2006 Dodge 2500 Diesel lift pump - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 04-01-2010, 06:02 PM Thread Starter
Does any one know where the factory lift pump is?
Is the only pump the main pump on the engine?
There is nothing on the back of the filter.
rob
kd4ccd is offline
post #2 of 17 (permalink) Old 04-01-2010, 06:05 PM
WES
WES's Avatar
The only pump is in the bottom of your tank. Its smaller than a coke can and is mounted in your canister.
06 2500 (Auto)Smarty,Silver Bullet 66,ATS Arc flow,Airdog 150,F-1 Springs,ARP head studs, Maxspool cam,Industrial 120s,Industrial duals,TS nitrous kit,Permacool electric fans, and Banks intercooler.
WES is offline
The Following User Says Thank You to WES For This Useful Post:
Pig (12-26-2014)
post #3 of 17 (permalink) Old 04-01-2010, 06:07 PM
DodgeMech's Avatar
the transfer pump is in the fuel tank...it supplies fuel to your high pressure injection pump which supplies fuel to your rail which supplies the injectors
-CJ
02 Taco Prerunner
06 Jetta TDI
formerly, a couple of dodge diesels...again someday perhaps
DodgeMech is offline
post #4 of 17 (permalink) Old 04-01-2010, 07:55 PM
Sandhills Native's Avatar
rob
That is because yours is a 04.5 and newer. This is the 03-04 section and all of our lift pumps are or where on the back of the fuel filter canister. You have the new and improved version.
03 QCSB 5.9 HO, NV5600, Bullydog Crazy Larry, Raptor 150 lift pump, MAC intake, CFM+, 5" MBRP, 5" skyjacker lift,Thuren track bar, 35" mickey thompsons, Moto Metal 17x9 rims, Autometer Phantom gauges,Southbend 3250 & HYD-.75
Sandhills Native is offline
post #5 of 17 (permalink) Old 12-26-2014, 11:26 AM
I have an 06 to do is the lift pump built into the cp3
Duckslayer137 is offline
post #6 of 17 (permalink) Old 12-26-2014, 12:33 PM
jokintom24's Avatar
No. It's in your fuel tank.
2005 Dodge Ram 3500, Long arms, 37's, 4.56 Yukon gears, Smarty Jr, AFE intercooler, Auto Meters, Air Dog165, Twin Viair 480 compresors w/ 5 gallon tank, train horns, JL audio, Source auto/ Opie billet 48re.
jokintom24 is offline
post #7 of 17 (permalink) Old 12-26-2014, 04:33 PM
I have a new intake lift pump for sale if anyone wants $150 shipped to lower 48. let me know honda350rmx@yahoo.com
some of the 03-4.5 years have been swapped to the in tank pump with a retrofit kit.
honda350rmx is offline
post #8 of 17 (permalink) Old 12-26-2014, 05:38 PM
DodgeMech's Avatar
actually, he's half right...there is a gear pump in the back of the cp3 that bumps up the pressure from the lift pump before the fuel enters the pump's cylinders...
and, if his truck was an 06 duramax, that would be the only lift pump on the truck from the factory
-CJ
02 Taco Prerunner
06 Jetta TDI
post #9 of 17 (permalink) Old 12-26-2014, 06:55 PM
I replaced the fuel pump in the fuel tank and still not getting fuel to the fuel filter. I was told that it has something to do with the injection pump
post #10 of 17 (permalink) Old 12-26-2014, 08:32 PM
You have a lift pump problem. Can you hear the pump run?The filter is between the lift pump and the injection pump. Whoever told you it's an injection pump problem shouldn't be allowed near your truck.
Jhenderson is offline
post #11 of 17 (permalink) Old 12-26-2014, 09:41 PM
Don't hear anything getting 10 volts to be plug in on the fuel pump could it be something with the ecm or a relay. All the fuses r good
post #12 of 17 (permalink) Old 12-27-2014, 04:17 AM
papaduck's Avatar
To trouble shoot the current to the pump the pump will only run for a second or 2 when the ignition is turned on and the engine not started. To get the pump to run, bump the starter and do not start, then it will run for about 25 seconds.
03 Dodge 3500 SLT, HO, 6 spd, 4x4, SRW, quad cab, gauge on lift pump-boost-EGT-engine oil pressure and rail pressure, FASS 95, water seperator and 2m filter, steering box brace, 6.7L fluid damper
papaduck is offline
