P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)? - Dodge Cummins Diesel Forum
post #1 of 2 (permalink) Old 07-24-2010, 07:19 PM Thread Starter
black Ram CTD's Avatar
What trigers this CEL and what do I need to chjeck to correct this? I keep getting the PO243 code and the PO480 code. Think I have the PO243 code narrowed down but not the fan code. Also how does the waste solenoid come out of the turbo housing?
04.5 QC SB 6 speed, 5" skyjacker 37's. Edge Juice HOT, ADII 165 MBRP 4" Duels, CFM+, Afe,
black Ram CTD is offline
The Following User Says Thank You to black Ram CTD For This Useful Post:
post #2 of 2 (permalink) Old 07-24-2010, 08:34 PM
cummins 05's Avatar
the solenoid just screws out i just had the same code unplugged the solenoid and put a 100ohm resistor across the wires also had the same code didnt go away but i got my boost back also have the fan code fixed the clutch wires and it hasnt went away yet check fuse 17 i think it was 10 amp for vistronic fan mine was blown prolly from the wires getting cut like i said my cel and codes havent went away yet hope this helps you
2005.5 3500 srw g56 6 speed valair dd ceramic fresh rebuild Industrial 120"s airdog 150 HTT 66/71/16 second gen mani swap Hx-40 downpipeDIY intake ARP 625's single 7 inch stack35-12.50-20 nitto mud grapplers leveled
cummins 05 is offline
