P0299 CODE hELP - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 05-19-2010, 08:19 PM Thread Starter
amko22's Avatar
P0299 CODE hELP
Any one with any advice? I Had to replace my intercooler today and got it installed took the truck for a test drive and everything was fine. So then got stupid showing my a$$ at the house doing a burnout and everything was still fine. Backed the truck in the drive way and shut it off. Went out a hour later started the truck and the CEL is on and the truck is in limp mode. Took the truck to auto known and they pulled a p0299 under boost code and they could not clear it. Got back to the house and tryed to check the codes on the dash and got c-code a4 34. not sure what that is either. Can someone help?
Thanks in advance!
05 crewcab> Short Bed> Built Auto> SRW> K&N intake> 5in turbo back> Silencer ring MIA> 8000K headlights> 6000K Fog Lights> Smarty SO-6> Fass> 60hp nozzles> More to come!
amko22 is offline
post #2 of 3 (permalink) Old 05-19-2010, 10:13 PM
Hide your cats!
mstoaks's Avatar
check to make sure you tightened all your clamps down tight, or look for rips or tears in the tubing
2005 white auto, thanks to stoakenstine creations, 23 Diesel,smarty so6 Ats 5-star, 5" TBE to 6" stack, bhaf, GDP air boss, full triple pod, gdp 2 mic. edge ez 547hp 1078ft.lbs
mstoaks is offline
post #3 of 3 (permalink) Old 05-19-2010, 11:32 PM Thread Starter
amko22's Avatar
Thanks for the info, I checked that earlier, ended up Removing the MAP sensor, cleaning it and removing the Van Aaken to return the truck to stock. Re installed the map disconnected both batteries and re connected. CEL light went out and the truck is not in limp mode, going to pick up another MAP sensor just in case. Hope this solves the issue.
amko22 is offline
