Adjust bands on 48RE - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 12-31-2009, 07:37 PM Thread Starter
CF Chapter President
dieselenthusiast's Avatar
The owners manual says to adjust the bands when changing the transmission fluid. What are bands and what are their purpose? And I was wondering how important it is to have them adjusted?
SOLD - 2006/5.9 Cummins/Big Horn/2500/QCSB/4X4/48RE
2015/3.0 Ecodiesel/Big Horn/1500/QCSB/4x4/8HP70
2016/Travel Trailer/Arctic Fox 22G/LP Cummins Onan Generator/160 Watt Solar Panel
dieselenthusiast is offline
post #2 of 7 (permalink) Old 12-31-2009, 09:32 PM
davewright92's Avatar
The information on this website can be overwhelming. I've seen a thread on here somewhere which discusses the answers to your questions. You can do a search and you'll probably find it before I do. I'm looking for it for myself and when I find it I'll post a link or something. I'm not technically saavy on the transmission, but as I understand it (in simple terms) the bands are part of the operation in transferring the power from the go pedal. Than can come out of adjustment over time and when they do the trans will shift sloppier or looser. I need to adjust mine which I'll be doing this weekend -- maybe.
Dave
2006 2500 Laramie 4x4 - K&N Filter, Edge Juice w/Attitude, Aero Turbine 4040, AirDog II, Pusher, Load Lifter 5000, Daystar, DPC Super Single.
davewright92 is offline
post #3 of 7 (permalink) Old 01-01-2010, 12:17 AM
Go about half way down this thread, this will show you what is involved. If you don't have an inch lbs torque wrench get one.
48re band adjustment
07 3500 MegaCab 5.9,CAI,BMS 50hp inj,SpoolAid,AFE3.5" intake,AFE SS exh,Snow stage 3,smarty SSR UDC
3"lift,5"dual exhaust,Wicked Wheel,BD Triple disc,Billet shafts,BD stage 4,DNJ,BD VB,DD pan,Fass150,8an line,Twin fuel filters,Traction bars.
Smoksho is offline
The Following 4 Users Say Thank You to Smoksho For This Useful Post:
dbcooper (03-09-2011), dieselenthusiast (01-01-2010), JPW (12-09-2010), red796 (04-25-2010)
post #4 of 7 (permalink) Old 01-01-2010, 12:39 PM
NavyDood's Avatar
If you aren't having any underlying issues, don't adjust it. If there is a shifting issue and the diagnosis leads to a band adjustment then they should be adjusted. Doing a band adjustment just for the sake of doing it is not needed.
Retired Navy Chief - Vanilla 04 2500 QCSB, 4x4, 48RE w/MagHytec DD, Smarty Jr, HOG 4" Exh, Modded Air Box, Isspro Gauges, Quadzilla RPG w/fuel pressure, DynaTrac front, Coolant By-Pass Filter - B&W Turnoverball w/Companion 5vr hitch
NavyDood is offline
The Following User Says Thank You to NavyDood For This Useful Post:
b wojo (05-01-2015)
post #5 of 7 (permalink) Old 01-01-2010, 12:56 PM Thread Starter
I have 55,000 miles on the truck and I havenít noticed any shifting concerns. It kind of shifts hard into second, but it has always done that since I bought it.
post #6 of 7 (permalink) Old 01-01-2010, 02:43 PM
NavyDood's Avatar
I have 125,000 miles on mine. The only thing I have done is 3 fluid/filter changes. I am due for another fluid/filter change.
NavyDood is offline
post #7 of 7 (permalink) Old 01-01-2010, 02:49 PM
mmerz's Avatar
48re Diagnosis Charts
Diagnosis Charts
CONDITION POSSIBLE CAUSES CORRECTION
HARSH ENGAGEMENT
(FROM NEUTRAL TO
DRIVE OR REVERSE)
1. Fluid Level Low. 1. Add Fluid
2. Throttle Linkage Mis-adjusted.
V-10 Only
2. Adjust linkage - setting may be too long.
3. Mount and Driveline Bolts Loose. 3. Check engine mount, transmission
mount, propeller shaft, rear spring to body
bolts, rear control arms, crossmember and
axle bolt torque. Tighten loose bolts and
replace missing bolts.
4. U-Joint Worn/Broken. 4. Remove propeller shaft and replace
U-Joint.
5. Axle Backlash Incorrect. 5. Check per Service Manual. Correct as
needed.
6. Hydraulic Pressure Incorrect. 6. Check pressure. Remove, overhaul or
adjust valve body as needed.
7. Band Mis-adjusted. 7. Adjust rear band.
8. Valve Body Check Balls Missing. 8. Inspect valve body for proper check ball
installation.
9. Axle Pinion Flange Loose. 9. Replace nut and check pinion threads
before installing new nut. Replace pinion
gear if threads are damaged.
10. Clutch, band or planetary
component damaged.
10. Remove, disassemble and repair
transmission as necessary.
11. Converter Clutch Faulty. 11. Replace converter and flush cooler and
line before installing new converter.
DR AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION 21 - 1283
DELAYED ENGAGEMENT
(FROM NEUTRAL TO
DRIVE OR REVERSE)
1. Fluid Level Low. 1. Correct level and check for leaks.
2. Filter Clogged. 2. Change filter.
3. Gearshift Linkage Mis-adjusted. 3. Adjust linkage and repair linkage if worn
or damaged.
4. Torque Converter Drain Back (Oil
drains from torque converter into
transmission sump).
4. If vehicle moves normally after 5
seconds after shifting into gear, no repair is
necessary. If longer, inspect pump bushing
for wear. Replace pump house.
5. Rear Band Mis-adjusted. 5. Adjust band.
6. Valve Body Filter Plugged. 6. Replace fluid and filter. If oil pan and old
fluid were full of clutch disc material and/or
metal particles, overhaul will be necessary.
7. Oil Pump Gears Worn/Damaged. 7. Remove transmission and replace oil
pump.
8. Governor Circuit and Solenoid
Valve Electrical Fault.
8. Test with DRBT scan tool and repair as
required.
9. Hydraulic Pressure Incorrect. 9. Perform pressure test, remove
transmission and repair as needed.
10. Reaction Shaft Seal Rings
Worn/Broken.
10. Remove transmission, remove oil pump
and replace seal rings.
11. Rear Clutch/Input Shaft, Rear
Clutch Seal Rings Damaged.
11. Remove and disassemble transmission
and repair as necessary.
12. Regulator Valve Stuck. 12. Clean.
13. Cooler Plugged. 13. Transfer case failure can plug cooler.
NO DRIVE RANGE
(REVERSE OK)
1. Fluid Level Low. 1. Add fluid and check for leaks if drive is
restored.
2. Gearshift Linkage/Cable
Loose/Misadjusted.
2. Repair or replace linkage components.
3. Rear Clutch Burnt. 3. Remove and disassemble transmission
and rear clutch and seals. Repair/replace
worn or damaged parts as needed.
4. Valve Body Malfunction. 4. Remove and disassemble valve body.
Replace assembly if any valves or bores
are damaged.
5. Transmission Overrunning Clutch
Broken.
5. Remove and disassemble transmission.
Replace overrunning clutch.
6. Input Shaft Seal Rings Worn/
Damaged.
6. Remove and disassemble transmission.
Replace seal rings and any other worn or
damaged parts.
7. Front Planetary Failed Broken. 7. Remove and repair.
21 - 1284 AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION DR
NO DRIVE OR REVERSE
(VEHICLE WILL NOT
MOVE)
restored.
Loose/Misadjusted.
2. Inspect, adjust and reassemble linkage
as needed. Replace worn/damaged parts.
3. U-Joint/Axle/Transfer Case
Broken.
3. Perform preliminary inspection procedure
for vehicle that will not move. Refer to
procedure in diagnosis section.
4. Filter Plugged. 4. Remove and disassemble transmission.
Repair or replace failed components as
needed. Replace filter. If filter and fluid
contained clutch material or metal particles,
an overhaul may be necessary. Perform
lube flow test. Flush oil. Replace cooler as
necessary.
5. Oil Pump Damaged. 5. Perform pressure test to confirm low
pressure. Replace pump body assembly if
necessary.
6. Valve Body Malfunctioned. 6. Check and inspect valve body. Replace
valve body (as assembly) if any valve or
bore is damaged. Clean and reassemble
correctly if all parts are in good condition.
7. Transmission Internal Component
Damaged.
7. Remove and disassemble transmission.
needed.
8. Park Sprag not Releasing - Check
Stall Speed, Worn/Damaged/Stuck.
8. Remove, disassemble, repair.
9. Torque Converter Damage. 9. Inspect and replace as required.
SHIFTS DELAYED OR
ERRATIC (SHIFTS ALSO
HARSH AT TIMES)
1. Fluid Level Low/High. 1. Correct fluid level and check for leaks if
low.
2. Fluid Filter Clogged. 2. Replace filter. If filter and fluid contained
clutch material or metal particles, an
overhaul may be necessary. Perform lube
flow test.
3. Throttle Linkage Mis-adjusted.
V-10 Only
3. Adjust linkage as described in service
section.
4. Throttle Linkage Binding. V-10
Only
4. Check cable for binding. Check for return
to closed throttle at transmission.
5. Gearshift Linkage/Cable
Mis-adjusted.
5. Adjust linkage/cable as described in
service section.
6. Clutch or Servo Failure. 6. Remove valve body and air test clutch,
and band servo operation. Disassemble
and repair transmission as needed.
7. Governor Circuit Electrical Fault. 7. Test using DRBT scan tool and repair as
required.
8. Front Band Mis-adjusted. 8. Adjust band.
9. Pump Suction Passage Leak. 9. Check for excessive foam on dipstick
after normal driving. Check for loose pump
bolts, defective gasket. Replace pump
assembly if needed.
DR AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION 21 - 1285
NO REVERSE (D RANGES
OK)
1. Gearshift Linkage/Cable
Mis-adjusted/Damaged.
1. Repair or replace linkage parts as
needed.
2. Park Sprag Sticking. 2. Replace overdrive annulus gear.
3. Rear Band Mis-adjusted/Worn. 3. Adjust band; replace.
4. Valve Body Malfunction. 4. Remove and service valve body. Replace
valve body if any valves or valve bores are
worn or damaged.
5. Rear Servo Malfunction. 5. Remove and disassemble transmission.
Replace worn/damaged servo parts as
necessary.
6. Direct Clutch in Overdrive Worn. 6. Disassemble overdrive. Replace worn or
damaged parts.
7. Front Clutch Burnt. 7. Remove and disassemble transmission.
Replace worn, damaged clutch parts as
required.
HAS FIRST/REVERSE
ONLY (NO 1-2 OR 2-3
UPSHIFT)
1. Governor Circuit Electrical Fault. 1. Test using DRBT scan tool and repair as
required.
2. Valve Body Malfunction. 2. Repair stuck 1-2 shift valve or governor
plug.
3. Front Servo/Kickdown Band
Damaged/Burned.
3. Repair/replace.
MOVES IN 2ND OR 3RD
GEAR, ABRUPTLY
DOWNSHIFTS TO LOW
1. Valve Body Malfunction. 1. Remove, clean and inspect. Look for
stuck 1-2 valve or governor plug.
NO LOW GEAR (MOVES
IN 2ND OR 3RD GEAR
ONLY)
1. Governor Circuit Electrical Fault. 1. Test with DRBT scan tool and repair as
required.
2. Valve Body Malfunction. 2. Remove, clean and inspect. Look for
sticking 1-2 shift valve, 2-3 shift valve,
governor plug or broken springs.
3. Front Servo Piston ed in
Bore.
3. Inspect servo and repair as required.
4. Front Band Linkage Malfunction 4. Inspect linkage and look for bind in
linkage.
21 - 1286 AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION DR
NO KICKDOWN OR
NORMAL DOWNSHIFT
1. Throttle Linkage Mis-adjusted.
V-10 Only
1. Adjust linkage.
2. Accelerator Pedal Travel
Restricted.
2. Verify floor mat is not under pedal, repair
worn accelerator cable or bent brackets.
3. Valve Body Hydraulic Pressures
Too High or Too Low Due to Valve
Body Malfunction or Incorrect
Hydraulic Control Pressure
Adjustments.
3. Perform hydraulic pressure tests to
determine cause and repair as required.
Correct valve body pressure adjustments as
required.
4. Governor Circuit Electrical Fault. 4. Test with DRBT scan tool and repair as
required.
5. Valve Body Malfunction. 5. Perform hydraulic pressure tests to
required.
6. TPS Malfunction. 6. Replace sensor, check with DRBT scan
tool.
7. PCM Malfunction. 7. Check with DRBT scan tool and replace
if required.
8. Valve Body Malfunction. 8. Repair sticking 1-2, 2-3 shift valves,
governor plugs, 3-4 solenoid, 3-4 shift
valve, 3-4 timing valve.
STUCK IN LOW GEAR
(WILL NOT UPSHIFT)
1. Throttle Linkage Mis-adjusted/
Stuck. V-10 Only
1. Adjust linkage and repair linkage if worn
or damaged. Check for binding cable or
missing return spring.
2. Gearshift Linkage Mis-adjusted. 2. Adjust linkage and repair linkage if worn
or damaged.
3. Governor Component Electrical
Fault.
3. Check operating pressures and test with
DRBT scan tool, repair faulty component.
4. Front Band Out of Adjustment. 4. Adjust Band.
5. Clutch or Servo Malfunction. 5. Air pressure check operation of clutches
and bands. Repair faulty component.
CREEPS IN NEUTRAL 1. Gearshift Linkage Mis-adjusted. 1. Adjust linkage.
2. Rear Clutch Dragging/Warped. 2. Disassemble and repair.
3. Valve Body Malfunction. 3. Perform hydraulic pressure test to
BUZZING NOISE 1. Fluid Level Low 1. Add fluid and check for leaks.
2. Shift Cable Mis-assembled. 2. Route cable away from engine and bell
housing.
3. Valve Body Mis-assembled. 3. Remove, disassemble, inspect valve
body. Reassemble correctly if necessary.
Replace assembly if valves or springs are
damaged. Check for loose bolts or screws.
4. Pump Passages Leaking. 4. Check pump for porous casting, scores
on mating surfaces and excess rotor
clearance. Repair as required. Loose pump
bolts.
5. Cooling System Cooler Plugged. 5. Flow check cooler circuit. Repair as
needed.
6. Overrunning Clutch Damaged. 6. Replace clutch.
DR AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION 21 - 1287
SLIPS IN REVERSE ONLY
1. Fluid Level Low. 1. Add fluid and check for leaks.
2. Gearshift Linkage Mis-adjusted. 2. Adjust linkage.
3. Rear Band Mis-adjusted. 3. Adjust band.
4. Rear Band Worn. 4. Replace as required.
5. Overdrive Direct Clutch Worn. 5. Disassemble overdrive. Repair as
needed.
6. Hydraulic Pressure Too Low. 6. Perform hydraulic pressure tests to
determine cause.
7. Rear Servo Leaking. 7. Air pressure check clutch-servo operation
8. Band Linkage Binding. 8. Inspect and repair as required.
SLIPS IN FORWARD
DRIVE RANGES
2. Fluid Foaming. 2. Check for high oil level, bad pump
gasket or seals, dirt between pump halves
and loose pump bolts. Replace pump if
necessary.
V-10 Only
3. Adjust linkage.
4. Gearshift Linkage Mis-adjusted. 4. Adjust linkage.
5. Rear Clutch Worn. 5. Inspect and replace as needed.
6. Low Hydraulic Pressure Due to
Worn Pump, Incorrect Control
Pressure Adjustments, Valve Body
Warpage or Malfunction, Sticking,
Leaking Seal Rings, Clutch Seals
Leaking, Servo Leaks, Clogged Filter
or Cooler Lines.
6. Perform hydraulic and air pressure tests
to determine cause.
7. Rear Clutch Malfunction, Leaking
Seals or Worn Plates.
8. Overrunning Clutch Worn, Not
Holding (Slips in 1 Only).
8. Replace Clutch.
SLIPS IN LOW GEAR 9D9
ONLY, BUT NOT IN
MANUAL 1 POSITION
Overrunning Clutch Faulty. Replace overrunning clutch.
GROWLING, GRATING OR
SCRAPING NOISES
1. Drive Plate Broken. 1. Replace.
2. Torque Converter Bolts Hitting
Dust Shield.
2. Dust shield bent. Replace or repair.
3. Planetary Gear Set Broken/
Seized.
3. Check for debris in oil pan and repair as
required.
4. Overrunning Clutch Worn/Broken. 4. Inspect and check for debris in oil pan.
Repair as required.
5. Oil Pump Components Scored/
Binding.
5. Remove, inspect and repair as required.
6. Output Shaft Bearing or Bushing
Damaged.
6. Remove, inspect and repair as required.
7. Clutch Operation Faulty. 7. Perform air pressure check and repair as
required.
8. Front and Rear Bands Misadjusted.
8. Adjust bands.
21 - 1288 AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION DR
DRAGS OR LOCKS UP
1. Fluid Level Low. 1. Check and adjust level.
2. Clutch Dragging/Failed 2. Air pressure check clutch operation and
repair as required.
3. Front or Rear Band Mis-adjusted. 3. Adjust bands.
4. Case Leaks Internally. 4. Check for leakage between passages in
case.
5. Servo Band or Linkage
Malfunction.
5. Air pressure check servo operation and
repair as required.
6. Overrunning Clutch Worn. 6. Remove and inspect clutch. Repair as
required.
7. Planetary Gears Broken. 7. Remove, inspect and repair as required
(look for debris in oil pan).
8. Converter Clutch Dragging. 8. Check for plugged cooler. Perform flow
check. Inspect pump for excessive side
clearance. Replace pump as required.
NO 4-3 DOWNSHIFT 1. Circuit Wiring and/or Connectors
Shorted.
1. Test wiring and connectors with test lamp
and volt/ohmmeter. Repair wiring as
necessary. Replace connectors and/or
harnesses as required.
2. PCM Malfunction. 2. Check PCM operation with DRBT scan
tool. Replace PCM only if faulty.
3. TPS Malfunction 3. Check TPS with DRBT scan tool at PCM.
4. Lockup Solenoid Not Venting. 4. Remove valve body and replace solenoid
assembly if plugged or shorted.
5. Overdrive Solenoid Not Venting. 5. Remove valve body and replace solenoid
6. Valve Body Valve Sticking. 6. Repair stuck 3-4 shift valve or lockup
timing valve.
NO 4-3 DOWNSHIFT
WHEN CONTROL SWITCH
IS TURNED OFF
1. Control Switch Open/Shorted. 1. Test and replace switch if faulty.
2. Overdrive Solenoid Connector
Shorted.
2. Test solenoids and replace if seized or
shorted.
3. PCM Malfunction. 3. Test with DRBT scan tool. Replace PCM
if faulty.
4. Valve Body Stuck Valves. 4. Repair stuck 3-4, lockup or lockup timing
valve.
CLUNK NOISE FROM
DRIVELINE ON CLOSED
THROTTLE 4-3
DOWNSHIFT
1. Transmission Fluid Low. 1. Add Fluid.
2. Throttle Cable Mis-adjusted. V-10
Only
2. Adjust cable.
3. Overdrive Clutch Select Spacer
Wrong Spacer.
3. Replace overdrive piston thrust plate
spacer.
DR AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION 21 - 1289
3-4 UPSHIFT OCCURS
IMMEDIATELY AFTER 2-3
SHIFT
1. Overdrive Solenoid Connector or
Wiring Shorted.
1. Test connector and wiring for loose
connections, shorts or ground and repair as
needed.
2. TPS Malfunction. 2. Test TPS and replace as necessary.
Check with DRBT scan tool.
3. PCM Malfunction. 3. Test PCM with DRBT scan tool and
replace controller if faulty.
4. Overdrive Solenoid Malfunction. 4. Replace solenoid.
5. Valve Body Malfunction. 5. Remove, disassemble, clean and inspect
valve body components. Make sure all
valves and plugs slide freely in bores.
Polish valves with crocus cloth if needed.
WHINE/NOISE RELATED
TO ENGINE SPEED
2. Shift Cable Incorrect Routing. 2. Check shift cable for correct routing.
Should not touch engine or bell housing.
NO 3-4 UPSHIFT 1. O/D Switch In OFF Position. 1. Turn control switch to ON position.
2. Overdrive Circuit Fuse Blown. 2. Replace fuse. Determine why fuse failed
and repair as necessary (i.e., shorts or
grounds in circuit).
3. O/D Switch Wire Shorted/Open
Cut.
3. Check wires/connections with 12V test
lamp and voltmeter. Repair damaged or
loose wire/connection as necessary.
4. Distance or Coolant Sensor
Malfunction.
4. Check with DRBT scan tool and repair or
5. TPS Malfunction. 5. Check with DRBT scan tool and replace
if necessary.
6. Neutral Sense to PCM Wire
Shorted/Cut.
6. Test switch/sensor as described in
service section and replace if necessary.
Engine no start.
if necessary.
8. Overdrive Solenoid Shorted/Open. 8. Replace solenoid if shorted or open and
repair loose or damaged wires (DRBT scan
tool).
9. Solenoid Feed Orifice in Valve
Body Blocked.
9. Remove, disassemble, and clean valve
body thoroughly. Check feed orifice.
10. Overdrive Clutch Failed. 10. Disassemble overdrive and repair as
needed.
11. Hydraulic Pressure Low. 11. Pressure test transmission to determine
cause.
12. Valve Body Valve Stuck. 12. Repair stuck 3-4 shift valve, 3-4 timing
valve.
13. O/D Piston Incorrect Spacer. 13. Remove unit, check end play and install
correct spacer.
14. Overdrive Piston Seal Failure. 14. Replace both seals.
15. O/D Check Valve/Orifice Failed. 15. Check for free movement and secure
assembly (in piston retainer). Check ball
bleed orifice.
21 - 1290 AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION DR
SLIPS IN OVERDRIVE
FOURTH GEAR
2. Overdrive Clutch Pack Worn. 2. Remove overdrive unit and rebuild clutch
pack.
3. Overdrive Piston Retainer Bleed
Orifice Blown Out.
3. Disassemble transmission, remove
retainer and replace orifice.
4. Overdrive Piston or Seal
Malfunction.
4. Remove overdrive unit. Replace seals if
worn. Replace piston if damaged. If piston
retainer is damaged, remove and
disassemble the transmission.
5. 3-4 Shift Valve, Timing Valve or
Accumulator Malfunction.
5. Remove and overhaul valve body.
Replace accumulator seals. Make sure all
valves operate freely in bores and do not
bind or stick. Make sure valve body screws
are correctly tightened and separator plates
are properly positioned.
6. Overdrive Unit Thrust Bearing
Failure.
6. Disassemble overdrive unit and replace
thrust bearing (NO. 1 thrust bearing is
between overdrive piston and clutch hub;
NO. 2 thrust bearing is between the
planetary gear and the direct clutch spring
plate; NO. 3 thrust bearing is between
overrunning clutch hub and output shaft).
7. O/D Check Valve/Bleed Orifice
Failure.
7. Check for function/secure orifice insert in
O/D piston retainer.
1. Fluid Level Low. 1. AddDELAYED 3-4 UPSHIFT
(SLOW TO ENGAGE fluid and check for leaks.
2. Throttle Valve Cable Mis-adjusted.
V-10 Only
2. Adjust throttle valve cable.
3. Overdrive Clutch Pack Worn/
Burnt.
3. Remove unit and rebuild clutch pack.
4. TPS Faulty. 4. Test with DRBT scan tool and replace as
necessary
5. Overdrive Clutch Bleed Orifice
Plugged.
5. Disassemble transmission and replace
orifice.
6. Overdrive Solenoid or Wiring
Shorted/Open.
6. Test solenoid and check wiring for
loose/corroded connections or shorts/
grounds. Replace solenoid if faulty and
repair wiring if necessary.
7. Overdrive Excess Clearance. 7. Remove unit. Measure end play and
select proper spacer.
8. O/D Check Valve Missing or
Stuck.
8. Check for presence of check valve.
Repair or replace as required.
TORQUE CONVERTER
LOCKS UP IN SECOND
AND/OR THIRD GEAR
Lockup Solenoid, Relay or Wiring
Shorted/Open.
Test solenoid, relay and wiring for
continuity, shorts or grounds. Replace
solenoid and relay if faulty. Repair wiring
and connectors as necessary.
HARSH 1-2, 2-3, 3-4 OR
3-2 SHIFTS
Lockup Solenoid Malfunction. Remove valve body and replace solenoid
assembly.
DR AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION 21 - 1291
NO START IN PARK OR
NEUTRAL
Mis-adjusted.
1. Adjust linkage/cable.
2. Neutral Sense Wire Open/Cut. 2. Check continuity with test lamp. Repair
as required.
3. Park/Neutral Switch, or
Transmission Range Sensor Faulty.
3. Refer to service section for test and
replacement procedure.
4. Park/Neutral Switch, or
Connection Faulty.
4. Connectors spread open. Repair.
5. Valve Body Manual Lever
Assembly Bent/Worn/Broken.
5. Inspect lever assembly and replace if
damaged.
NO REVERSE (OR SLIPS
IN REVERSE)
1. Direct Clutch Pack (front clutch)
Worn.
1. Disassemble unit and rebuild clutch
pack.
2. Rear Band Mis-adjusted. 2. Adjust band.
3. Front Clutch Malfunctioned/
Burned.
3. Air-pressure test clutch operation.
Remove and rebuild if necessary.
4. Overdrive Thrust Bearing Failure. 4. Disassemble geartrain and replace
bearings.
5. Direct Clutch Spring Collapsed/
Broken.
5. Remove and disassemble unit. Check
clutch position and replace spring.
21 - 1292 AUTOMATIC TRANSMISSION - 48RE - SERVICE INFORMATION DR
OIL LEAKS.
1. Fluid Lines and Fittings Loose/
Leaks/Damaged.
1. Tighten fittings. If leaks persist, replace
fittings and lines if necessary.
2. Fill Tube (where tube enters case)
Leaks/Damaged.
2. Replace tube seal. Inspect tube for
cracks in fill tube.
3. Pressure Port Plug Loose
Loose/Damaged.
3. Tighten to correct torque. Replace plug
or reseal if leak persists.
4. Pan Gasket Leaks. 4. Tighten pan screws (150 in. lbs.). If leaks
persist, replace gasket.
5. Valve Body Manual Lever Shaft
Seal Leaks/Worn.
5. Replace shaft seal.
6. Rear Bearing Access Plate Leaks. 6. Replace gasket. Tighten screws.
7. Gasket Damaged or Bolts are
Loose.
7. Replace bolts or gasket or tighten both.
8. Adapter/Extension Gasket
Damaged Leaks/Damaged.
8. Replace gasket.
9. Park/Neutral Switch, or
Leaks/Damaged.
9. Replace switch and gasket.
10. Converter Housing Area Leaks. 10. Check for leaks at seal caused by worn
seal or burr on converter hub (cutting seal),
worn bushing, missing oil return, oil in front
pump housing or hole plugged. Check for
leaks past O-ring seal on pump or past
pump-to-case bolts; pump housing porous,
oil coming out vent due to overfill or leak
past front band shaft access plug.
11. Pump Seal Leaks/Worn/
Damaged.
11. Replace seal.
12. Torque Converter Weld
Leak/Cracked Hub.
12. Replace converter.
13. Case Porosity Leaks. 13. Replace case.
NOISY OPERATION IN
FOURTH GEAR ONLY
1. Overdrive Clutch Discs, Plates or
Snap Rings Damaged.
1. Remove unit and rebuild clutch pack.
2. Overdrive Piston or Planetary
Thrust Bearing Damaged.
2. Remove and disassemble unit. Replace
either thrust bearing if damaged.
3. Output Shaft Bearings Scored/
Damaged.
3. Remove and disassemble unit. Replace
either bearing if damaged.
4. Planetary Gears Worn/Chipped. 4. Remove and overhaul overdrive unit.
5. Overdrive Unit Overrunning Clutch
Rollers Worn/Scored.
5. Remove and overhaul overdrive unit.
06 2500 Megacab4x4,4"custom BallisticFab lift,SuperB,SpynTecFreeSpin,PATC L5 billet tranny,4.56,GearVendor,SmartyPOD,II100hp,Boost&Pyr o,Volant intake,4" Exhaust-cat,wife calls it "The Money Pit"
mmerz is offline
The Following 8 Users Say Thank You to mmerz For This Useful Post:
AZkcar135 (02-16-2011), Blazex32 (06-14-2014), CAFyrman (01-01-2010), dbcooper (03-09-2011), JPW (12-09-2010), Mccraw82 (07-07-2010), tlparadis (09-25-2010), vtxcummins (03-10-2014)
