3rd Gen. PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING
I've got a newbie question sadly, I've been borrowing the family diesel until recently when I bought my own and was curious about something.
I work 2 weeks in 2 weeks out in the Canadian North and the truck sits for 2 weeks in -30 celcius weather but is plugged in. Is it a problem if I don't start it and let it run a few minutes for those 2 weeks? Is there any problems that could arise or what?
Any help would be awesome!
Already learned a ton from the forums!
Cheers
__________________ 2006 Dodge 3500HD QC/SB, 60HP BD Injectors, Edge Juice w/ Attitude Hot Unlock, Flo Pro Turbo back exhaust, Silencer Ring MIA, Kore Racing Rims, Chromed Out, "THE HUMMIN CUMMINS!!!"
[SIGPIC]https://www.me.com/gallery/#100012/DSCN0783[/SIGPIC]
As long as it's plugged In and better to keep out of the wind if possible you should be good!
2005 white auto, thanks to stoakenstine creations, 23 Diesel, bully dog td ver. 2.5.3, 5" TBE to 6" stack, bhaf, GDP air boss, full triple pod, gdp 2 mic. edge ez 517hp 990ft.lbs
The Following User Says Thank You to mstoaks For This Useful Post:
Thanks a ton man! I really appreciate it!
Here is my question, I also had the dimming and the voltage drop when the heaters came on, Also my seat heaters (on cold mornings 45 degf or lower) would blink and not come on. I would have to drive a minute or 2 then stop shut the truck off, restart the truck before I could get the seat heaters to work. Do you think the switch is going bad?
Rwo
2006 Dodge Laramie 2500 4x2 stock:Nerf Bars, 50gal Bed transfer flow tank:, K&N Air Filter, Undercover tonnau cover. Amsoil BK11 bypass filter, bug deflector, window visors and a 2007 Cedar Creek Silverback.
That sounds like your AC compressor cycling. Even with the AC button off, it will use the system on the defrost/defog settings. Normal.
Gotta just worship this site. Yet again here is a post answering a simple issue that i was gona ask a question on. Could never figure out why the A/C was working even tho it is switched off.
As i always have my heater set for your feet and the windscreen im guessing this answers my simple question
On my 06 the voltage drops to about 9V when the heaters cycle on, and back to 14V when they cycle off, THEN the check engine light comes on.
I get the light turned off, but next time the heaters cycle on/off, the light come on again. What gives? Why does the engine light keep coming on, and how do i stop it?
