Updates on my cp3 rebuild - Page 2 - Dodge Cummins Diesel Forum
post #13 of 28 (permalink) Old 03-11-2006, 11:36 AM
03CTD
Guest
Posts: n/a
When you took the CP3 off, did you notice how tight the bolts were? Also did you see how the pump was sitting? and the seal looked?
post #14 of 28 (permalink) Old 03-11-2006, 02:10 PM Thread Starter
Tech Specialist
all the bolts were nice and tight and everything was in place as it should be,and the seals all looked good.
2004 305/555 6sp.DIY cruise control, 373's, bd short shift,homemade boost elbow,autometer boost and egt, isspro fuel press.,zenon flares,quad race box or sp diesel stage 1 stacked with diablosport predator, modded tone ring,bd pusher pump(and yes the truck still runs if the oem pump dies)afe intake and tt,sp diesel overboost eliminator,DIY modded cp3,
rich2500 is offline
post #15 of 28 (permalink) Old 03-11-2006, 02:18 PM Thread Starter
Tech Specialist
well its back together and running better than it has for a while,and my leak is gone,Sorry guys left in a hurry this morning to get the parts before they closed and forgot to take the camera with me.
rich2500 is offline
post #16 of 28 (permalink) Old 03-12-2006, 07:49 AM Thread Starter
Tech Specialist
If anybody else decides to approach the leak as I did, feel free to contact me and I can give part no. for the seals I used,that way you can have the parts on hand and do the job in one day.I used a 2 thousand thicker o-ring around the pump and 1mm larger o-rings around the six passages.
rich2500 is offline
post #17 of 28 (permalink) Old 03-12-2006, 10:39 AM
ill take the information please...how much were all the parts. the place you got your parts from will he ship just in case i cant find them around here?
Dan
2010 3500 Crew Cab Long Bed Laramie 4x4 4.10s
DF5152 is offline
post #18 of 28 (permalink) Old 03-12-2006, 11:16 AM
Former Staff Member
MR4WLR's Avatar
I would also like to get your list of parts and source. Keep it on hand should I ever need it:fist:
Corey Ritter - Amity, OR
2016 Blue Streak SRW QCLB Laramie. Buckstop/Warn 12,000 lb, WeatherTech vent shades, DeeZee tailgate assist, DeeZee tool/fuel combo with GPI pump
SOLD '04 Patriot Blue SRW 3500 QC 4X4 Laramie, 6spd 151K
MR4WLR is offline
post #19 of 28 (permalink) Old 03-12-2006, 03:06 PM Thread Starter
Tech Specialist
1- Harwal-25x37x7 shaft seal- lip type A-material Fpm
1-Harwal-25x36x7 shaft seal- lip type A-material Fpm
1-AME-2.50x54.00 mm Viton o-ring
6-AME-2.00x7.00 mm Viton o-ring
Philadelphia Ball & Bearing Co.
1346 Centre Avenue
Reading PA.19601-1412
phone # 610-376-7500
I don't know the prices yet because they were billed to my Dads business acct.
rich2500 is offline
post #20 of 28 (permalink) Old 03-19-2006, 07:29 AM Thread Starter
Tech Specialist
my cost for the rebuild $20.00
rich2500 is offline
post #21 of 28 (permalink) Old 03-19-2006, 01:47 PM
Tech Specialist
AK RAM's Avatar
Super cheap for a CP3 rebuild! Wanna do mine next?
Sold: 1992, D350, Extended Cab, Auto, straight pipe, Banks Power Pack - Purchased in 1992, sold in 1995
Sold: 1995, 4X4, Standard Cab, Auto, striaght pipe, plate, timing - Purchased new in 1995, sold Sep 2003
Sold: 2003, 4X4, QUAD, LWB, Twins, Snow, Helix2, Hot Cp3, Injectors, 315s - 12.32 @ 109mph - Purchased new Sep 2003, sold Jan 2011
Sold: 92 W250 Ext Cab 5 speed LE, 3.54's - Purchased in Jan 2011, sold Dec 2014
2015 Honda Fit (insert Roadrunner "Meep, Meep" here)
AK RAM is offline
post #22 of 28 (permalink) Old 03-19-2006, 03:51 PM Thread Starter
Tech Specialist
send it to me and I will fixer up
rich2500 is offline
post #23 of 28 (permalink) Old 03-19-2006, 08:34 PM
lets hope it stays leak free. I see a package there youll be able to sell when we dont have any more warranty on these things.:thumbsup
2005 3500 HD 4x4 CDT auto/with custom TPS VB srw AFE stage II DDP injectors (70 hp )Quadzilla STD Rokktech sensor 4'' turbo back exh EGT Boost Trans guages 402 hp 749 tq on the 60hp setting w injectors
syndicate is offline
post #24 of 28 (permalink) Old 03-19-2006, 09:15 PM Thread Starter
Tech Specialist
even if it only last a year or two until it leaks again $20.00 is alot better then buying new pumps when the warranties expire.
rich2500 is offline
