Valve Adjustment - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 08-11-2010, 03:39 PM Thread Starter
Valve Adjustment
Any one know how often to adjust the valves? 06 2500
fatdaddy is offline
post #2 of 13 (permalink) Old 08-11-2010, 05:17 PM
There is a write up on it, if you do a search youll find it. Personally I took mine to a local diesel shop and paid them $300. I dropped it off before work and picked it up after work and I didnt have to get dirty and wonder if I did it corectly.
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
post #3 of 13 (permalink) Old 08-11-2010, 05:29 PM
They're supposed to be checked/adjusted at 150k miles but I would do it sooner than that.
2006 3500 SRW MC g56 4x4 Laramie / Isspros (FP, EGT, Boost) / GDP MK-2 micron fuel filter / severely allergic to cat & EPA / Smarty Jr 5.08 SW2 Tm4 Tq2 POD45
HOD-ISB is offline
post #4 of 13 (permalink) Old 08-11-2010, 06:43 PM
cotharyus's Avatar
A buddy of mine is a diesel mechanic, he says 120K.
2004.5 QC LB 4x4 Banks Monster Exhaust, CFM+, Icebox, cool tube, Banks Ottomind
Cotharyus
cotharyus is offline
post #5 of 13 (permalink) Old 08-11-2010, 10:15 PM
chood45's Avatar
Around 120k is factory recommended. However, most times they won't be out of adjustment.
2006 Dodge 2500 4X4 Quad Cab, Patriot Blue, 48RE Goerend VB & TC. Triple dog programmer. Hog muffler. Willie's Whistler Intake, Recon cab lights. 2.5" leveling kit. LT325 Terra Grappler's w/ 18X9.5 Pro-Comp Series 6001 wheels.
chood45 is offline
post #6 of 13 (permalink) Old 08-11-2010, 10:18 PM
ruidosododge's Avatar
iTrader Score: 5 reviews
I have seen them out of adjustment at 50k miles... Just did mine again at 95k and again at 125k
premature, yes, were they out of wack a tad, yes
there is a good write up on it here
Valve Adjustment 24 Valve CTD's
'12 VW Passat Previous Rams: '10,'06,'04,'01
ruidosododge is offline
post #7 of 13 (permalink) Old 08-12-2010, 06:39 AM
My apologies, I was incorrect about 150k. I just checked the service manual for an 06 and it says initial valve adjustment at 135K. The given procedure is below.
Keep in mind that the exhaust valve lash settings changed in 06 to the below numbers.
VALVE LASH ADJUSTMENT AND VERIFICATION
NOTE: To obtain accurate readings, valve lash
measurements AND adjustments should only be
performed when the engine coolant temperature is
less than 60 C (140 F).
The 24–valve overhead system is a “low-maintenance”
design. Routine adjustments are no longer necessary,
however, measurement should still take place when
troubleshooting performance problems, or upon completion
of a repair that includes removal and installation
of the valve train components or injectors.
1. Disconnect battery negative cables.
2. Remove cylinder head cover (Refer to 9 - ENGINE/
CYLINDER HEAD/CYLINDER HEAD COVER(S) -
REMOVAL).
3. Using the crankshaft barring tool #7471–B, rotate crankshaft to align damper TDC mark to 12:00 o’clock position.
a. If both number one cylinder rocker levers are loose, continue to next step.
b. If both number one cylinder rocker levers are not loose, rotate crankshaft 360 degrees.
DR ENGINE - 5.9L DIESEL - SERVICE INFORMATION 9 - 2643
4. With the engine in this position, valve lash can be measured at the following rocker arms: INTAKE 1–2–4 /
EXHAUST 1–3–5. Measure the valve lash by inserting a feeler gauge between the rocker arm socket and crosshead.
Refer to VALVE LASH LIMIT CHART for the correct specifications. If the measurement falls within the
limits, adjustment/resetting is not necessary. If measurement finds the lash outside of the limits, adjustment/
resetting is required.
INTAKE
0.152 mm ( 0.006 in.) MIN.
0.381 mm ( 0.015 in.) MAX
EXHAUST
0.533 mm (0.021 in.) MIN.
0.863 mm (0.034 in.) MAX.
NOTE:
If measured valve lash falls within these specifications, no adjustment/reset is necessary. Engine operation within
these ranges has no adverse affect on performance, emissions, fuel economy or level of engine noise.
5. If adjustment/resetting is required, loosen the lock
nut on rocker arms and turn the adjusting screw
until the desired lash is obtained:
INTAKE 0.254 mm (0.010 in.)
EXHAUST 0.660 mm (0.026 in.) Tighten the lock
nut to 24 Nm (18 ft. lbs.) and recheck the valve
lash.
6. Using the crankshaft barring tool, rotate the crankshaft
one revolution (360) to align the damper
TDC mark to the 12 o’clock position.
7. With the engine in this position, valve lash can be
measured at the remaining rocker arms: INTAKE
3–5–6 / EXHAUST 2–4–6. Use the same method
as above for determining whether adjustment is
necessary, and adjust those that are found to be
outside of the limits.
8. Install the cylinder head cover (Refer to 9 - ENGINE/CYLINDER HEAD/CYLINDER HEAD COVER(S) - INSTALLATION).
9. Connect the battery negative cables.
HOD-ISB is offline
The Following 4 Users Say Thank You to HOD-ISB For This Useful Post:
AA BEN (04-04-2011), Jamlewis (01-01-2013), Marks Marine (03-13-2015), TLB98'12v (06-10-2013)
post #8 of 13 (permalink) Old 09-05-2010, 03:13 PM
bigramdiesel's Avatar
The service manual for an 03 says no maintenance valve adjustment necessary.
Where are you guys reading 150K foe valve adjustment?
2003 Dodge Ram 2500 Diesel HO, 48re Trans, KORE Chase suspension, Carli cotrol Arms, 09 Mopar steering Up-grade, TOYO 35x12.2x17 M/T, Banks Exhaust, ATS Exhaust manifold & air intake, Amsoil Oil by-pass filter, 2micron fuel filter, trans & coolant filter
bigramdiesel is offline
post #9 of 13 (permalink) Old 09-05-2010, 04:06 PM
tinbanger's Avatar
source automotive is right next door to my shop. i had them adjust the valves on my 06 at 130. they said that the specs dodge provides have a very wide range. and that they have seen noticeable differences when adjusting within those parameters. They only charge 180 for an adjustment on my truck. I noticed a smoother idle and maybe a bit smoother accelerations.
you know the manual also says you only need to change your oil every 7500 miles, do you follow that service schedule? having them checked and adjusted can NEVER be a bad thing.
06 CQ 6SP LB 4X4 4" exhst,08 aluminum 1piece driveline,leveling kit,custom removable pipe rack. Airaid intake.Full navi deck with backup cam.170k+ and running hard.
tinbanger is offline
post #10 of 13 (permalink) Old 09-05-2010, 04:50 PM
2006 2500 RCLB 2wd + G56, bone stock. 122k miles.
Cekkent is offline
The Following 2 Users Say Thank You to Cekkent For This Useful Post:
Flyncowboyz (09-25-2010), PEvil (10-05-2010)
post #11 of 13 (permalink) Old 04-04-2011, 12:58 AM
mrslva's Avatar
Just did mine, they were are loose as hell(040). I was amazed. seems like
i picked up 25hp+ nice an quiet now. feel sorry for Harley dud when I stomped her down she let go a cloud ! yeah buddy 05 qclb 107000miles
mrslva is offline
post #12 of 13 (permalink) Old 04-04-2011, 01:15 PM
STR8JKT's Avatar
The local Cummins shop I went to recommends the first valve adjustment at 50k miles and then again after another 200k miles. They told me that the first adjustment is most important and is what they recommend in all their literature for commercial engine sales. They said that Dodge doesn't recommend the proper intervals.
2006 2500 2WD Auto, Glow Shift. Other than that it's stock.
A rainbow occurs every time Chuck Norris kicks Richard Simmons in the face.
STR8JKT is offline
