Fan Clutch manual switch - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 06-28-2010, 10:56 AM Thread Starter
Hello,
I just ordered a new Dorman fan clutch for my 2003. When I replace I would like to utilize a switch on the dash to engage the clutch when I want to, lice the a/c does. Has anyone done this or do you know which wire on the harness engages the clutch to lock it up? I just thought it would be nice to be able to do this without having to turn on the a/c. Any input is appreciated.
Mark
2014 Ram 2500 CC/SB/4X4/68RFE Big Horn
(SOLD)2003 Ram 3500 Dually NV5600
(SOLD)1992 Ram 350 custom crew cab GET-DRAG
McGivern is offline
post #2 of 8 (permalink) Old 06-28-2010, 08:54 PM Thread Starter
diagram
Does anyone at least have the wire diagram for the fan harness connection??
McGivern is offline
post #3 of 8 (permalink) Old 06-28-2010, 09:51 PM
Man, I don't know if you can do that safely. You may fry something. But heres what I show. My program won't let me copy wire diagrams, but I'll just tell you how they are listed. All but one wire go straight to the computer. If you backprobe power to the wrong wire, you are gonna fry either the clutch or the computer...
Dark Blue is 12 volt supply from fuse 36
White is "Sens Sply". I'm assuming a 5 volt reference wire.
Orange is "Fan Spd Sens". I assume the speed sensor
Black/Light Blue is a ground shared with several other sensors.
Light Green is "Sol Ctrl"
If I had to *guess*, I would say ground the light green wire. First, check the white wire with a dvom to confirm that has 5 volts on it.
You may cook something, set a code, put the truck in limp home mode, theres no telling... Use this info at your own risk. But thats your wires
07mega_cab is offline
post #4 of 8 (permalink) Old 06-28-2010, 10:36 PM Thread Starter
Thanks!
Appreciate the info; I'll proceed with caution. But I figure if I can send the same signal as when the a/c is on, I can do it... we'll see...
McGivern is offline
post #5 of 8 (permalink) Old 07-28-2010, 07:25 PM
i was wondering if you ever got your fan clutch wired up on a switch and if so how bc i need to do this to and i have no clue how.http://www.cumminsforum.com/forum/im...onfused013.gif
EVSBLAKE is offline
post #6 of 8 (permalink) Old 07-28-2010, 08:17 PM
tryNto's Avatar
See here Fan Clutch Control Experiment for some info on this...
2003 QCLB 2500 HO NV+Fast Coolers 3.73 4x4,
Edge CTS Evo W/Bunch of Gauges, Donaldson DBL7349 Oil Filter, Baldwin PF7977 Fuel Filter, GDP kit W/Donaldson P551313 FF, OEM Fan Clutch Delete, Steering Box Brace
tryNto is offline
post #7 of 8 (permalink) Old 07-28-2010, 11:19 PM
lmeyer9916's Avatar
iTrader Score: 4 reviews
I apologize guys, I still haven't made any progress on cutting the delay time down, I'm still tweakin on it though..
03 2500, 6 spd, 4x4, leveled, 315-70R-17's, BHAF, A-1 studs, Hamilton 181/210, SMARTY, Amsoil bypass,ATS exh man., Fluidampr, Airdog, 09 steering, KC's on top, DDP 50HP Inj's, Garrett Stg 2, Jake Brake, OASIS XD4000, 10 gals of tanks, shocker XL's
lmeyer9916 is offline
The Following User Says Thank You to lmeyer9916 For This Useful Post:
tryNto (07-29-2010)
post #8 of 8 (permalink) Old 08-07-2010, 02:33 AM
on my 05 i was wondering if the wire is brown and orange bc the guy that hooked mine up tapped in to that wire right at the computer but it is causein my truck to die when i flip the switch off sometimes and it is throwing these codes, p0480
p0483, p2509 so if you know any thing please help
EVSBLAKE is offline
