Vibration in 2006 3500 - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 05-14-2010, 12:28 PM Thread Starter
Hope i get some help on my truck from here. I got a vibration in my truck when i get to about 50mph and one at 70 mph. Had the tires blanaced it help the 50 mph but not the 70 mph. Does any one got any ideas what this might be? It also only has 53000 miles on it so its not even broke in yet. any help would be greatly appriated.
liltractor is offline
post #2 of 13 (permalink) Old 05-14-2010, 12:35 PM
nostroker's Avatar
You might check the front end parts. ie: tie rod ends, drag link, ball joints, etc. Also search this site for "death wobble".
Something else that you can check, but you need someone rolling the truck forward for you while doing. Check ALL of the tires for high spots going the same direction the tread is going. You might have a tire seperating. Just replaced mine for the same type deal and 40-k miles.
Just a farm truck, with some extras!
2007.5 Dodge Ram 3500 C/C 6.7L, auto, 9'.4" CM HAULER BED, front replacement, H&S XRT with deletes and S&B INTAKE!
nostroker is offline
post #3 of 13 (permalink) Old 05-14-2010, 12:41 PM Thread Starter
yeah they checked for that separtion yesterday said all the tires where good and that there where no flat spots or anything that tires where in exellent condtion. i will check that death wobble like you say, take you heard of this before though.
post #4 of 13 (permalink) Old 05-14-2010, 01:17 PM
nostroker's Avatar
Yeap, from what I have seen it has been more of a problem on 4x4 and lifted trucks. Mine is a 2wd cab n chassis and so far no problems, but that part is all stock.
post #5 of 13 (permalink) Old 05-14-2010, 01:19 PM Thread Starter
yeah mine is all stock. The DW looked like its was a steering damper. So if you hear of anything else let me know. thanks.
post #6 of 13 (permalink) Old 05-14-2010, 01:40 PM
BIGREDMACHINE's Avatar
Rear drive shaft u-joints
2006 2500 QUAD CAB-AUTO-5 INCH TURBO BACK-JACOBS EXHAUST BRAKE-BUMPER TO BUMPER AMSOIL-BUCKSTOP BAJA-BUSHWACKERS-CFM+-COLD AIR INTAKE AMSOIL4510-SMARTY JR.--STAINLESS 6 INCH TIP-5 INCH ROUGH COUNTRY LIFT -STAINLESS WIRE MESH GRILL-CAB LIGHTS-WHORE RED-391RWHP-704TQ
BIGREDMACHINE is offline
post #7 of 13 (permalink) Old 05-14-2010, 01:49 PM Thread Starter
did you have this problem with your truck? and if so did it fix it?
post #8 of 13 (permalink) Old 05-14-2010, 01:57 PM
I had a vibration at 50mph and the dealer did the torque converter/flywheel change and it still had the vibration. They checked the u-joints front and rear first and they looked ok. After all that work they went back to the rear u-joint and replaced them and that was the end of my vibration. I think the u-joints would have been a easy fix but they warrantied this and the work was for free.
post #9 of 13 (permalink) Old 05-14-2010, 02:03 PM
mud sweat and gears's Avatar
I have 53K on mine, and just had the same issue vibation and squeaking at low mph. Changed the rear driveshaft U-Joints and it was solved. If you do this yourself, be ready to deal with the injected nylon around the cups! I used a torch to melt mine.
2007 Dodge 2500 4X4 5.9L Cummins with 4 speed Auto, Quad Cab SLT Thunder Road with Jake Brake, 5" turbo back Cat Delete FBD exhaust, Edge with Attitude, 2"HBS leveling kit and Tekonsha P3 brake control.
mud sweat and gears is offline
post #10 of 13 (permalink) Old 05-14-2010, 02:28 PM Thread Starter
so you did it your self and you had to melt it off? did you have to put another nylon on?
post #11 of 13 (permalink) Old 05-15-2010, 12:57 AM
Your new U-Joints will come with the proper retaining clips. I recommend getting a high quality U-joint with grease fittings. When you melt out the nylon be careful not to over heat the drive shaft or yoke, as they will warp on you.
post #12 of 13 (permalink) Old 05-15-2010, 08:53 AM
Diesel Junkie
TVtruck's Avatar
Moved to 3rd gen powertrain
Tim
2010 3500 C&C 4X4 ;EBY Built Flatbed ;H&S Black Maxx; DPF/EGR Delete; S&B CAI;South Bend CAISDD3600-GK,
Ohio Coal Rollers
Cumminsforum.com
TVtruck is offline
