ECM Reprogramming Recall 06-07 5.9l - Page 3 - Dodge Cummins Diesel Forum
post #25 of 80 (permalink) Old 05-29-2010, 02:48 PM
07Bighorn's Avatar
I was afraid it was a sneaky way to lock out the ECM, it was the rumor on the stree.. but after doing some more research I'll be taking mine down and getting it set and hopefully the high idle set too... I have been to that dealer enough with multiple trucks so I'm hoping they just do me the favor instead of having to pay for it...
07 Dodge 2500 Big Horn 5.9L... AFe Stage2 Cx Pro Dry S, WinSpeed heater delete, MRBP cat delete.... Quad boost Fooler 296.7hp baseline. 2" leveling kit with Ion 133 wheels wrapped with 35" Nitto's and wants a playmate for my stock turbo!
07Bighorn is offline
post #26 of 80 (permalink) Old 05-29-2010, 03:24 PM
06 Cummins
iTrader Score: 5 reviews
It's a programming recall by the manufacturer to meet some kind of state law for compatibility - you should not have to pay for anything, and also not have to ask for a favor.
CD
2006 Dodge 3500 MC DRW 4x4 6-spd 3.73 LS rollin' on 19.5's. Not stock by any means . .
CD in NM is offline
post #27 of 80 (permalink) Old 05-29-2010, 05:13 PM
CD
Ive had my previous cummins trucks reflashed before from the steeler... its allways free. Why is everyone afraid of the reflash? usually after I have mine done they run better.
2014 2500 Black Appearance Package big horn CTD 4x4.
Thuren suspension, Rigid 30 inch e series, rear air.
MPD106 is offline
post #28 of 80 (permalink) Old 05-29-2010, 05:25 PM
FireMedic427's Avatar
When you take it down just ask to have the high idle enabled. They will hook the scanner to it and get it done. Like everyone else has said it is FREE. I will bet that they will try and find something to make money on you. Maybe they will come back and give you a quote for a cracked flywheel. LOL J/K I hope they dont.
2007 Dodge Crew Cab 5.9 liter 48RE Black Dually.Looking to upgrade to pillar gauges, smarty, intake, and muffler delete pipe.
ACDC
Stay Safe, Stay Low
FireMedic427 is offline
post #29 of 80 (permalink) Old 05-29-2010, 08:02 PM
SandyMushCummins's Avatar
Originally Posted by Pooter View Post
Mainly for winter time warm up, and if you have a smarty its already enabled.
If you have a 6spd you have to install/ground the 22pin(IIRC) on the ecm harness so it will work. 6.7 guys have it easier with a green wire by the parking brake in the cab.
Then some type of switch I assume? I guess I should search...
'07 2500 ThunderRoad QC 4x4, 5.9, G56, 3.73's, S&B airflow pack, ISSPRO gauges, 2.5" mini-lift, Power Wagon flares, 295/70/17 Dynapro RF-10's, 90k miles as of 6-15.
SandyMushCummins is offline
post #30 of 80 (permalink) Old 05-29-2010, 09:21 PM
so if i take mine in to get reflashed i need to undo all my wiring under the hood from my banks economing programmer and plug stock connections back up or what? Who else has done this reflash.. no changes in fuel economy afterwards?
'07 2500 5.9L auto, Bank CAI, Cat delete, Smarty Sr, 4040xl,
Stephen85 is offline
post #31 of 80 (permalink) Old 05-30-2010, 01:33 AM
jas9848's Avatar
there are actually a lot of options you can have enabled and disabled on these trucks. for example you can have the headlights turn on when wipers are in use enabled, door locks automatically at a certain speed, a whole bunch of others one i forget it's late i'm tired.
07 2500 5.9 Auto QC LB 4x4 / 4" Diamond Eye QT Exhaust
jas9848 is offline
post #32 of 80 (permalink) Old 05-30-2010, 03:21 PM
is there a site or something you can see all the features you can enable and stuff?
post #33 of 80 (permalink) Old 05-30-2010, 03:55 PM
tryNto's Avatar
Yep, its called an Owners Manual...
2003 QCLB 2500 HO NV5600 3.73 4x4, Edge CTS Evo/Gauges, DPP Cool Tube, Baldwin PF7977 FF, GDP W/Donaldson P551313 FF, Steering Box Brace, On-Board Air W/Horns
tryNto is offline
post #34 of 80 (permalink) Old 05-30-2010, 07:52 PM
Danderson's Avatar
I'll be interesting to see if anybody is able to reload their Smarty after this update. Marco's probably going to have to release another one. I like this 418b update I loaded.
'07 2500 SLT,5.9,regcab.,G-56,4wd,Northstar TC800 popup 24/7. SBC OKHD. Toyo AT2's. Dynatrac freespins and bj's. Synergy HD steering. Suspension mutt courtesy of Kore, Carli and Thuren.
Danderson is offline
post #35 of 80 (permalink) Old 05-30-2010, 08:29 PM
Matafdo's Avatar
Still haven't got my letter, if I do. High idle will be enabled. Another option that can be enabled on will be power on/key off.
06, 5.9, 2500, 4x4, Auto, QC, SB, RanchHand Front, Rear, GDP intake horn,Shibby delete, lines and rail, 2 1/2 level, fluidamper, 2nd Gen Swap manifold, Spyntec free spin, BW63/68/14, EFI(Anarchy Tuned), Carli BJ
Matafdo is offline
post #36 of 80 (permalink) Old 05-31-2010, 04:11 PM
2007LaramieMGM's Avatar
Im not too sure i want to go in for this.... Buuuut, i remember reading somewhere on this forum that if you had a programmer installed on the truck and removed it the only way to erase any tracks it may have left on the ECM is to get a computer reflash from the dealer. I just uninstalled my Diablosport Predator because i was very unhappy with it and it also caused my rig to throw the CEL which hasnt returned since i unistalled it. So i am just wondering if this reflash will get rid of any footprints left behind
2007 Laramie 2500 QCSB 4x4 48re: GDP MK-2 w/Donaldson filter, FBD 5" TBE, Donaldson 40" muffler, Quadzilla Boost Fooler, Cool Blue Hose, Mopar Air Filter, DTT Triple Disk TC, DTT Custom VB. SMARTY coming soon.......
2007LaramieMGM is offline
