3rd Gen. PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING
Newb here.....Anybody have or know of a good write up on how to install a temperature gauge on a 2003 48RE tranny? Boost gauge? I looked in the 3rd gen. tech articles but couldn't find one. (may have missed it). Also tried google and no luck. Finally got the gauges in and not sure where to put the sensor. is the install an easy tap in somewhere or would i have to drill?(drilling scares me haha) thanks for the help.
2003 Cummins HO Quad Cab 48RE, 2WD, BFG A/T KO 285/70R17
boost gauge is too easy you'll replace one of your intake bolts with a boost bolt hook your lil rubber line to it, and be done
I saw a neat way to hook up your trans temp without drilling DieselManor - Taking the Mystery out of Diesel Performance™ has a replacement transcooler line with a place to screw in your probe built into it...other than that you can drill your stock pan or buy a Mag HiTec pan...that's what I'm going to do.
-Duane Henrie
06 Cummins QCSB 4x4 Auto. Billet suncoast. PDI T4 Second Gen Mani. BD intercooler, intake mani and boots. II 85% over pump, II 120's. Hamilton 181/210, springs, and pushrods. HTT 64/71/13SS. Snow Stage 2. Lazarsmith Bars and gauge pods. T&C PRV. Smarty & MP8. Thanks to Diesel Performance Outfitters of Texas
706/1401 on 2/1/11 12.2 @ 110
We carry fitting to splice into the rubber hose section of the hot line to mount the temp sender. As for the Boost gauge, boost bolt, a hollow bolt, is the easiest way to install one.
94 Reg Cab 4x4 6 speed
A little work here and there..........
I apologize...let me amend my advice...check with sponsors before you go lookin' elsewhere...the sponsors actually care others may not.
-Duane Henrie
On my 07 I purchased the gauges from Geno's and they have an adapter called the Acu Temp Adapter. The temp probe screws into the adapter and the adapter has a groove that fits over the hot cooler line. Works great no cutting, replacing any lines. In addition, if you buy the boost gauge from them they supply a boost bolt free. Sorry I see now that you already have the gauges, anyway check Geno's garage for the Acu temp and boost bolt.
Diesel Nut can get ya going!!!! :thumbsup
I used the replacement cooler line from dieselmanor, before talking to dieselnet, and it turned out to be a bit more costly and time consuming than i planned (I drained/spilled out almost 5 quarts of ATF the hard way... ) - it works good and is very clean looking, once it is installed correctly!
DieselNut, is that a "vampire" type fitting to rubber part of the cooler line for trans temp?
2004.5 2500, QC, Auto, 4.10, TripleDog w/Outlook w/Pyro, Quad BF, ISSPRO Trans, Icebox w/Cool Hose
________________________________________
I love what I'm doing, I just don't know what I'm doing...
Just a suggestion here. As for the Tran's Temp, Additional fluid capacity and Cooling is a bonus with the auto, you may want to consider a DD pan and put the sender in it.
Floor It CP3 MOD's & PPE Dual Fueler Kits
6.7 Race / Delete Pipes and Sims in stock!
I had good instructions for replacing the cooler line (thanks diesel nut), but figured i knew better after seeing the cooler line was connected higher than where the pan bolted to the tranny. after i removed the cooler line, I only drained about a quart from the line, but then almost 4 qts from the (cooler line hole) in the tranny about 2 inches from the pan line...
didn't know there was that much fluid in the trans ABOVE where the pan bolts on. i thought the truck was "level", but i musta been wrong!
guess it never hurts to put fresh atf in there, even if it was only a month old...
Thanks for the replies guys. Diesel Nut, do you have a picture of the fitting already spliced into the hose? i want to verify the the spot that im thinking of.....its really the only spot it looks like. haha thanks.
The Following User Says Thank You to SilverBullet21 For This Useful Post:
