3rd Gen. PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING
Got a related post on this but trying to get a quick answer. I removed the two bolts holding the housing. I assume I just pry it out? Not sure how it sits in the crank case.
Also is the breather tube near the filter supposed to be rigid or should it be flexible. Seems like it is rigid as mine is but just checking to see if I need to replace it also.
'05 2500 4x4 5.9L CTD AT. 20in MB wheels, Nitto Terra Grappler tires, Alpine stereo with 10in sub, Bully Dog GT, AFE stage2 XP intake, turbo silencer removed, 5in Silverline turbo back exhaust
Figured it out after seeing the new filter. Yep, it just pops out with a little prying/wiggling. It is simply sits in the casing with a large o-ring sealing it at the bottom.
The vent and return tube are somewhat flexible and fairly easy to remove with a flat edge screwdriver to slowly pry them off as you work it around the edge. Remove them before removing the filter.
Here is a pic of the crank case filter with breather and return tubes disconnected before I pryed it off if interested:
Why are you replacing it? Did your oil presure drop off or spike?
2005 3/4Ton 4x4 DIESEL Loaded Stock maybe
2013 Dodge Dart Limited Turbo Fast&Fun
2012 HO SLt Gray 4x4 RGCSB All H&S GOODIES,ARPs, Fass 150 Titanium, CCV Kit, Shibby Caps, S&B Intake FOR SALE
2012 Jeep Rubicon White Loaded Wife 5"Lift 35 Ats; Built to Play the Jeep her to
Harnessing the Power of Technology for the Warfighter NAVY/AIR FORCE Son
Thats what I am asking I don't know if this would cause this. I was told this that it couold cause this to happen.
Gotcha, that makes sense and the filter is a cheap and easy part to replace. Trying to recall what the maintenance interval is for them, but I can't remember.
I think someone mentioned it being like 60k miles but not sure. Not sure if this is a Dodge or a Cummins recommendation and/or if both agree or even list this. Doesnt seem like too many people are changing these at all but I certainly will be.
