5.9 Cummins - Just tell me what kind of oil to use!! - Dodge Cummins Diesel Forum
post #1 of 47 (permalink) Old 02-16-2010, 05:15 PM Thread Starter
Howdy brethren (and sistren) -
Just got an '07 DCTD QuadCab 2500HD BigHorn with the 4spd auto tranny and manual 4wd. It was built in Dec of '06 and is thereby one of the last 5.9s out there (or so I have been told). I'm coming up on 75K miles, and wanting to change over pertinent fluids to the best of their respective categories. I have been all over the Honorable AlGore's internet looking for a straight answer on what kind of oil to use. It's like a MENSA convention - 12 people and 13 different opinions.
So - allow me to cut the bull:
Engine oil? best type
Engine oil filter?
A/T fluid?
A/T filter?
Transfer case?
Rear end?
Air filter?
Fuel filter?
Water separator?
AND - I've been reading up on running the 610 H.O. DCTD on WVO. What's the consensus here?
Thanks in advance for the good advice and 13 different opinions!
Cheers,
Justin
JNHaigler is offline
post #2 of 47 (permalink) Old 02-16-2010, 06:35 PM
DODGE74's Avatar
iTrader Score: 15 reviews
First off
I run Rotella T 15W40
Mopar Cummins oil filter
ATF +4
Trans filter is just a screen
I havent changed the transfer case or rears yet but it will be synthetic Royal Purple
Air filter (after market) S&B
Fuel filter/Water sep. is all one Baldwin 7977 (I'm pretty sure thats the number)
I wouldnt run WVO in mine if I were you. These injectors are very sensative. I think that you can run bio but I think its only like B20.
Specializing in custom tuning for your Dodge, Ford and GM.
Dealers for EFILive, mm3, UDC Pro, Warp, HPTuners and SCT
DODGE74 is offline
post #3 of 47 (permalink) Old 02-16-2010, 07:01 PM
Dr.Dizzle's Avatar
I run Amsoil HD synthetic 15/40 diesel /marine AME
Engine oil filter?
I use the Donaldson Endurance Synteq (Part# ELF 7349). This is a synthetic media filter which is 98.7 percent efficient when faced with 15 micron contaminants,and 50 percent efficient when faced with seven micron contaminants. It is the same filter as the Amsoil EA080 filter (painted different), but cost significantly less than the Amsiol filter.
A/T fluid?
Valvoline ATF+4
A/T filter?
Dodge dealer
Transfer case?
Valvoline ATF+4
Rear end?
Royal Purple 75/90
Air filter?
Baldwin #4162
Fuel filter?
Water separator?
Baldwin #PF7977 - The best fuel filter / water sep.(5um) available that fits in the stock cannister
I do not run it.
Cheers,
Justin
Hope that helps!
2003 - 2500 SLT 5.9 HO 4X4 Quad Cab Shortbed, 48RE, Garnet Red Pearl, Isspro, Carli Pintop Suspension, Carli Torsion Sway Bar,Carli Ball Joints, Carli Control Arms, Raptor 100, Toyo 285 75 18 Extreme and 14 Laramie 18"wheels
Dr.Dizzle is offline
The Following User Says Thank You to Dr.Dizzle For This Useful Post:
jhawk73 (05-14-2014)
post #4 of 47 (permalink) Old 02-16-2010, 08:32 PM
Groundshaker's Avatar
My truck runs with....
Engine oil? best type Valvoline 15w-40 (cummins recommended)
Engine oil filter?Fleetguard
A/T fluid?valvoline atf 4
A/T filter? AFE
Transfer case?valvoline 4
Rear end?valvoline syn.
Air filter? S&B drop in
Fuel filter?fleetguard
06 2500 4X4 Qcab Auto
I've tinkered a little here and there
Groundshaker is offline
post #5 of 47 (permalink) Old 02-16-2010, 08:41 PM
dodgetank98's Avatar
Engine oil filter?
A/T fluid?
A/T filter?
Transfer case?
Rear end?
Air filter?
Fuel filter?
Water separator?
AMS OIL ALL THE WAY!
05 6 speed (nv5600) 3500, cold air and 4" turbo back, sperco intercooler, BBI stage 1 injectors, smarty so6 pod, .
All parts from-
dodgetank98 is offline
The Following User Says Thank You to dodgetank98 For This Useful Post:
Dodgedeeesul (12-16-2015)
post #6 of 47 (permalink) Old 02-17-2010, 10:18 AM
bigred04's Avatar
don't run rotella unless you like the smell of raw oil under your nose. i was running it and when ever i'd get in or out of my truck i'd get a huge wiff of oil smell. its terrible. i starting using delo and no more smell! i may go to valvoline blue though but its a little more $$$$.
2004.5 2500 CC SB Volant CAI, 4" magnaflow, no cat, 305/70 MTR's
bigred04 is offline
post #7 of 47 (permalink) Old 02-17-2010, 10:51 AM
I was told to run 15 40 wolfshead and a wix filter I also run a quart of lucas with every change.
2006 2500 Quad Cab LB 5.9 AFE Stage 2 SI, Stock Pipe no Cat and Flo Pro Muffler, Edge J/A with Hot unlock, 2" leveling kit, Air bags, 295 70 17 Terra Grapplers.
jgolden is offline
post #8 of 47 (permalink) Old 02-17-2010, 03:53 PM
Engine oil? best type AMSOIL 5w40 Syn.
Engine oil filter? The new Fleetguard (can't remeber the number)
A/T fluid? Mopar ATF4
A/T filter? Wix/dodge dealer
Transfer case? Mopar ATF4
Rear end? Any synthetic 75w90
Air filter? AFE/Amsoil Dry Cotten reusable
Fuel filter? Baldwin PF7977
Water separator? See above, there is only one filter on the truck. Consider a FASS or Airdog 100 kit
AND - I've been reading up on running the 610 H.O. DCTD on WVO. What's the consensus here? I don't use it.
Cheers,
Justin
2003 2500 - SO Auto
Edge J/A, stright pipe, intake
shell_guy is offline
post #9 of 47 (permalink) Old 02-18-2010, 05:08 AM
Okiecowboy's Avatar
Amsoil all the way 15/40 MARINE[.
I run it in everything,(not the 15/40 marine)..motorcycle's, Beemer, etc etc. Have since 1980. Best on the market. Go to thier website & look at the comparisons yourself.
2004 RAM 2500
"You get more with a smile & a gun, than with just a smile"....
Al Capone
Okiecowboy is offline
The Following User Says Thank You to Okiecowboy For This Useful Post:
j_amsoil (10-15-2010)
post #10 of 47 (permalink) Old 10-04-2010, 02:37 PM
what about the wallmart stuff something tech 15w40 witha fram its all tested probably same stuff only cheaper.
two Canoe is offline
post #11 of 47 (permalink) Old 10-04-2010, 04:35 PM
Gear Nerd
TX_Dj's Avatar
I wouldn't run a FRAM oil filter even if you gave it to me free and paid me to use it. They are complete JUNK.
First of all, ask yourself... do you want to actually filter your oil? Fram really doesn't... not like a quality filter. Do you want your oil filter to last at least as long as your oil change interval? A Fram won't even last 3000 miles before it's paper endcaps dissolve inside, turning it into nothing more than a oil bypass tube.
As far as cheap oil goes... well, I'll say the same thing about cheap oil that I will about cheap filters: The engine in your truck costs anywhere from $5000-12000 to replace. Do you really want to run the cheapest, most questionable stuff to keep it lubricated? Oil is cheap. Engines are not.
I run a fleetguard 2 micron filter and Delo 400. Delo isn't that much more expensive than the cheap stuff at walmart, if at all, and I swear by it.
2007 3500 MC DRW 4x4 5.9L (122k mi)
G56 / SBC SDD3250
aFe Stg 2 / Pusher / GH Delete / FTE 5" TBE
AirDog II DF-165 (P551315/BF1275) / GDP Canister Delete / Bosch 505 - Stock Tips (Replaced @ 112,381 mi)
Autometer / JVC / Polk Audio
Best Tanks: 16.6 towing / 23.92 unloaded hwy / 23.2 city
TX_Dj is offline
The Following 3 Users Say Thank You to TX_Dj For This Useful Post:
j_amsoil (10-15-2010), serj33 (10-06-2010), two Canoe (10-04-2010)
post #12 of 47 (permalink) Old 10-04-2010, 05:00 PM
I run royal purple in everything i drive.
zsoccerdude17 is offline
