vibration under load? - Dodge Cummins Diesel Forum
post #1 of 17 (permalink) Old 07-04-2007, 08:26 PM Thread Starter
KAS
I have an '07 5.9L 2500, CTD, 48RE AT, Q-Cab long bed. I've had the truck 2 months, it has 2400 miles on it.
Under high load, low RPM situations, such as accelerating in OD (torque converter locked up), there is a vibration, I can feel it through the floor and even up through the steering wheel. Its most prevalent while hauling my camp trailer (~4500lbs). Sometimes its bad enough to rattle the dash.
Is this normal? Any ideas?
KAS is offline
post #2 of 17 (permalink) Old 07-04-2007, 08:39 PM
Lombo's Avatar
Vibration that is felt though out the truck enough to vibrate the dash is not normal . Sounds like a drive line vibration. Binding u-joint or pinion bearing .
Lombo is offline
post #3 of 17 (permalink) Old 07-05-2007, 01:16 AM
Banned
DORKWEED's Avatar
Location: "The Peoples Republic of Illinois".....behind enemy lines
Sounds to me like you're lugging the engine. With the low end torque these bad boys put out, that's not real good for the drivetrain. Try downshifting to increase your rpm's.
DORKWEED is offline
post #4 of 17 (permalink) Old 07-05-2007, 02:09 AM
Dsljnki07ctd5.9's Avatar
If it's not a u-joint it may be that you need to shim your carrier bearing. Mine is a shortbed and I dont have one but I've read where more than a few guys with longbeds have had to shim it because it was off from the factory.
Chris
2007 Ram 2500, SLT Big Horn, Mineral Grey, 4WD, 5.9, BMK11 bypass, G56, 285/70/17, GV overdrive, D'Trac manual hubs, Smarty Jr, 6" Wwhistler, 4" turboback, LED's
2003 T600 Kenworth, C15 bridge, 13sp Eaton, 3:70Eaton rears, 22.5 lopros
Dsljnki07ctd5.9 is offline
post #5 of 17 (permalink) Old 07-05-2007, 05:55 AM
Hotshot3500's Avatar
i feel it too
i haul alot of different stuff but i use a 40ft float my vibration isnt near as severe as your like shaking th dash but in first gear i feel it and 52-56 mph. i can feel it I have yet to solve that problem and another thing is I can only feel it loaded empty i dont feel a thing
Hotshot3500 is offline
post #6 of 17 (permalink) Old 07-05-2007, 08:52 AM
Roid's Avatar
you guys running stock torque converters?
03 2500 SLT, more candy than a pedophile's van
Roid is offline
post #7 of 17 (permalink) Old 07-09-2007, 07:01 PM Thread Starter
KAS
Yes, stock TC.
KAS is offline
post #8 of 17 (permalink) Old 07-09-2007, 07:17 PM
14sec Cummins's Avatar
Have that Tc check i have a 99 and i had the same problem but once i had a new tc put in it was fine
Edge Comp Module, EDGE jammer stage 5 injectors,boch vp44 high flow injection pump,high flow lift pump,SuperchipTuned,4inch stack,AIR AID intake
BUILT TO RUN!!!!!!
14sec Cummins is offline
post #9 of 17 (permalink) Old 07-09-2007, 09:31 PM Thread Starter
KAS
If it makes any difference, its not a steady vibration, but instead its a pulsating vibration.
I think I might call the dealer this week.
KAS is offline
post #10 of 17 (permalink) Old 07-09-2007, 10:28 PM
bigger dodge's Avatar
How low of rpm are you talking about?
1990 RAM 350 reg cab fleet side almost 800.000 miles.,1993 RAM 350 ex cab,dualy 234k, 1997 RAM 3500 ex cab dually 298.000 all stock. 2001 Ram 2500 2wd 130.000 no mods yet
bigger dodge is offline
post #11 of 17 (permalink) Old 07-09-2007, 10:43 PM
jbarker's Avatar
A shudder under load usually indicates torque converter issues. Sounds like the lock up clutch is slipping. Mine used to shudder under acceleration until i changed out the atf and filter and added a good atf+4 fluid and the shudder went away. Again mine is a 99 not an 07 but thought i would see if i could help. Have you checked the tranny fluid? just because it is new doesnt mean its full. Also check for the color of the fluid it should be bright red and not smell burned. If it is low on fluid it would possible cause the shudder also.
John:thumbsup
jbarker is offline
post #12 of 17 (permalink) Old 07-09-2007, 10:50 PM
Roid's Avatar
My crap factory TC gets replaced tomorrow, only shudders in OD when the RPMs get close to 2K. Been driving at 55 only for over a week.
Roid is offline
