- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
Question, towing w 37s
Anything I need to do to tow 9-10k with my 07? Truck has 3in and 37 in procomp extreme at's. Edge juice w attitude, extreme power puck, exhaust, intake. Trans is stock and thats what im worried about (15k miles). In due time im going to change the converter and valve body but was just gathering input if the truck would be ok with this load the way it is. I would not run the edge any higher then 2 (40hp). The 37s on rockstars did zap the power noticibly. Thank you in advance
2007 5.9 Edge,Afe,Silverline, 3in 37s 1998 12v, 11.70@113.8mph A5k, Ddp's, Goerend Dads 1997 12.16@110 / 1994 dually tow rig. |
#2 (permalink) |
lesbian at heart
![]() Join Date: Mar 2008
only thing you need to do is tow away ! no issues with towing
on 37's, i do it all the time. cattle, jeeps, etc...
jason 04.5 6sp qclb smarty - valair - isspro - gdp - fass
#3 (permalink) |
TECH SPECIALIST
minimum put on an extra deep tranny cooling pan, will boost your ATF capacity by 3.
Derale Part# 14210 ![]() change all of the ATF 15 quarts, use only synthetic spec'd ATF+4 add a large Allison plate fin tranny cooler if it's in the budget. add a tranny temp gauge and keep below 200d F for long life. watch the pyro EGTs. 1200d F. max on hard pulls use Tow/Haul
'05 2500 4x4 QC LB SLT NV5600 STOCK How in the HELL did we go from $1.40 gal diesel 2000 to $4.70 gal 2008? 2010$ comparison. GREED + BREEDING the consumer
#4 (permalink) |
this might not be a necessity but if your truck was built with the 3.73 ring & pinions, maybe look at swapping them for something a little bigger if you continue to haul with 37's, that will help relieve some stress off the drive train as well.
'03 3500 QC SB, TST, BD Super B, Optix Gauges, NV4500 with Valair parts, AD 150, 6" Superlift, 20" DC-1's in 35x13.50 ProComp X-AT's, Custom stereo with JL & Alpine, ST to SLT conversion, '03 Caravelle 232 Interceptor (other money pit!) OIF II Combat Vet |
#5 (permalink) |
You Should have no major issues... In the future i would recommend installing a new gear set.
2004.5 Ram 2500 4x4 5.9L Cummins to a NV5600... ARP Studs, Ported & Polished Head, Oversized Valves, Phat-Shaft Turbo, BD Injectors, FASS Platinum, Edge, Afe, Auto Meter Gauges, leveled on 35" Toyo's |
#6 (permalink) |
I have a manual trans and a few hop up parts, but I have no problem towing those same loads with a 6" lift on 37's, but I am switching to those same tires you have shortly because these mud terrains make me unhappy towing a lot at highway speeds, they are just pretty loud...
But I agree when I switch the Banks back to stock the truck feels slugish, but it can still get you where your going. I would sugest a few of the normal base power mods (intake exhaust, chip, gauges, and etc.) to help you out, and you may want to address any tranny weeknesses...
John P. - 2007 2500 SLT, QC, 4X4, 5.9 CTD, G56 6spd w/SBC DD clutch, 6" BDS lift, 37" VorTrac's, Banks 6 gun w/SL and PDA, Airaid MIT intake, CFM+ manifold, MBRP exhaust, and Amsoil fuilds |
#7 (permalink) |
Great info guys I apprec. I will prob only tow the 12v to a few races, a few hours away, a couple times a year. Other then that I just drive it to work etc. Truck runs good with the edge, exhaust, intake, intake manifold right now just was worried about the trans being ok with that rubber and load. Going to order a deeper pan pretty soon. Thanks again!
#8 (permalink) | |
2006 dodge 5.9 - matte blk - BD PMT w/ CL - MHT 18''wheel wrap w/ Toyo AT's 355/65-18 - 6'' lift - silverline5'' TBE - sb horn and CAI - fs2500 on 48re and 5.9 - and some more stuff.............. |
#9 (permalink) |
![]() Join Date: Nov 2009
I tow more weight than that all the time. You should have no issues what so ever.
What I have found helped the most for the tranny was the lock up switch. When it gets to 2nd lock it, unlock then put it in 3rd(drive with t/h), then after you get to 60-70 you can put it in OD with that weight.. On longer hills you may want to put it back into 3rd. just watch the EGTs you will be fine.
04.5 QCSB GARMON fat shaft 48RE- 6" superlift, 37" Toyo M/T, XD Monsters, Super B Special/ S480 race cover, ATS twin pumps, Wicked 150's, ARP, Edge, SMARTY TNT/R, Air Dog 150, Rail/fuel/EGT/boost/throttle%/load% gauges, 6" MBRP stacks, 12k# smittybuilt Engine built by: Diesel Diagnostics Injection by: Wicked Diesel 12.6 @ 110mph |
#10 (permalink) |
Sounds good again I really apprec it. I sure didnt want to buy smaller tires and other rims just to tow a few times a year. Rather spend that money on a converter and valvebody.
#12 (permalink) |
Thanks brother
