Code P0203, and P2146 Help Please - Dodge Cummins Diesel Forum
post #1 of 24 (permalink) Old 03-09-2010, 10:35 AM Thread Starter
Cummins Crazy
Hello all
I have an all stock 2007 5.9 Dodge. It has 114k that has had almost zero issues till this last month. I drive twice a month over the passes from Seattle to Wenatchee for work. After one of these trips I was sitting in my truck on the job site with it idling doing some paper work. The truck started to run rough for no reason. It sounded like it was running on 4 cylinders. I tried to drive it around the site to see if it would clear up, but it was running on 4 cylinders for sure. The check engine light came on at the same time as the rough running condition started.
I shut off the truck and went inside to do some work, and returned 2 hours later with a plan to change the fuel filter. I called a friend in the area, and had them pick up a filter from town and bring it to the site. Once he was on site I started the truck to show my friend how bad it sounded, only to have it start and run smooth.
We changed the filter anyhow, and it was dirty, but not plugged looking.
Long story short, I drove it home without any further problem, and figured my issue was over. Fast forward 10 days. I was driving home from a good workout at my gym, and went to pass someone. I put the pedal to the wood, and the truck shifted down and the engine late came on. The motor acted like it dropped 2 cylinders again, so I pulled over.
I turned the truck off, and let it sit for a few minutes, called my wife, informed her that she might have to pick me up, then restarted my truck and it ran like a champ. I spent Friday doing some reading here on the forums, and learned of the trick to pull codes The Codes I pulled were P0203 Fuel Injector 3 circuit, and P2146 Fuel injector Group 1 Supply Voltage Circuit.
I am smart enough to understand that I have an electrical issue going on in my fuel injection system. My question to you guys is these. Have any of you had this type of issue, and if what direction was this fix? I am guessing this is a loose plug, or an ECM that is failing. Any help would be great.
Sorry for the long read, just wanted you all to have the details.
Cris
2007 2500 5.9 Silencer Ring MIA, K&N filter Yet
Docroth is offline
post #2 of 24 (permalink) Old 03-11-2010, 02:56 PM Thread Starter
Cummins Crazy
I can't beleive in all the people out here on this board that someone hasn't seen this problem or somthing like it. I am goign to give this a little bump to the top, please have a read and let em know if this sounds liek anything you have seen. As a side not. it has been good for 4 days now. no more issues.
thanks Doc
Docroth is offline
post #3 of 24 (permalink) Old 03-11-2010, 03:08 PM
Master of Mayhem NASFIG
rpage's Avatar
the 07 and 06 have been known to have the injector harness short out. this has happened to a buddy of mine and my truck. We also had the an injector short out later not sure if the harness caused it or not. the symptons that you describe are the same thing that happened on both trucks. the harness is on back order
Really don't give a rat's App**
rpage is offline
post #4 of 24 (permalink) Old 03-26-2010, 02:58 PM Thread Starter
Cummins Crazy
Thanks for the info, I would think this is the same issue here. The Problem has Fixed itself. Only till next time. thanks again
Docroth is offline
post #5 of 24 (permalink) Old 03-26-2010, 03:06 PM
Torque Monster's Avatar
iTrader Score: 4 reviews
Happened to me a few months ago, I have an 04 though. Mine ended up being my ECM, but what richard said is most likely the cause. There are a bunch of things it could be though.
* Injector harness
* Injector solenoid
* Injector harness interior (under valve cover)
* ECM
* Bad batteries
* Glitched ECM
This is what I went through and it ended up being my ECM, but you have not to worry to bad, your injector harness in the rear is more likely the suspect
Dallas
Sold: 2004 Dodge Ram 2500 QCSB
Now: Big Bad B7 Dually
Torque Monster is offline
post #6 of 24 (permalink) Old 04-02-2010, 05:30 PM
j birdfx4's Avatar
wow just happened to me today, so driving into work and the CEL comes on, so I was like okay call my buddy at dodge and get him to look at it. Well later in the day pull out of somewhere and the truck made a noise and the whole truck like chunked or jumped in a sense downshifted and EB got really loud. So I pull over and then bam CEL goes away and Im back on my way.
So Im taking it in cuz that lil Jump or buck it pulled in the road wasnt cool at all!! checked the code and got P203
2008 QCSB 4X4, Mineral Grey Sport SLT, (aka DUKE) Auto, 8" rize lift, 2.5 Fox reserviors, 37x13.50x22 Toyo MT, skating 22" Rockstars, Amp Steps w/LED's, Smarty JR, S&B, EGR/Cooler MIA, 5"TBE. "PREPARE FOR GLORY"
j birdfx4 is offline
post #7 of 24 (permalink) Old 04-26-2010, 09:42 AM
Nothin but a Cummins's Avatar
anything new??My truck is doing the same thing and its freaking me out. The only difference from everyone else is that my truck doesn't start up fine again. I haven't been able to drive it since it happened the first time
2006 Mega Cab 5.9L/ bd 48re/ efi live/ Pure Performance/carli/ bilstein/ thuren/ k&n/ mbrp/ bullydog/37x13.50x20 toyo mt/ train horns
Nothin but a Cummins is offline
post #8 of 24 (permalink) Old 04-26-2010, 09:56 AM
Only in a HEMI
BBRam's Avatar
iTrader Score: 13 reviews
Have you looked into this? VVVVVVVVVVV
2012 Ram 2500 5.7L HEMI
2012 Dodge Challenger SRT8 6.4L HEMI
2015 Hellcat, and ya, it's got a HEMI
BBRam is offline
post #9 of 24 (permalink) Old 04-26-2010, 10:12 AM
i Have been reading constantly since the problem started. I was hoping I could find some updates from people and there fixes. It seems like theres alot of people with the problem but all different fixes
post #10 of 24 (permalink) Old 04-26-2010, 05:01 PM
ok I just got in from lifting the valve cover. I inspected all the wires and gasket really well and don't see any problems at all. I then got my mulitmeter and did some ohm testing and my #2 injector ohmed out a 9 and all the rest are running .5-.6. So, does that mean my injector is shot or mabe my injector solenoid??
post #11 of 24 (permalink) Old 03-09-2011, 10:28 PM
Diesel Junkie
1-TON's Avatar
iTrader Score: 10 reviews
Bump for a follow up report on this problem as I am needing info as well.
JAMES 2002 RCLB 4x4, NV56, Flow-Pro 4" TB.
"The Work Truck"
1-TON is offline
post #12 of 24 (permalink) Old 03-10-2011, 08:48 AM
what problems are you having?
The Following User Says Thank You to Nothin but a Cummins For This Useful Post:
cwsmith (03-22-2011)
