Old 11-09-2007, 05:27 PM   #25 (permalink)
jstange2's Avatar
Does the Smarty automatically do the fast idle or do you have to do something special when programming? Also, how do I know when it is working? Is it when the motor is cold and the motor speeds up until warmer? Wow I just asked too many questions. Thanks guys for putting up with them.
Josh
2006 Dodge Ram 2500 CTD SLT, Auto, Mega Steps, stainless bed caps, extreme bed liner, chrome door & tailgate handles, no muff or cat, Smarty, triple pillar pod, isspro boost, EGT, tranny temp, no silencer ring, debadged, S&B CAI
jstange2 is offline   Reply With Quote
Old 11-09-2007, 06:09 PM   #26 (permalink)
Have a 2007 and the dealer enabled the high idle feature at no charge. Also had him turn on the Day Time Running Light feature. I've always had it on my GM vehicles and think it is the safer way to drive.
phitter is offline   Reply With Quote
Old 11-09-2007, 06:17 PM   #27 (permalink)
Have a 2007 and the dealer enable the high idle at no charge. Also had him enable the Day Time Running lights. Have had it for years on my GM vehicles and think it provides more safety.
Old 11-10-2007, 06:09 AM   #28 (permalink)
Dieselguy8599's Avatar
Josh
The Fast Idle, from what the dealer explained, is nothing more than a PTO option. It's enabled by turning on the cruise, hitting set, and then hitting the accl button to idle it up. I'm not sure how the smarty would turn that on.
Originally Posted by ah64id
So my dad brought up an interesting point today... Do you still have to press on the clutch to start the rig? Or does grounding #22 act like a clutch start cancel switch as the rig thinks its in park?
That's something I'm going to have to try on Monday when the dealer loads the Fast Idle for me. I think your Dad is on to something!:thumbsup
2006 3500 Laramie H - QC ° LWB ° 4x4 ° 3:73 ° G56
AFE Stage 2 ° Silencer Ring - MIA ° MBRP T-304 4" TBE 5" Tip ° CAT Delete ° TST PMCR R49 ° Smarty SW#5
Dieselguy8599 is offline   Reply With Quote
Old 11-12-2007, 11:49 AM   #29 (permalink)
Well, I tried what your dad was thinking and that didn't work. I didn't think it would.
On the other hand, I got the High Idle enabled today and the dealer only charged me $22.00 to do that and rotate the tires. I can't complain! It works like a charm and that's with the $12.00 part from the cummins dealer!:thumbsup
Old 11-12-2007, 04:11 PM   #30 (permalink)
Local Rotor Head....
ah64id's Avatar
Good deal...we wernt sure where the ECU got its signal for the clutch...
Good deal, going to get the pigtail soon.
05 3500 QC LB NV5600 4X4 SRW
Pricol's (EGT, Boost, DP, FP, RP, Oil)
Amsoiled, BMK-11
GDP MK-2+ w/ Cat 2 mic
Smarty Jr Revo
ah64id is offline   Reply With Quote
Old 11-12-2007, 05:52 PM   #31 (permalink)
I am going to take some pics tomorrow and post them. This is going to be real nice this winter!
Old 11-13-2007, 12:45 PM   #32 (permalink)
Here are the pictures that I took this morning.
High Idle Pin# 22 Install
Save the picture and then zoom in. The yellow wire goes into PIN #22 and then to the ground on the right. That's all there was to it and trust me, if I can do it anyone can!:thumbsup
Old 11-29-2007, 06:12 PM   #33 (permalink)
luckyhat12's Avatar
I just went to the parts store and the pin alone was $4.85. I got one but I sure think I should have gone ahead and gotten the other one as well while I was there. I plan to try and put the pin in while I am installing my exhaust brake this next weekend. I will let you know how it turned out.
Chris
--Chris-- 07 Silver QC LB 3500 5.9 4X4 G56 w/ SBC DD, BD Ex. Brake -Full Time RV'er-
luckyhat12 is offline   Reply With Quote
Old 11-30-2007, 07:15 AM   #34 (permalink)
Dieselguy,
I saved the picture that you have labeled and tried to zoom in on it but when I zoomed in on the text it became blurry to where I couldn't read it. Can you tell me what you have written in yellow and also green? Also, Can I go to the dealer first and have the software enabled before proceeding with the steps you listed or do I have to do the first six steps and then go to the dealer and have it enabled. Thanks!
Pat -> 05 2500 QC (Mineral Gray Metallic) 4x4, Short Bed, 3600 DD, NV5600 6 Speed, 35/12.5/17, Amsoil 4510, Smarty setting 9, Dipricol Pyro, Boost, & Fuel Pressure, Straight pipe, weatherguard truck box, Gutted tube and removed ring, HID's
metalli445 is offline   Reply With Quote
Old 12-04-2007, 02:18 PM   #35 (permalink)
03silver_hand_shaker's Avatar
my truck already idles up to 1000rpms what do i need to idle it with the cruise control??
03silver_hand_shaker is offline   Reply With Quote
Old 12-04-2007, 02:25 PM   #36 (permalink)
ah64id's Avatar
That is automatic and only happens when certain temp parameters are met... by having the dealer enabling the fast idle circuit you can do it when you want.. if its an auto all you have to do is have it enabled... with a manual (I am guessing this is you) you either need the clutch switch kit or to ground pin #22 on the ECM.
Amsoiled, BMK-11
Smarty Jr Revo
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
