Getting a real JAKE brake on a 5.9 retro kit coming soon - Dodge Cummins Diesel Forum
post #1 of 141 (permalink) Old 12-13-2010, 11:59 PM Thread Starter
Suffers from Black Lung
Cumminpwr11's Avatar
Since SEMA is over there are pics floating around with PAC brakes new combination braking system (which I been told not for us) so I made a few calls to Jacobs and this is where I am at.
I told them via email yesterday that pac brake is designing a brake to work with possibly the 5.9 and 6.7 cummins. Why have they not come out with a retro kit like this when they are the ones that pioneered this setup. Also there are a lot of use that use our trucks at or beyond limits and an exhaust brake is not they answer we need to make a living with. Please make a real engine brake for the 5.9 and 6.7 cummins.
They call around noon today as said.
"we have been thinking about a kit and started basis R&D to see what the options would be in making a retro head. We are talking to Dodge and Cummins to see about potential warranty issues with the kit and hope to have more answers in the near furture."
I told them thank you for the fast response and I hold they find the answer we have been waiting for. I would buy 3 almost on the spot for my two trucks and one for my dads granting they aren't 4K a piece. I also said please realize that money is tight for everyone in the working class but if you build it I would be a beta tester!
He said that he would look into it and try and get back with me.
I think we should flood Jacobs with emails so they know that there is a market for this and they would not just be building 3 just for ME
Chris
Chris
1997 Ram 3500 crew cab long bed dually NV4500 GDS-300 62/65/12
1936 Chevy pickup 4bta rat rod project build
2006 Jetta TDI 5spd 45MPG commuter
2005 Ford Excursion 6.OH Livewire TS+
2003 Chevy 3500 cab chassis Duramax LB7 all stock
Cumminpwr11 is offline
post #2 of 141 (permalink) Old 12-14-2010, 12:05 AM
rymac007's Avatar
I want one! But like you said as long as they are not 4 grand a piece, if i had that much to throw at my truck, id prob save a couple grand more and get a goerend.
Grey 06 mega, whistler sans silencer, 5" dp back no kitty, and a cheap wife.
rymac007 is offline
post #3 of 141 (permalink) Old 07-04-2011, 03:55 AM
i want one to
hicknate is offline
post #4 of 141 (permalink) Old 07-04-2011, 10:25 AM
macko300exc's Avatar
You would most likely have to do body lift tp fit the engine brake (compresstion brake) There needs to be a oil manifold on top of the rockers that would push open a single exhaust valve slighty. This would require new valve bridges, longer steam on one of the exhaust valves, the oil mainifold, wiring harness and ECU programing. That is if they plan to do them like an C Brake or a Jacobs brake on a truck.
macko300exc is offline
post #5 of 141 (permalink) Old 07-04-2011, 03:26 PM
Ya im not sure it is as easy as it sounds.Im with macko here.Thats alot of block that im not sure is gonna fit under the hood.And im not a betting man but ill bet its gonna be a pricey piece of hardware.Not sure how much room is between the valve cover now and the hood but any jake block i have seen is all of 6 inches or so.Would be interesting to see if they come out with one though.
2007 2500 4X4 5.9 CTD-Banks Monster exhaust,K&N drop in
Tazman40 is offline
post #6 of 141 (permalink) Old 07-04-2011, 03:33 PM
Dreadnaught's Avatar
only thing wrong with what macko said is the jake brake opens both exhaust valves with the bridge. not just one.
07 3500 MEGA DRW 4X4 G56 DPF DELETE AND EGR UNPLUGGED, EDGE CTS, AFE CAI
05 F-350 6.GO LARIAT STOCK CCLB DRW BLOWN UP! TRADED IN!
K.I.A. 11.11.12 2004.5 3500 4x4 .
Dreadnaught is offline
post #7 of 141 (permalink) Old 07-04-2011, 04:35 PM
No, a Jacobs brake (compression brake) only opens one exhaust valve. If you look in the pic, the red circle shows the valve that releases compression when the brake is activated. AThe one in blue is the other exhaust valve and is only used during normal operation. Both valves work when no brake activation is required. The reason the blue valve looks so different is that the valve dropped and made contact with the piston. this is the way the jacobs brake works on Cats, Cummins, Detroit, Mack, Navistar. This is an ISM
post #8 of 141 (permalink) Old 07-04-2011, 08:21 PM
TheDude724's Avatar
Subscribing.
TheDude724 is offline
post #9 of 141 (permalink) Old 07-04-2011, 10:42 PM
I want a jake brake soooo bad.
07' Inferno Red Dually | Smarty s-06, Retro solutions 55w
swoyekr is offline
post #10 of 141 (permalink) Old 07-05-2011, 01:24 AM
dunno what cat your looking at, but all our 3406's and c-15 acert the brake activates both exhaust values at the bridge.
post #11 of 141 (permalink) Old 07-05-2011, 10:17 AM
Ok, maybe i am wrong about Cats, but doesnt the bridge have a hole in one end of it? Doesn't the oil rail only push on one valve as the acutal bridge has the rocker lever on it?
post #12 of 141 (permalink) Old 07-05-2011, 11:01 AM
the actuator for the Jake pushes down on the top of the rocker that pushes on both valves with the bridge.
The Following User Says Thank You to Dreadnaught For This Useful Post:
diesel0895 (12-29-2013)
