tranny fluid and transfer case - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 06-20-2007, 02:00 AM Thread Starter
redbull660's Avatar
I have a 2004 cummins 3500, it has the 6 speed manual with 4 wheel drive. what is recomended for fluid in the tranny, transfer case and front and rear differentials. thanks
2016 Dodge Cummins 3500, Crew Cab long box, 4x4.
redbull660 is offline
post #2 of 9 (permalink) Old 06-20-2007, 08:04 AM
peterc06ram's Avatar
These are the recommended fluids that I pulled from the Dodge service manual. As always, Dodge recommends to use their product or one of equal quality.
tranny fluid: is Mopar Manual Transmission Lubricant
transfer case: Mopar ATF +4 Automatic Transmission Fluid
front and rear diffs: Mopar Synthetic Gear Lubricant 75W-90
If these are not correct, I'm sure that some here will chime in.
'06 Ram 2500 4x4 SLT, G56, 6" Superlift w/bilsteins and dual stabilizers, 35x12.5 Pro Comp Extreme A/T on 17" Pro Comp wheels, Thuren track bar, Smarty, Commader, Line-X, silencer ring gone, AFE dry filter, muffler del, all Amsoil and by-pass .
peterc06ram is offline
post #3 of 9 (permalink) Old 06-20-2007, 08:11 AM
Here's a link, so that you can download the PDF version of an 04' Dodge truck manual. You can find all sorts of useful stuff in it. I got this from someone else here on this site. Scroll down the page and it will be on the left of the screen under the picture of an almost naked girl.
"The Premiere website for Hemi Ram and Hemi SUVs."
post #4 of 9 (permalink) Old 06-20-2007, 12:25 PM
Roid's Avatar
AMSOIL ONLINE PRODUCT APPLICATION GUIDE - amsoiloaf.144572652
I have used this in the past!
03 2500 SLT, more candy than a pedophile's van
Roid is offline
post #5 of 9 (permalink) Old 06-20-2007, 01:00 PM
Duluth Diesel's Avatar
NV5600 transmission calls for a 5W30 Synchromesh transmission fluid. Not to be confused with a 5W30 engine oil. I have an NV5600 in my '02 and run this fluid: https://www.amsoil.com/storefront/mtf.aspx?zo=1206252
Your transfer case calls for an ATF+4 lubricant. I run this:https://www.amsoil.com/storefront/atf.aspx?zo=1206252
Front and rear diffs call for a 75W90 or heavier gear lube. With aftermarket horsepower mods, I recommend stepping up to a 75W110 fluid (new API category), and if you haul/tow at GVWR most of the time, stepping up to a 75W140 will provide the most protection for heavy use. I run the 75W110: https://www.amsoil.com/storefront/svt.aspx?zo=1206252
CAPACITIES
Engine, with filter..........12.0 quarts
Cooling System, Initial Fill..........28.0 quarts
Manual Transmission, NV5600..........9.5 pints
Differential, with 10.50 AA Rear..........4.6 pints
Differential, with 9.25"AA Front..........4.6 pints
Differential, with 11.50 AA Rear..........7.6 pints
Differential, with 9.25"AA Front..........4.9 pints
Transfer Case,NV241 GENII..........3.4 pints
Transfer Case,NV243..........3.4 pints
Transfer Case,NV271..........4.0 pints
Transfer Case,NV273..........4.0 pints
Transfer Case,NV244 GENII..........3.4 pints
TORQUES
Oil Drain Plug.....37 ft-lbs
Transfer case
Fill Plug.....15-25 ft-lbs
Drain Plug.....15-25 ft-lbs
Manual Transmission NV5600 6-SPD
Fill Plug.....22 ft-lbs
Drain Plug.....30 ft-lbs
Duluth Diesel is offline
The Following User Says Thank You to Duluth Diesel For This Useful Post:
Raf0419 (01-02-2016)
post #6 of 9 (permalink) Old 06-21-2007, 08:59 AM
Guest
Guest
Posts: n/a
I have found that every fluid affects every NV5600 differently...so if one doesn't work well, try another. And what works in that guy's NV5600 might not work so well in yours'. If you are satisfied with the factory fluid, stay with it...changing to another brand might make things worse (shifting).
With that said, I run Royal Purple Synchromax in the tcase with excellent results to date. It is the thinnest of the synchromesh-type fluids and closer to ATF in viscosity than a light gear oil...
I run a blend of Redline MTL and MT-90 in the NV5600. I have ran about every synchromesh-type fluid in my NV5600 (including Amsoil, RP, Pennzoil, and Redline) and redline seems to hold up the best in MY trans.
You might also read about additives in the NV5600, I have yet to find one that worked...I have used LSD modifier, LubeGuard Gear Supplement, and Lucas Tranny Fix...and again, what worked/didn't work in mine, might work great in yours.
And I run Royal Purple 85w140 in the rear...there is a recommendation (from dodge) to run 75w140 if you tow any...the 75w90 is actually a fuel economy thing more than a wear thing. I find the 85W140 provides a cooler running rear diff.
Just my thoughts...
steved
post #7 of 9 (permalink) Old 07-25-2009, 06:26 PM
Mkoegel's Avatar
i have a 06 G56 6 speed. whats the fluid needed for that.
06 2500 4x4, Banks Big Hoss bundle, BDTB with Scary Larry, silencer gone, exaust dump, train horns, blacked out lights 37" Nitto Grapplers. Goerend full built, maybe soon to come.....Turbo, Injectors, and fuel system. then no more haha
Mkoegel is offline
post #8 of 9 (permalink) Old 07-25-2009, 10:33 PM
For the G56 manual, AMSOIL ATF is what I recommend.
-Chuck
post #9 of 9 (permalink) Old 02-28-2011, 01:06 PM
can anyone tell me where the fill whole and drain plug are located on my 05 diesel dually 6 spd gearbox ? have a grinding problem with 3rd gear and hoping this will help
keating is offline
