2006 5.9L grid heater - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 12-22-2010, 10:47 AM Thread Starter
hi-boost's Avatar
anyone know of a link for a parts phish? or can anyone tell me if there is a bridge/connection from grid heater "postive" post to post on a 2006 5.9L CTD? pics would be helpful
thx!
06 Big Horn Edition 2500 SLT,HD,5.9L,4X4,QC,SB,48RE,3:73,5" MagnaFlow/6" tip,BDTDPP V2.4.3,Quad BF,moded stk airbox w/Cool hose,Stk turbo,Pwr-Flow,Defiant,Thuren,6"lift,Carli,37x13.5-17 Toyo O,C,bagofparts,EBC,MK-2,Warn,Viper16.5T w/syn line
hi-boost is offline
post #2 of 17 (permalink) Old 12-22-2010, 11:11 AM
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
yeah this was just covered in another thread I read. there is a buss bar between the two studs on the back of the heater and only 1 power wire leading to the grid.
What do you need to know the info for? (replacing grid with used? reinstalling? rewiring?)
Back in the common snail game. 03 SO 2wd 480,000 miles and counting.
Parts for sale: Van Aken SmartBox, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. RACEME 07-09 Delete Tuners
Shibbyutman is offline
post #3 of 17 (permalink) Old 12-22-2010, 12:48 PM
07 5.9 QC LB 4X4 auto
mq105 is offline
The Following User Says Thank You to mq105 For This Useful Post:
hi-boost (12-22-2010)
post #4 of 17 (permalink) Old 12-22-2010, 12:49 PM Thread Starter
hi-boost's Avatar
"What do you need to know the info for? (replacing grid with used? reinstalling? rewiring?)"
thx for the info. i'm re-installing the htr and couldn't remember if there was a jumper from "post to post" on the htr connection. it was last yr when i removed it for a htr delete.
now i beleive i need a new relay (code P2609). checked everything else associated with code.
do you know how to clear the code? lol
thx mq105 for the pics!
hi-boost is offline
post #5 of 17 (permalink) Old 12-22-2010, 01:29 PM
can you hear the relay cycling under the hood shortly after start up? To find out if you need a new relay take a meter and check continuity between the two big poles on the relay as it cycles on and off. If it functions you should get continuity after one click and it will go away after the second click from it.
That code should clear itself once the conditions of the fault have been fixed...meaning once the grid heater cycles normally for 5-10 key cycles the light will go off. Codes can be manually cleared with any OBD-II reader
post #6 of 17 (permalink) Old 12-22-2010, 04:16 PM Thread Starter
hi-boost's Avatar
come to think of it,...i haven't heard the relay "click" at all. our next cold morning and i will check it. living in SE La. and the temps are like a roller coaster here.
just checking here...will ohm'ing while there is voltage present harm the testing device?
hi-boost is offline
post #7 of 17 (permalink) Old 12-22-2010, 04:40 PM
there will voltage present, but it won't have a path to ground, so there will be no path for current to flow.
post #8 of 17 (permalink) Old 12-22-2010, 07:02 PM Thread Starter
hi-boost's Avatar
ok. i'm gonna make a short jumpers tomorrow to apply 12vdc and a ground to the posts of the relay that gets voltage from the EMC(?) to see if it will energize. of course i will remove the small wires that controls it
if no click...must be defective. correct?
hi-boost is offline
post #9 of 17 (permalink) Old 12-22-2010, 07:24 PM
There are 4 posts on them two big, two small. Ground one small, make a jumper from the + batt. to the other small one, and check for click. if it clicks you're HALF done. Just because the armature is moving doesn't mean it is making contact with both of the large terminals internally. Once you power it up with + batt you need to check continuity between the two large terminals.
If you try and it doesn't click, then try to swap the terminals between the ground and + batt. I don't know if there is a diode internally to the relay that would make it function one way and not the other.
post #10 of 17 (permalink) Old 12-22-2010, 07:36 PM Thread Starter
hi-boost's Avatar
your correct shibbyutman. i didn't think about the relay may still pull in but still be defective with connecting the 2 large posts, thx.
i guess ohm'ing the 2 large posts, after energizing the relay will tell me if the path is good?
hi-boost is offline
post #11 of 17 (permalink) Old 12-22-2010, 07:40 PM
yep, but like i said, it needs to be tried with current flowing both ways (in the event it doesn't work in the first) just to make sure it isn't diode protected
The Following User Says Thank You to Shibbyutman For This Useful Post:
post #12 of 17 (permalink) Old 12-22-2010, 08:30 PM Thread Starter
hi-boost's Avatar
rodger that
hi-boost is offline
