new cp3, new lift pump still no start.. but if i spray ether it starts.. need help!!! - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 3rd Gen. Dodge Cummins 03-07 Common Rail Forums > 3rd Gen. Powertrain
Old 01-27-2010, 06:47 PM   #1 (permalink)
i have a 2003 3500... i got in to my truck to go to work one day and it started to take a long time cranking but it than started. day after day it got longer and longer to start... now doesent start at all only if i recycle the key like 4 times cranks a while than starts. i changed the lifter pump. cp3 (injector pump) and filter...when i first put the cp3 in it started right up no prob after i let it run to get the air out i shut it off and it went back to long cranking... people told me i might have a hole somewhere, or i have bad injectors, or its a pressure relief valve...idk what it could b and the last thing i want to to go back to the dealer...please help i spent wayyy to much $ and its just sittin there...
tommy smoke stax is offline   Reply With Quote
Old 01-27-2010, 06:51 PM   #2 (permalink)
what lift pump did you put in?
what CP3 pump did you put in?
why did you change out those items first?
reason i ask is that it sounds more like injectors, but will need more info on your truck. like mileage?
did someone point you in that direction to have those pieces changed?
should really get a flow return test done, or send the injectors out to a shop who can test them/fix them/ rebuild them
04,3500,auto,silver Quad,4x4,sps62,5"magnaflow,suncoast,Fass,afe,MP8,s marty TNT,TST,gauges,mag hytec diffs and trans covers,air bags,amp reasearch,FF front bumper,methods,37"toyo MT,5"lift,ATS flares,CFM intake,coolant bp
waiting to go on, head studs,fluid damper,twins,TC rail,air boss,wicked 120's
pullinhard is offline   Reply With Quote
Old 01-27-2010, 07:04 PM   #3 (permalink)
everything is stock.. stock lift pump, stock cp3... i have about 140,000 miles on it..
Old 01-27-2010, 07:08 PM   #4 (permalink)
Fuel only 1000+ hp, been there done that.
THE STIG's Avatar
iTrader Score: 5 reviews
why did you change the lift pump and cp3? Sounds like an injector issue to me
Powerful - Reliable - Inexpensive. Pick any two at a time, the third is not included.
12 QCLB DRW aka "Doooly" the hotshot truck
04 RCSB SRT-10
THE STIG is offline   Reply With Quote
Old 01-27-2010, 07:08 PM   #5 (permalink)
TXAustin's Avatar
IMHO it sounds like you either have a leak somewhere or a bad injector(s). Common problem on the CRs.
Have a flow return test, and hook up a rail pressure gauge to see what you are putting out.
[04.5 QCSB] Jeff Garmon's Fat Shaft billet 48RE, 6" superlift, 37" Toyo M/T, XD Monsters, Super B Special/ S480 race cover, ATS twin pumps, II 65lpm (~250hp), ARP, Smarty SSR, AirDog 150, TC rail, 25k / 27k PRV's, Rail/fuel/EGT/boost/throttle%/load% gauges, Flex-a-Lite, 6" MBRP stacks, grid delete
TXAustin is offline   Reply With Quote
Old 01-27-2010, 07:12 PM   #6 (permalink)
great more money to dish out...lol...doesent injectors cost like 150$ a peace? i hope the they can fix the stock ones...lol
Old 01-27-2010, 07:16 PM   #7 (permalink)
TECH SPECIALIST
steelhead01's Avatar
that dealer shop has milked you dry.
stay away from them.
since you have no diesel mechanical knowledge take it to your local hot trucks shop that specializes in Dodge/Cummins.
get references on your states forum here
will save you money and headaches in the end. can destroy the engine running it low rail pressure lean on diesel or leaking injectors that dump diesel into the crank case.
get your engine parts from a authorized Cummins listed dealer, half the price of rip off Chrysler Corp. and you're certain to get real made by Cummins parts, not some Oriental pot metal knockoff that violates patent laws and is not tested
real Bosch HPCR new FIs for $150 a piece is only in fairy tales, the cheap ones on ebay are made from Chinese noodles.
cliff
AH64ID: Is your kitty in place?
TONASKET:You callin me a *****???
steelhead01 is offline   Reply With Quote
Old 01-27-2010, 07:17 PM   #8 (permalink)
jjrightmire1973's Avatar
Cheapest place I have found injectors is $260.00 each plus $80.00 core charge
2003 H.O 543 HP and 1273 torque before Stage 3 pump and beta 4.2
jjrightmire1973 is offline   Reply With Quote
Old 01-27-2010, 10:00 PM   #9 (permalink)
WHERE! WHERE!
2003, 2500 2WD, AMSOIL Stock, 26 Years USAF still going!
HillCountry is offline   Reply With Quote
Old 01-27-2010, 11:07 PM   #10 (permalink)
every time i read your replies,( steelhead01) i can't help but laugh. you have a way with words!!!!
but make perfect sense
injectors are pricey, but not as pricey as replacing a motor.
thats why i ask why you chaged out that stuff first.
i had a buddy with similar problems, he took it to 6 different dealerships, all in which took his money and replaced stupid stuff without testing anything. needless to say, he had a no start, unless using starting fluid. i replaced injectors for him, and fixed his problem, but it was after he spent way too much money on needless items. first dealer should have done some test to see that the injectors were wore out and were returning too much fuel back, and not letting it get to the psi required to start the engine.
Old 01-28-2010, 12:38 AM   #11 (permalink)
DELETE YOUR TURBO!!!!!
WATERLOO49's Avatar
iTrader Score: 4 reviews
injector is byppassing guarenteed if it will pop off with a huff of either you have an injector that wont let it build rail pressure xtreme diesel has good prices on replacements
YOUR DREAM TRUCK
TURBO-Deleted
INJECTORS-500hp
CHIPS-STACKED PRINGLES AND A DORITO
PERFORMANCE XTRAS-Flux capacitor, custom cut silencer ring, twin smoke switches
Body- wal mart chrome, 20" stacks, 500hp stickers
ALL SMOKE AND NO GO THE ONLY WAY TO ROLL!!
NEBRASKA DIESEL CREW PRESIDENT/WATERLOO FIRE DEPT
WATERLOO49 is offline   Reply With Quote
Old 01-28-2010, 03:13 AM   #12 (permalink)
TECH SPECIALIST
hell, what am i doing wrong.
they don't give me 6 chances at the craps tables in Vegas.
What LIES the Dealer tells you and all the cash you dump at a Dodge dealer stay in the Dealer
"""""""he took it to 6 different dealerships, all in which took his money and replaced stupid stuff without testing anything. needless to say, he had a no start, unless using starting fluid. i replaced injectors for him, and fixed his problem, but it was after he spent way too much money on needless items. first dealer should have done some test to see that the injectors were wore out and were returning too much fuel back, and not letting it get to the psi required to start the engine.
