DIY Spyntec Lockout Hub conversion - Dodge Cummins Diesel Forum
post #1 of 182 (permalink) Old 06-07-2010, 01:32 AM Thread Starter
TECH SPECIALIST
steve05ram360's Avatar
Have a copy of the spyntec install instructions handy, read it to the end. Use this instruction at your own risk, I am
not an expert and there may be alternate methods to use. this writeup is based on my experience with this kit.
Experts be kind... havent tackled hub work in a long long long... no longer time...
Tools needed
4 ton floor jack
6 ton jack stands (or equivelant)
large screwdriver
lug nut socket(s) various sizes.
4mm, 5mm allen sockets
13mm, 18mm 1 11/16" sockets
3/8 drvie inch lb torque wrench
1/2 drive ft lb torque wrench
1/2 drive 4 lug internal 76mmx80mm locknut socket p/n25966 at autozone.
Materials needed
Royal Purple grease
The kit
1) put axle on jackstands & remove both front wheels. make sure the axle is level, prevents fluid loss.
2) remove brake/abs line bracket from axle (13mm socket)
3) unclip abs wires from brake line so the caliper can be move out of the way
4) remove brake caliper (18mm socket) and place on the ground out of the way.
5) remove rotor
6) remove the abs sensor using the 5mm allen socket and move out of the way
7) using 1 11/16" socket & impact gun, remove cotter pin & axle nut
9) loosen the 4 hub bolts and back out approx 1/4" or so. (18mm socket)
9) using 18mm and stubby extension, place socket up against the back of one of the hub bolts and turn
the steering wheel so that it pushes the socket up against the hub bolt... you may need to start the motor
and use the power steering to assist pushing the hub out. Gently push on the bolts with the steering,
move the socket to another bolt on the other side of the hub and repeat until hub breaks loose.
10) once the hub is loose, remove the bolts and slide the hub off the steering knuckle & axle
11) using screwdriver, pry out the axle enough so it starts to move out of the axle housing, once it is on its way out,
you will want to support it on its way out. There is a seal on the inside of the axle you do not want to damage, so be
aware. I pulled the axles out 3x so far and have not needed to change the seals... no leaks.
12) using 2 screwdrivers, pop out both retainer clips that hold the u-joint in place
13) using a large socket as a reciever place under one side of the u-joint and using a 2nd socket on top, tap the top
socket to push the u-joint out on one side so that you can remove the cap, flip the axle over and tap the joint back into
the 1st side so that the joint will move enough to come out, then tap out the other cap. (there may be an easier way)
14) re-assemble using the new shaft and MAKE SURE YOU PUT THE SHIMS ON THE JOINT BEFORE YOU RE-ASSEMBLE... this was not
in the instructions so I had to pull it appart and do a do-over. the screwdriver is there to allow you to see the shim.
The shim goes between the clip & the yolk. replace the clips.
15) using a cut off wheel, shorten the hub bolts by about 3/8 of an inch. I found it easiest to cut the 1st bolt down
after measuring it, then using the hub as a guide... made it pretty easy.
16) clean the steering knuckle surface using a wire brush
17) reinstall axle, put a light coating of grease on the end prior to installing & be careful of the seal when installing
it. you may need to rotate it slightly to align the splines.
18) put anti-seize on the knuckle face & bore (per the instructions)
19) slide the seal that goes over the mud slinger so that the lip is towards the outside of the truck. this is the
surface that will seal against the spindle. put a light coating of grease on this lip.
20) install the thrust washer over the stub shaft, instructions were not clear on which way it went so I put it with the
flat surface facing outward. there is a beveled edge on one side, (experts please chime in here...)
21) install the small v-lip seal in the back of the new spindle where the roller bearing is.
22) install the dust shield between the knuckle & new spindle and using the cut hub bolts, bolt the spindle to the
steering knuckle. Anti-seize is your best friend...
23) reinstall the ABS sensor using the 5mm allen socket, careful as they break easy over time. I had to use some force
to wiggle it back into the sensor hole. You may need to bend the shield back into place. make sure there is enough
clearance for the rotor.
24) install the v-lip seal over the hub & put a light coaging of grease on the v-lip.
25) pack the *&$^ out of the outer wheel bearing using your favorite method or tool. I tried a bearing packer tool but
just made a mess and resorted to the old method of packing it using grease on the fingers and working it into the
bearing. sorry, no pics... too messy.
26) install the bearing into the back of the hub
27) using a hammer, tap in the rear seal into the hub
28) now pack the cr@p out of the rear bearing, seal with grease... clean the inside bearing surface with a clean rag,
this surface will sit on the spindle and should not spin so grease here would not be good.
29) slide the hub onto the spindle.
30) now pack the cr@p out of the front bearing and slide over the axle into the hub. Push it all the way up as far as
you can, the hub should be centered on the axle.
AFE PG7 drop in filter, AFE Torque Tube, HTT 2.5 turbo, AFE e-mani, ATS Arc Flo, 50HP DDP injectors, 327k, HPTuners, G56, mpg threads ->
steve05ram360 is offline
The Following 4 Users Say Thank You to steve05ram360 For This Useful Post:
Gijohnny23 (05-05-2014), Sparkygoc (01-06-2016), Terry07_Dodge_5_9L (12-28-2015), W_A_Watson_II (02-26-2017)
post #2 of 182 (permalink) Old 06-07-2010, 01:33 AM Thread Starter
TECH SPECIALIST
part 2
31) next your going to take the spindle nut that has the small pin sticking out of it and thread it onto the spindle.
Note that the pin needs to face outward so that the locking ring can seat against it and this pin will go thru a hole in
the lock ring.
32) Use the spindle nut socket to torque this spindle nut to 50 ft lbs. while you torque this nut down, rotate the hub
back & forth & 360* around so that you seat the bearings. Once you have torqued this down, back the nut off up to 1/4
turn, enough so you can slide on the locking ring and find a hole for the pin to go thru. Once you have found this spot,
grab the hub and push/pull to check for end play. there should be none. Instructions told me to back off 1/4 turn, then
lock it down. Check for end play, if there is some, repeat. everytime I did this I had end play so I concluded they are
wanting to remove the 50 ft lbs of torque and then lock it down. for me, this ended up being approx 1/8 turn or so. I
did this for both sides, checked for end play (none) and rotated the hub to ensure bearings were not overly tight (they
werent).
33) slide on the lock ring and adjust the spindle nut so that the pins goes thru one of the holes. NOW check for end
play... if there is some you may need to repeat and flip the ring over... if you look at the placement of the holes, you
have multiple spots where you can seat the spindle nut...
34) once the lock ring is in place, & there is no end play & the hub rotates freely as expected, place the lock nut over
the spindle & tighten down to 125~150 ft lbs (per instructions)... I did 140
35) have a look at these 3 pictures... when you assemble the locker into the hub, it will only go 1 way. with the control
in the "Free" position, the end of the spring needs to mate up to the bottom of the "tooth" such that when it is rotated
to the "Lock" position, it does not slip off the end... if it does, it will not unlock and it will jam.
36) Next slide the lockout body into the hub, you may need to rotate it some to get it to line up.
37) insert the snap ring in the grove on the hub to hold the lockout body in place
38) there is an o-ring on the hub dial body, spread some grease over the o-ring to lubricate it.
39) line up the dial with the lockout body and bolt down with the allen bolts supplied (4mm allen socket)
torque the bolts in a cross pattern to 30 inch lbs.
40) now rotate the assembly with the selector in the "Free" position and verify that the u-joint/axle does not spin.
41) rotate the selector to the "Lock" position & verify that the u-joint/axle now spins as expected.
42) rotate the selector back to "Free" and verify the hub unlocks from the axle... if it does, yippee skippee...
43) reinstall the rotor, if needed, spray both sides with brake cleaner
44) reinstall caliper
45) reinstall abs/brake line bracket to axle & clip all the abs wires back into the clips on the brake line.
46) reinstall wheel and have a beer.
47) repeat for the other side, once complete, take it for a spin with the selectors in the free position.
48) verify there is no bearing noise, drive it long enough to heat things up, pull over & feel both hubs. they should be warm to the touch and you should be able to hold your hand on it for a few seconds. If both sides feel the same & there is no noise, lock the hubs & repeat.
49) verify that both hubs can be unlocked as expected.
50) if all testing is good... then your done.
Hope this helps... remember I'm not a mechanic (test engineer) but I like to pretend to be hahaha...
The Following 20 Users Say Thank You to steve05ram360 For This Useful Post:
1Faith4ever (03-14-2017), ALEKATNM (05-14-2013), ATFPSF (11-04-2012), chovanl (10-27-2012), commtrd (08-01-2013), Devilman (08-10-2011), dunerking (10-05-2015), emwave42 (10-04-2013), frankzappa (04-13-2015), GlennRMK (07-31-2010), GTABurnout (06-07-2010), hevyevie (09-01-2010), JLollis (11-17-2015), loco one (08-12-2010), Matafdo (06-08-2010), Polar Express (08-04-2010), radioactivenewf (05-01-2011), R_Zachs (01-31-2011), scotchwhiskey (03-06-2017), Sparkygoc (01-06-2016)
post #3 of 182 (permalink) Old 06-07-2010, 03:09 PM
Rollin' Heavy's Avatar
Nice post with nice pictures! Really nice finished look!
2005 2500 QC Silver, Pricol EGT and BoosT Gauges, Banks Cold Air Intake. GDP 2 Micron Fuel Filter and Amsoil 2 Micron Oil Filter. I bought the CUMMINS, its just that the Dodge came with it!
Rollin' Heavy is offline
post #4 of 182 (permalink) Old 06-07-2010, 04:42 PM Thread Starter
TECH SPECIALIST
thanks... I tried not to get grease on the lens filters lol.... (nikon d200 + 18mm-200mm vr lens)
post #5 of 182 (permalink) Old 06-07-2010, 07:27 PM
kblranch's Avatar
Sounds like the seals that go where the needle bearings are that support the axel on the inboard side of the new spindle. The needle bearings need to be packed with grease also.
2004, 305/555, 4x4, QC, 6spd, 1 piece driveline, Smarty Jr. (POD), Piers turbo,2005 exhaust turbo to tail pipe with MBRP cat delete pipe, Pacbrake, ATS exhaust manifold, B/W hitch, Sirius, RB1, GDP intake horn, GDP fuel filter
kblranch is offline
post #6 of 182 (permalink) Old 06-07-2010, 11:28 PM Thread Starter
TECH SPECIALIST
not big enough... the shaft is stepped in size from where it bolts to the steering knuckle... no way it would fit there.
post #7 of 182 (permalink) Old 06-17-2010, 10:04 AM Thread Starter
TECH SPECIALIST
Update...
Well its been a few weeks now and I've put some miles on it and I wanted to update those who are interested. The last tank I ran B5 biodiesel for 500 miles of mixed city/hiway miles, guessing its closer to 50/50 on this tank, ran the AC a few times, hauled a load of bark and romped on it a few times. This tank gave me 16.5 mpg Pre-spyntec mpg #'s would have been 14.5~15.0 mpg. Also worth mentioning is that on the B5, I get slightly less mpg compared to straight diesel...
I can say this kit gave me a solid 1.5+ mpg overall which is better than I expected.
spyntec, royal purple grease (& fluids throughout)
post #8 of 182 (permalink) Old 06-23-2010, 10:34 PM
ohioviper's Avatar
This is a great post and looks like a great upgrade for our trucks but omg the price. It doesnt cost that much to build the entire axle. I know these are AMA axles but holy crap. I used to work for Dana the build cost for a ready to roll D60 front was around $1200 with lockouts. Why is this upgrade so dam expensive ? Has anyone looked into sourcing the parts direct and skipping the middle man ?
Red 2006 CTD QC 4X4 Big Horn
Muffler delete.
Tekonsha Prodigy brake controller,285/75r/17 Nitto Terra Grapplers
ohioviper is offline
post #9 of 182 (permalink) Old 06-23-2010, 10:59 PM Thread Starter
TECH SPECIALIST
there is r & d plus machining expenses that drive the cost up.
when I decided to make the switch, 1 of my bearings was making noise, turned out both bearings were bad. The replacements dont seem to have a good track record and what I would have gone with from napa was going to run $370+tax each so it helped rationalize the cost some. looking at it that way, mine will be paid off in about 1.5~2 years with the amount of miles that get put on each year.
my opinion... worth every penny... last weekend wife & I went camping up in the Sierra's (7500' elevation change from home) and racked up 550 miles with a couple of long windy steep grades... was figuring i'd end up with about 16~16.5 mpg with the amount of climbing I was doing. to my surprise I got a sweet 18.6 mpg over that 550 miles. couldnt be happier. I'm curious as to what the mpg on long flat runs will be...
commtrd (08-01-2013), gsuburban (03-18-2015), OK CUMMINS (11-03-2012), Polar Express (02-19-2013)
post #10 of 182 (permalink) Old 06-23-2010, 11:08 PM
Good pictures and nice conversion. Maybe should go in the Tech forum
Mine - 2006 Mega 3500 6spd Coilover Conversion & 4 Linked Rear, Fox Racing Shocks - In Progress
Hers - 2008 Mega 2500 Auto Fox 3.0s on Thuren Long Arms
tgibbs is offline
post #11 of 182 (permalink) Old 07-04-2010, 01:17 PM
Quilbilly Brian's Avatar
I just finished installing the Dynatrac free spin with the Dynatrac locking hub.
the hardest part was being without a few essential tools like a deep socket for replacing the ball joints and I went to a local atuo repair shop and had the old u joints pressed out. it cost me $40.00 to have them do it.
The install directions were fantastic. I only wish I had a deeper 6 prong socket for the spindle nuts. Mine started bottoming out towards the end and made it hard to keep the socket on the nut when torqueing down.
I have to go back and re-adjust the bearing load. I drove the truck last night and one hub was hotter than the other but now that I know how to do the locking hubs it should be a piece of cake
2006 2500 Quad cab 4x4, Auto, short box SLT Big Horn inferno red with black rhino liner bed and side panels. Dynatrac Free spin kit with Dynaloc hubs
Amsoil BMK-21 bypass.2" leveling kit Baldwin 12/12
F/W separator under cab, Cat 2 micron fuel filter under hood
Custom Diesel steering box brace.
Quilbilly Brian is offline
post #12 of 182 (permalink) Old 07-04-2010, 01:20 PM
Yea it was expensive but I replaced my stock ball joints,(Dyna uppers Mquay-norris lowers) new u joints, new rotors and brakes.. Total cost with the kit and all the above about $3G.
But now I can replace bearings and not have to get whole new hubs every 30 to 75k.
Worth the investment for a truck I plan on keeping and using for a long time.
