain forum and do a search at the top of the thread list and you can see what others have said.
2016 3500 Asisn Megacab Stock for now
rgaskell is offline
post #3 of 15 (permalink) Old 01-25-2011, 07:35 PM
DodgeRamItUpYours2004's Avatar
They are hella expensive like $2500 for the set and don't really seem to help out with the mileage that much from what I have seen. I would leave it stock. I could hit 20 mpgs with my truck and a bullydog tune.
04 2500 4X4 QC 305/355, 6 SpeedSOLD
2001 2500 ECLB Monster VP, 7X14, .93 tubes, 3 piece manifold, Silver 64 Phat Shaft, ATS intake, 5" exhaust, Studs, Fire ringed, Built auto, AD165
DodgeRamItUpYours2004 is offline
post #4 of 15 (permalink) Old 01-25-2011, 10:31 PM
BIG Na$ty's Avatar
Yeah but just think you could throw her off in low and pull your house of your foundation, in 2 wheel drive.
06 qcsb,6sp man,cat&muff mia, S&B intake from the turbo 2 the bumper Dual yellow top optima batt 5in. rough contry lift, XD wheels, 37/14.50/20 nitto terra's,ranch hand rear bumper, recon cab lights, Pyro,Boost,Rail pressure, Kenny's pulling clutch. [SIGPIC][/SIGPIC]
BIG Na$ty is offline
post #5 of 15 (permalink) Old 01-25-2011, 10:37 PM
Or I could do like I did when I was younger with my K5 with 35's and decide to go mudding and drive in the hole in two wheel cause forgot about the hubs. I don't need to get out to put it in 4x4 and I like that. I can live with the rest. No house pulling for me.
post #6 of 15 (permalink) Old 01-25-2011, 10:47 PM
squid11's Avatar
I've also thought about this as my truck has a 6" lift with indexing ring and Daily Driving seams hard on the front drive shaft u-joints when the shaft is turning all the time. Just seams a little too much $$$. to spend on that when I want to upgrade on other issues.
'06 Dodge, 8" lift, Custom longarms, Bilsteins reservoir shocks, 37x13.5x20 Toyo's, Edge Juice programmer, Volant Cold air, MBRP exhaust. Built 48RE with Tripple disc.
squid11 is offline
post #7 of 15 (permalink) Old 01-26-2011, 07:14 AM
Dynatrac, Spyntech, Ems offroad and now Yukon gear makes them, im sure I missed one. Anyone of them can be had for under 2k or well under 2k if you purchase it at the right time
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
post #8 of 15 (permalink) Old 01-26-2011, 11:44 AM
psd1's Avatar
$1500-$1800 still buys alot of fuel. What are the real world gains of these things? Are we talking .5 MPG or 2-3 MPG?? I wish Dodge would have had hubs from the factory.
2004.5 3500 4x4, Air Dog 150, 5in. Magnaflow, Edge J/A, AFE stage 2 dry, Big A$$ Bumper, Built trans with billet bits, flatbed/sled deck on the way!
psd1 is offline
post #9 of 15 (permalink) Old 01-26-2011, 01:10 PM
jokintom24's Avatar
I think a lot of guys just go with the hub conversion just to avoid the crappy design of the orignal bearing/hub unit. OME parts alone are close to 600 bucks i believe. Then throw in labor if your not gonna do it yourself. The aftermarket one such as the dynatrac uses bearing that are about 60 bucks if i remember corrctly. And im sure there gonna last way longer than the OEM parts. There are also other benifits such as now your front diff doesnt spin or fron driveline. That means less wear on U-joints and diff. I think i read somewhere that it gets rid of like 135 lbs. of roatating mass. Ive also heard the truck seems to turn easier.
2005 Dodge Ram 3500, Long arms, 37's, 4.56 Yukon gears, Smarty Jr, AFE intercooler, Auto Meters, Air Dog165, Twin Viair 480 compresors w/ 5 gallon tank, train horns, JL audio, Source auto/ Opie billet 48re.
jokintom24 is offline
post #10 of 15 (permalink) Old 01-26-2011, 02:13 PM
pretty much said it all right there . if you know for a fact you are going to keep your truck for a long time get it done . i plain on keeping my 03 for as long as i can and should have followed my own advice becuase in the 4 years i had the truck i went through 5 front bearin units , and 3 u-joints . if you get the free wheel kit none of the axles in the front will turn , and it does make for easier turning . its on my goodie list for this year .
camaroboy8691 is offline
post #11 of 15 (permalink) Old 01-26-2011, 03:02 PM
superswamperctd's Avatar
I'm glad I bought the dynatrac kit, it did save on the mileage a little but when I snapped my front driveshaft, I just unlocked the hubs and went. I also just blew out my pinion bearing up front recently, lots of squeaking, just unlocked it again. Theres is benefits for it. The double cardavan joint wearing out quickly with big lifts is another reason, and of course the stupid factory hubs too...
95 2500 5 ton rockwells 60"x 30" v treads
05 ctd 12" keldermans lift 40" toyo mt's 46" baja claws
superswamperctd is offline
post #12 of 15 (permalink) Old 01-26-2011, 07:43 PM
I didnt buy the manual hub kit for any improvement in mpg. The little I gained I see as an added benefit.
MPD106 is offline
