48RE won't shift to second or 3rd untill 3000 RPM's - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 05-29-2010, 06:56 PM Thread Starter
shambo's Avatar
Any one have any idea why the transmission won't shift to second or third untill the engine is running at 3000 rpm's fluids are good?
97 Dually 12V 12.78 MPH
DIESEL SPECIALISTS, FTI, AirDog, Airaid and COR Fab.
shambo is offline
post #2 of 9 (permalink) Old 05-29-2010, 07:17 PM
Cum4x4mins's Avatar
How many miles on the truck?
Thought about adjusting the bands?
Michael
'05 White QC 4x4 SRW 48RE 2500 Big Horn w/out the badge
-Edge Juice w/Att., Silencer Ring MIA, Straight Pipe
-35x12.50x17's Nitto Mud Grapplers
Cum4x4mins is offline
post #3 of 9 (permalink) Old 05-29-2010, 07:18 PM
Cum4x4mins's Avatar
Could possibly be the Gov. pressure solenoid also maybe?
post #4 of 9 (permalink) Old 05-29-2010, 07:31 PM Thread Starter
shambo's Avatar
The truck has 170K the tranny was rebuilt at 70K I was thinking about the Bands
shambo is offline
post #5 of 9 (permalink) Old 05-29-2010, 07:46 PM
Cum4x4mins's Avatar
Might want to at least check the front band which is on the outside of the trans and if it takes much adjustment then might want to consider the rear band which is in the pan. Front isn't very hard to do.
The front (kickdown) band adjusting screw (2) is located on the left side of the transmission case above the manual valve and throttle valve levers.
1. Raise vehicle.
2. Loosen band adjusting screw locknut. Then back locknut (1) off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw threads if necessary.
3. Tighten band adjusting screw to 8 Nm (72 in. lbs.) torque with an appropriate Torx socket.
CAUTION: If Adapter C-3705 is needed to reach the adjusting screw, tighten the screw to only 5 Nm (47-50 in. lbs.) torque.
4. Back off front band adjusting screw 1-3/4 turns, for diesel vehicles, or 1-1/2 turns, for V-10 vehicles.
5. Hold adjuster screw in position and tighten locknut to 34 bNm (25 ft. lbs.) torque.
6. Lower vehicle.
Michael
post #6 of 9 (permalink) Old 05-31-2010, 05:16 PM Thread Starter
shambo's Avatar
Bad news I dropped the pan and there are a couple of pieces of something in it. Out she comes!!!!!!
shambo is offline
post #7 of 9 (permalink) Old 05-31-2010, 05:26 PM
Cum4x4mins's Avatar
Damn that sucks. Let us know what it was. Good luck
Michael
post #8 of 9 (permalink) Old 10-04-2010, 12:32 PM Thread Starter
shambo's Avatar
the retaining c clip (wavey) let loose in the OD section and killed everything!
shambo is offline
post #9 of 9 (permalink) Old 10-04-2010, 01:20 PM
That sucks!
2006 Dodge Ram Mega Cab 5.9L Smarty S06 6" BDM Lift
35" Toyo Open Country Tires, What Cat, Intake
2006cumminsbeast is offline
