04.5 Surging at Idle and Stalls - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 09-23-2010, 06:14 PM Thread Starter
Woodlandviewstables's Avatar
Just bought a 2004.5 3500 6 speed. It has a banks intercooler in it and banks exhaust but no chip. Drove home from Houston, Tx to Jersey Shore, PA with out issue. However it now intermittently idles rough and sometimes stalls after it first starts. I havent noticed any other side effect yet. Any ideas on where to start???? I have 98.5 2500 with a 24 valve, but am learning the common rail cummins is a differnt creature.
Thanks Shane
Woodlandviewstables is offline
post #2 of 9 (permalink) Old 09-23-2010, 06:32 PM
Gear Nerd
TX_Dj's Avatar
CR is a different beast, that's for sure.
First things first, see if you have any stored codes. With the key off and out, get in and close the door. Put the key in and cycle it on-off-on-off-on (leaving it on) and watch the odometer. It will start with "---------" and then read off any codes, finally saying "done".
You say you haven't noticed any other side effect, so I'll guess that includes no white smoke.
Check your oil, see if you smell diesel, put a few drops on a paper napkin and let it sit for a bit. There will be a lighter color "halo" around the oil spot after a little while if there's fuel in the oil.
I'm sure you know that part from your prior experiences though.
Things that can cause surges and rough idle and stalls right after starting are usually fuel-related, so we need to find out if you're getting good fuel pressure and rail pressure. If you're having a high or low pressure situation the codes will probably tell us.
2007 3500 MC DRW 4x4 5.9L (122k mi)
G56 / SBC SDD3250
aFe Stg 2 / Pusher / GH Delete / FTE 5" TBE
AirDog II DF-165 (P551315/BF1275) / GDP Canister Delete / Bosch 505 - Stock Tips (Replaced @ 112,381 mi)
Autometer / JVC / Polk Audio
Best Tanks: 16.6 towing / 23.92 unloaded hwy / 23.2 city
TX_Dj is offline
post #3 of 9 (permalink) Old 09-23-2010, 09:47 PM Thread Starter
Checkign codes
I will check the codes tonight and get back to you. Judging by your avitar you got you dodge in the same place i did in Houston.
post #4 of 9 (permalink) Old 09-23-2010, 09:53 PM
Gear Nerd
TX_Dj's Avatar
Yeah, when you said you got it in Houston, I thought about calling Lee to ask him what he sold you.
G56 / SBC SDD3250
TX_Dj is offline
post #5 of 9 (permalink) Old 09-23-2010, 09:57 PM Thread Starter
Houston
He was great to deal with. Love the truck.
post #6 of 9 (permalink) Old 09-23-2010, 11:50 PM Thread Starter
Codes
I get a P0191 code
post #7 of 9 (permalink) Old 09-24-2010, 09:20 AM Thread Starter
Something New
Well as of this morning it now starts rough. Real rough and it acts like its starving for fuel.
post #8 of 9 (permalink) Old 09-24-2010, 09:26 AM
Hide your cats!
mstoaks's Avatar
check out this thread
P0191 Tsb
2005 white auto, thanks to stoakenstine creations, 23 Diesel,smarty so6 Ats 5-star, 5" TBE to 6" stack, bhaf, GDP air boss, full triple pod, gdp 2 mic. edge ez 547hp 1078ft.lbs
mstoaks is offline
post #9 of 9 (permalink) Old 09-24-2010, 12:15 PM Thread Starter
Update
So i did some investigation and found that the High Ram Intake was leaking right at the manifold. Called Banks and ordered new gaskets. Then decided to check the bolts. No more than hand tight. So after tighting the intak down the truck runnes remarkably better but stil shoing the same code. Also found to two wires run up from the undersde of the fuse box out of a harness and into the fuse box. they are twisted together and taped. Cleaned them and used a connecter. Any idea on what that might be?????
thanks again.
