How to check transmission fluid? - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 08-01-2010, 02:31 PM Thread Starter
TONASKET's Avatar
Not sure of correct procedure to check transmission fluid level of '06 5.9L. Should the truck be running and in neutral? Can it be in park and not running?
Do folks run a little more than full in tranny>
Thanks
06' Ram 2500 5.9L Diesel. Auto, SLT Bighorn Quad Short Box. AFE Stage 2. BD Tranny Pan. 285x70x17, Smarty Jr. EZ Down
TONASKET is offline
post #2 of 6 (permalink) Old 08-01-2010, 02:39 PM
scott116's Avatar
iTrader Score: 13 reviews
Running in neutral.
There is no fluid flowing in Park.
You do not want to overfill it, it will cause foaming.
2003 2500 Sold!!!
2006 2500 SLT 4x4 QCLB
scott116 is offline
The Following User Says Thank You to scott116 For This Useful Post:
TONASKET (08-01-2010)
post #3 of 6 (permalink) Old 08-01-2010, 02:43 PM
TXAustin's Avatar
iTrader Score: 4 reviews
warm the truck up some then park it on a level surface with the E brake on and the truck in neutral with the engine running. Give it a min or two and then pull the dipstick out, wipe it off, shove it back in, pull it out and see where the fluid is at. I run mine with it about an 1/8" too full(about a qt), won't hurt it at all. Sometimes there is little bubbles that come out on the dipstick but don't worry much about that just let it sit in neutral for another minute and recheck.
-Austin
[04.5 QCSB] Jeff Garmon's Fat Shaft billet 48RE, 6" superlift, 37" Toyo M/T, XD Monsters, Super B Special/ S480 race cover, ATS twin pumps, II 65lpm (~250hp), ARP, Smarty SSR, AirDog 150, TC rail, 25k / 27k PRV's, Rail/fuel/EGT/boost/throttle%/load% gauges, Flex-a-Lite, 6" MBRP stacks, grid delete
TXAustin is offline
post #4 of 6 (permalink) Old 08-01-2010, 02:43 PM
Crude Dude's Avatar
x2, scott is correct. I had to contact dealership because it didnt seem right to me. At the time I did not know fluid was not circulating in converter in park. Make sure you run it through ALL the gears and then back to neutral to check it. Remember the e-brake : )
'07 2500 4x4 5.9, Leveled, 285/75/17 TOYO OC Extreme, Built trans, Smarty
Crude Dude is offline
post #5 of 6 (permalink) Old 09-03-2010, 02:19 AM
What are the symptoms of it too full? I am having problems with high rpms at highway speed and after rechecking levels found it 1/2" too high on dip stick. Could the two be linked?
2006 Dodge Ram 3500 SRW 4x4
90,000 miles/145,000km
tinpusher is offline
post #6 of 6 (permalink) Old 09-03-2010, 04:12 AM
TXAustin's Avatar
No it's not. 1/2" too full is where you want it after the fluid is hot and te truck is checked in neutral.
TXAustin is offline
