code p1754 - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 03-11-2010, 08:31 AM Thread Starter
code p1754
Check engine light came on with code 1754.Dealer says stuck trans throttle motor.Shifts late to second and hard.Is this the external motor on the drivers side of the trans?Can it be repaired or buy new?
50yz450 is offline
post #2 of 3 (permalink) Old 03-11-2010, 12:16 PM
Rbell's Avatar
Do you have a Smarty or anyway to clear the code? I've had this happend in the past, all I would do is clear the code and start it up, good to go at that point. It's pretty easy to remove the TV motor, just 2 bolts and a plug. I'm pretty sure you can remove the top cover and inspect the gears inside. This was just hear say but I've heard they cost around $160??Let me know how this works out for ya..ROB
05 Ram 3500 Garmon's FULL BILLET 48Re MBRP, AFE stage 2, Auto Meter gauges, Industrial Injection Phatshaft 330 and dragon fly 100hp injectors, Smarty.
Rbell is offline
post #3 of 3 (permalink) Old 03-12-2010, 08:47 AM Thread Starter
Had to buy one from the dealer at $300 cnd.Top cover is sealed with a crimped on band. The PLASTIC ????? gear inside lost a few teeth.A trans rebuilder freind said it is common. The dealer stocks the part.
50yz450 is offline
