| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#13 (permalink) |
ANyone know of an online place to get the clutch switch. I am not sure where the local cummins truck shop is and I sure don't want to pay the dealer price for that switch.
--Chris-- 07 Silver QC LB 3500 5.9 4X4 G56 w/ SBC DD, BD Ex. Brake -Full Time RV'er-
#14 (permalink) |
I wouldn't worry about the switch, I didn't, Anyone who drives a standard is most likely to depress the brake before letting the park brake off which will kill the high idle before you even get to hitting a gear with the clutch....you can buy the wire for the ground out for about 15 bucks at a Cummins dealer
2007,5.9L,3500,DRW,QC,SLT,4x4,G56,3.73Smarty on Level 5 - 4" Turbo Back Straight Piped - BHAF - Silencer Ring MIA - Espar Hydronic 5 - PacBrake PRXB - Diprocal Optix Pyro/Boost/Fuel Pressure - Soon to be installed Glacier Mechanical Lifter MK2 + Big Line Kit |
#15 (permalink) | |
Local Rotor Head....
05 3500 QC LB NV5600 4X4 SRW Pricol's (EGT, Boost, DP, FP, RP, Oil) Amsoiled, BMK-11 GDP MK-2+ w/ Cat 2 mic Smarty Jr Revo ![]() |
#17 (permalink) |
I'm not sure what the pig tails part number is either but basically it is a wire with a pin on one end that fits into one of the holes on the connector off the engine and the other end has a wire connector crimp on it so you can add another length of wire to ground the pig tail out to your battery post or wherever you decide to ground it. I can take a picture of it if you'd like me to.
#18 (permalink) | ||
#19 (permalink) | |
The Pig tail part number is 3824810. Cummsins sells them for $12.00. I'm going to pick mine up now because the dealer wanted to charge me $307 just for the Clutch switch Kit. Then more $$$ to install it. As it is, I can't find a dealer that won't charge me out the butt to just turn the software on. Going to cost me $86.00 + the Pig tail. Guess that's better than the $567 the dealer quoted me to to the switch and turn the software on.
2006 3500 Laramie H - QC ° LWB ° 4x4 ° 3:73 ° G56 AFE Stage 2 ° Silencer Ring - MIA ° MBRP T-304 4" TBE 5" Tip ° CAT Delete ° TST PMCR R49 ° Smarty SW#5
#20 (permalink) | |
any pics of the install would be great. I am going to do it to dads when he comes to town next month, and want to know what I am up against.... His dealer in WA wont even turn the software on, they think it will void the warranty... damn dealerships in yuppie central...
#21 (permalink) |
Well, got the part from the Cummins dealer in New Hudson, MI today. $12.72 was the final price. All you need to do the install on pin #22 is Part #3824810 from your local Cummins dealer, a 10mm wrench to undo the ground right next to the ECM plug, a 4mm alan wrench to undo the ECM conector, a 5 inch piece of black wire, a small size ring terminal, a crimper and a paper clip. Step 1: Undo the ECM connector from the ECM using the 4MM alan wrench. Step 2: Using the paper clip, Push it through PIN #22 from the engine side to get the little orange rubber plug out. Step 3: Remove the 10mm nut from the ground, You'll see the ground right next to the where the connector plugs into the ECM. Step 4: Connect the Black wire to the cummins part you bought. Connect the ring terminal to the other side. Step 5: Push the pin on the cummins part into port #22 on ECM wire harness. Should be to the right of a black wire on the connector. Keep pushing till you hear a click and feel the pin seat itself into the connector. Gently pull back on the wire to see if it snapped in. Step 6: Connect the Ring terminal to the ground. Step 7: Go to Dealer and have them charge you up the wazoo to enable the software. I have an appointment on Monday morning at 8:00AM to have the software enabled. We'll see if it works! I will also post some pictures as to what I did. Wasn't very hard at all.
#23 (permalink) | |
#24 (permalink) |
So my dad brought up an interesting point today... Do you still have to press on the clutch to start the rig? Or does grounding #22 act like a clutch start cancel switch as the rig thinks its in park?
