| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#25 (permalink) | |
2006 3500 Black Sport QC 4x4 G56 dually, Amsoil in everything w/bypass,SB CON OFE,Mag-Hytec on rear, pyro boost & rear diff temp gauges, AeroTurbine 4040, high idle, K&N cold air w/EaAU 4095, QUAD boost fooler, Rancho RS5K's, DS predator/puck, :
#27 (permalink) |
Glad to be of help.
06 48RE megacab, not cummings equipped but Cummins powered. Edge Juice/Attitude, mod'd intank fuel pump, Fleetguard FS20000 fuel filter and external lift pump regulator, modified intake housing, Goerend tranny/billet input, GDP intake horn. |
#28 (permalink) |
cj42 your rattle would most likely get worse by switching to F1s. larger injectors advance timing. what are you running for electronics?
'03 3500 4wd- HTS Billet Trans, Stage 4 CP3, SB66, TST, Smarty, F1 Flux 4's, Custom Paint '95 2500 2wd - Regular Cab, Short Bed - Garmon Billet Trans - Needs Sponsored! |
#29 (permalink) |
NADM Advisory
I know this post is quite old but, lets see if anyone if still around... You know... I thought you had something here for a little while ![]() My rattle isn't at idle like yours and I'm having a heck of a time figuring it out. I found your post and thought cool it makes sense. But then I got to thinking, my second CP3 is belt driven so there's no way you could adjust the timing on it. It's just a pump being driven by the engine. I asked around and others agreed that by moving the CP3 gear will do nothing. It's just a gear linked to the cam shaft which drives it. If you rotate the gear or pump shaft on the CP3.... it doesn't move anything. It would be like rotating the spocket on a bicycle. I'm not trying to down play what you did here, I just had to question whether it really does anything or not before I went through the trouble. You said it helped your knock so I gotta wonder ??
www.BlackPatchDiesel.com
Garmon Diesel / Airwerks / High Tech Turbo AirDog / Glacier Diesel / NADM / XSPower |
#30 (permalink) |
WICKED DIESELS
![]() Join Date: Dec 2006
No BS, it works, our 05, sounded like it was going to fly apart. I pulled the CP3, when I put it back on the sound was gone. The gear driven pump, will end up in the same place every revoluton.
http://www.wickeddiesels.com http://www.modifiedcp3.com Compound Turbo Kits S300/S400 Singles CP3's and mods Injectors Fuel Systems Coolant Bypass Kits Bosch Parts
#31 (permalink) |
NADM Advisory
I may try it to see what happens. There's so many variables to where the rattle could be coming from... have to look at the all. You would think though, if it did need to be in time with the engine, there'd be timing marks to line up ??
#32 (permalink) |
![]() Join Date: Sep 2006
i talked to a diesel mechanic about doing this because i had planned on doing it. like what triton had said, he said he didnt think it would resolve the problem either. i have yet to try for myself, but am very curious. plus i have been without my truck for the last month.
Silver 2005 Dodge Ram 2500 4x4, muffler delete and chrome side molding. Theres no "G" in Cummins, hole!
#33 (permalink) |
WICKED DIESELS
First of all it is not "timing, as you normally think of it" as the engine crankshaft rotates, so does the injection pump, they, by having gears of an equally dividable number of teeth, end up in the same location on each power stroke. It is the relationship between the particular cycle of the injection pump, versus where the piston in the engine is located, like nearing TDC on overlap, where there is little loading. It is easiest explained, much like lugging your manual trans in too high of a gear, the noise you hear is called gear clash. This is much the same as some of the engine noises on common rails due to the same type of cycling sound. If there is a condition of negative crankshaft load, or gear driven high pressure pump backlash, this can be transmitted through the engine and sound like an injector knock. Is this the answer to what everyone is experiencing, who knows. It has worked on several trucks that we have had the CP3 off of, it has also been a recommended repair to some, who have had success and eliminated the knocking sound.
#34 (permalink) |
The gear train noise is very different from the average fuel knock, if you have heard it, its easily distinguisheable from most other noises these engines make. The previous post is correct also, its not fuel timing but gear timing and backlash thats causes the knock.
#35 (permalink) |
im curious as to what this noise sounds like, i got a rattle/ticking/knocking, noticible around 1000-1500 rpm's, and taking off very slowly under 30mph? the dealer said it was nothing to worry about, but they still wanted 45bucks to look at it..any help
04.5 HO edge jammer turbo, magnasuck muffler, homemade 4" intake w/ amsoil filter. PPE programemr
#36 (permalink) |
My truck has more of a rattle at cruising speeds which dissapears instantly when I mash it. It sounds like the valve train suddenly being muted or something. Is this the knock you are talking about?
2007 5.9 h/o, 4x4 Big Horn, Quad Cab 2500, 6 speed manual,FLAME RED! STR8 piped and lovin it! Silencer Ring mia |
