CI-4 and CJ-4 oils, searched and no answer to this question... - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 02-19-2010, 04:07 AM Thread Starter
GT4point6's Avatar
Looking at getting an 04-07 5.9. I understand that the DPF trucks need the CJ-4 oil and the 5.9 is better with the CI-4 and CI-4+.
All of the oils I find have the same ratings, CI-4, CI-4+, CJ-4.
Valvoline Blue is a good example, (reg blue and syn same)
This product meets API CJ-4, API CI-4 Plus, API CI-4,
API CH-4,CG-4, CF-4, CF / SM, the performance requirements of ACEA E3-96, E5-02, E7-04 and the engine requirements of DB 228.3 ,MTU Type 2/Type 1, DDC 2000/4000 Series Type2/Type 1, MAN 3275, MAN 271.
So if a oil is CJ-4 rated and CI-4, is it good to use in the 5.9?
Since I have been unable to find any CI-4, CI-4+ only oils without the CJ-4 rating, what future is in store for the 5.9 oils?
Kevin - 2006 2500 Mega Cab Laramie 4x4 48RE. Banks Monster Cat Back, GDP 2 Micron FF, GDP intake and GD, Smarty Jr, 30% Honed Injectors, DPP Cool Hose.
GT4point6 is offline
post #2 of 11 (permalink) Old 02-19-2010, 04:13 AM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 12 reviews
If its rated cj-4 and ci-4 then its supposed to be fine for us. John Deer has a ci-4 rated oil and there are a few others.
2012 Laramie Longhorn, EFI by Ryan, 5" FloPro, 35x12.5x20 Toyo AT II
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, Old Numbers 421/946
1998 P-Pumped 24v, 4x4, NV4500 swap, Valair Dual Disk, BHAF, 4k GSK, .024 Dv's, Fass 150HPFP, Isspro, 5" exhaust, 2" Thuren Coils, Overland Shocks, 305/70r17 Nitto TG, 4th Gen Wheels, Fat Bald Asian 7x.010 Thanks Lee! VP Numbers 359/744
2005 Dually, 285/75r17 Nitto TG, Redhead, Thuren, Edge CTS, Smarty S06
98whitelightnin is offline
The Following User Says Thank You to 98whitelightnin For This Useful Post:
GT4point6 (02-19-2010)
post #3 of 11 (permalink) Old 02-19-2010, 03:22 PM
if the cj-4 oil is what you can find, use it. It meets the 6.7 standards for oil and exceeds the 5.9 standard. the difference, i believe, is just the low ash additives for the new emmisions on the new diesels.
MINE:2003 3500 cummins SO,47RE 4x4 QCLB,4"MPRB,Smarty POD,AirDog 100,Phat Shaft 62, Exergy 50's,Goerend TC,VB,Input,Suncoast clutches/steels
looking for more!!!
'91cummins6gun is offline
The Following User Says Thank You to '91cummins6gun For This Useful Post:
post #4 of 11 (permalink) Old 02-19-2010, 05:48 PM
DBLR's Avatar
CJ-4 oil also has a lower TBN.
2006 Ram 2500 Big Horn Edition Auto 5.9L Mineral Gray Met. Quad Cab SB 4X4 SRW 3.73's:
DBLR is offline
post #5 of 11 (permalink) Old 02-20-2010, 08:12 AM
REALISTICALLY, the CJ-4 oils that you buy NOWADAYS will provide all the protection you need.
Back when CJ-4 oils were introduced, the additive package anti-wear ingredients were changed from one pair of metals to a different pair of metals. The oil companies weren't quite sure, despite testing, how the switch would work out. They've now done their homework, and increased the amount or structure of the additive package. Bearings still come out unscathed, cylinder bores still come out unscored, even in OTR trucks that have hundreds of thousands of miles and lots of idle time, between overhauls.
If you really want, you can find oils with older API ratings at your local agriculture equipment dealers.
2006 2500 RCLB 2wd + G56, bone stock. 122k miles.
Cekkent is offline
post #6 of 11 (permalink) Old 02-20-2010, 11:40 AM
Castrol Tection Plus and Tractor Supply's "travellers all fleet diesel" are CI-4 rated oils still available mass marketed, if it matters.
04.5 SLT HO Dually 3500 CTD -bone stock.
Angelo C is offline
post #7 of 11 (permalink) Old 02-20-2010, 01:03 PM
TSC's Travellers oil is CJ-4 if it's in a white bottle, CI-4 if it's in a black bottle. Approximately.
Last time I looked at Castrol Tection (I don't remember what Tection it was) a few weeks ago at O'Reillys, it was CJ-4 with CI-4+.
Cekkent is offline
post #8 of 11 (permalink) Old 02-20-2010, 01:44 PM
Dr.Dizzle's Avatar
If you feel the need for a CL-4+ rated lubricant, there are options available in addition to those previously mentioned. John Deere Plus 50 15/40 is still available at JD dealers,however; JD claims that they have enough available for a few more months. At that time it will be phased out completely for the Plus 50 II CJ-4 rated oil also available. Caterpillar also carries Cat DEO 15/40 which is also API CL-4+ rated. This oil is currently manufactured by Exxon/Mobil for the N.A. region.
In addition, Amsoil also carries a synthetic 15W-40 Heavy-Duty Diesel and Marine Motor Oil with the CL-4+ rating.
2003 - 2500 SLT 5.9 HO 4X4 Quad Cab Shortbed, 48RE, Garnet Red Pearl, Isspro, Carli Pintop Suspension, Carli Torsion Sway Bar,Carli Ball Joints, Carli Control Arms, Raptor 100, Toyo 285 75 18 Extreme and 14 Laramie 18"wheels
Dr.Dizzle is offline
post #9 of 11 (permalink) Old 02-20-2010, 02:10 PM
Copy on the Black "Travellers"
and this looks pretty current for data...Castrol USA - Castrol Tection HD
Angelo C is offline
post #10 of 11 (permalink) Old 02-20-2010, 08:30 PM
On call 24/7
I forgot about the amsoil 15w40 hd diesel and marine being CI-4 and thats what I use in the 03. Also Mystic oils company is a synthetic CI-4 made in Oklahoma.
post #11 of 11 (permalink) Old 02-21-2010, 07:16 AM
We all better get used to using CJ 4 oils because CI 4 is history. Manufacters and retail outlets are just exhausting present stocks of CI 4 and then it will be CJ 4 only. With the exception of " Amsoil Diesel Marine 15/40" which is $30 bucks a gal. If anybody is dead set on CI 4 and finds some buy it all because it is history.
2006 megacab. cat delete pipe. otherwise stock.
Tim Lloyd is offline
