Overheat - Fan clutch does not engage - Dodge Cummins Diesel Forum
post #1 of 24 (permalink) Old 05-11-2010, 01:53 AM Thread Starter
Hey guys,
I have a problem with my fan clutch. I noticed that when my truck is not moving or when it is driving up the hill my fan clutch does not turn on. The temperature gets up to around 220 and higher. The only time fan clutch turns on is when the Air Conditioning gets turned on, therefore my truck does not gets overheated. I did not change any parts yet, i am not sure what to change. How can I fix this problem? What should I check for?
03 3500 2wd nv5600 ... stock... 205xxx
ValovAlex is offline
post #2 of 24 (permalink) Old 05-11-2010, 06:07 AM
Dodgezilla's Avatar
iTrader Score: 18 reviews
There is a temperature sensor that is supposed to tell the fan when to come on. I'm not sure exactly where it is though.
04 Ram 2500,Green/Silver-305/555HO,48RE,3:73s, QC,LB,4x4,Roadwire Leather,Laramie Interior,Infinity, HE351 Turbo,Magnaflow 4" Exhaust,VA C3.2,Westach gauges,Torque Tube,BeCool Fan,Fogzilla,TRM,4th Gen 20" Rims w/ 265/60 tires,118,000 miles
Dodgezilla is offline
post #3 of 24 (permalink) Old 05-11-2010, 04:32 PM Thread Starter
Just replaced temperature sensor, but the problem is not fixed.
When I started truck today , fan turned on for 10 minutes and then turned off. When the temperature got above 220 the fan never turned on again.
post #4 of 24 (permalink) Old 05-11-2010, 04:38 PM
when the motor is off but warm, the fan should spin with some resistance. If it spins freely than you FC is done.
06 4x4 auto QC,BilletTrans,Fass150,II85%CP3,fleece cheetah63/65,II 100hp sticks,GDP 6.7 lines upgrade,ARP Studs,GDP Rail Conversion Kit,S&B,EFILIVE,35''Toyo,Bushwacker Pocket Style,spearco,Autometer(5),TurbSmart BOV w/controller, 636/1150rwhp, CARLI
RHurricane200 is offline
post #5 of 24 (permalink) Old 05-11-2010, 04:47 PM Thread Starter
Yes . It spins with resistance.
post #6 of 24 (permalink) Old 05-11-2010, 09:12 PM
Dodgezilla's Avatar
You may need to check for TSBs that may apply to your issue. Check Fritz's Dodge Ram Tech. He lists every TSB for our trucks by year on his site....
http://dodgeram.info/tsb/2003-index.htm
post #7 of 24 (permalink) Old 06-04-2010, 08:23 PM
stonehac's Avatar
Ok I changed my clutch fan still has the sAme problem. What's next. The fan turns on and off with a/c but never kicks on and roars like it used to when it gets hot going down the road.
stonehac is offline
post #8 of 24 (permalink) Old 06-04-2010, 10:07 PM
okay Iam not sure but I would check to make sure pcm is sending the signal to clutch because you say it works when a/c is switched on.
01dodgecummins is offline
post #9 of 24 (permalink) Old 06-04-2010, 10:57 PM
I don't think I have ever heard the fan running other then for the A/C on my truck, even when pulling my camper up hills in the SC summer heat. The ecm can engage the fan at lower percentages for engine cooling and you won't hear it. The only time you hear it is at 100%.
2014 2500 Laramie 4x4 CC Long bed black on black, 3.42 gears, 68rfe. Only mods so far are window visors and a tri-fold bed cover.
NickBeek is offline
post #10 of 24 (permalink) Old 06-04-2010, 11:14 PM
stonehac's Avatar
Well i used to never got over 200 on the stock Gage. now going up small hills with the camper in it ( put it in today) It goes about 1/8 inch above 200 (220 maybe) I drove down from Alaska to Utah and going up hills even in the dead of winter i would here it kick on. Now the only time i really here it while driving is when i first start up and leave the house. I also downloaded the computer and the fan clutch fault is gone now so i guess that is good.
Is there a service manual online somewhere to get a schematic?
stonehac is offline
post #11 of 24 (permalink) Old 06-09-2010, 09:34 PM
temp sensor
Where is the temp sensor you replaced? I'm having fan clutch issues and just replaced the fan clutch with a new one but still no luck.
Thanks
2004 3500 4X4 dually, edge EZ, AFE intake, 50hp nozzles, 200,000 miles
cdeand is offline
post #12 of 24 (permalink) Old 06-09-2010, 09:42 PM
ruidosododge's Avatar
iTrader Score: 5 reviews
please post something up when you all find out what it is, my fan clutch is acting up itself...
'12 VW Passat Previous Rams: '10,'06,'04,'01
ruidosododge is offline
