NV 5600 Oil - Dodge Cummins Diesel Forum
post #1 of 43 (permalink) Old 12-29-2009, 11:32 PM Thread Starter
layneb's Avatar
NV 5600 Oil
I was wondering what type of oil I should use in my 5600? Ive seen syncromess on here but were can i get it? And how many quarts does the 5600 hold? Thanks in advance.
2010 CCSB, g56, 2" HBS, Smarty Jr,Deleted
layneb is offline
post #2 of 43 (permalink) Old 12-30-2009, 12:19 AM
LR11's Avatar
I use Amsoil mtf, others have used redline and RP. You can order direct from amsoil I don't know about the others.
05 hd 25 laramie 6sp and still stock
LR11 is offline
post #3 of 43 (permalink) Old 12-30-2009, 02:36 AM
TECH SPECIALIST
steelhead01's Avatar
search the forum for NV5600
you can buy the Dodge/Citgo synthetic special stuff at $25 a qt.
or
I run 5 qts of Redline MTL and 2 qts of MT-90 with 2 PTO coolers on, have to dump the last 2 qts thru the top shift cover hole.
part it on a side hill with fill hole up the hill, can get 5 qts in then. 4 is not enough for proper gear lube and cooling.
5600 runs hot especially towing heavy.
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
post #4 of 43 (permalink) Old 12-30-2009, 08:52 AM
I also use Amsoil MTF. 6 quarts by filling through the top PTO cover bolt hole. Need a small gear lube pump to do it.
MikeyB
MikeyB is offline
The Following User Says Thank You to MikeyB For This Useful Post:
Duluth Diesel (01-01-2010)
post #5 of 43 (permalink) Old 12-30-2009, 01:46 PM
Ram'n It's Avatar
According to a top Cummins tech, only Amsoil MTF 5w-30 and the factory Mopar stuff is what you can run. they are the only 2 that won't void warranty. 5qts is about the norm. Amsoil MTF is also rated for up to 150K per change. Take out the bottom center PTO cover bolt for draining then pull the PTO cover and suck the rest out.
03 HO, 4.5 Fabtech lift, Pro Comp M/T 35's, NV5600, All Amsoil fluids BMK-21 Bypass, Edge J/A, K&N intake with Amsoil Air filter, Banks 4" turbo back, Bak Flip bed cover, FASS 150, DDP 40's, SO6,CAUSE REAL TRUCKS DON'T HAVE SPARK PLUGS
Ram'n It is offline
The Following User Says Thank You to Ram'n It For This Useful Post:
post #6 of 43 (permalink) Old 12-31-2009, 04:13 PM Thread Starter
layneb's Avatar
How about royal purple syncromesh i can get it a napa for less than amosol, and i dont have to pay shipping.
layneb is offline
post #7 of 43 (permalink) Old 12-31-2009, 04:25 PM
big-c's Avatar
any 75 w90 synthetic will do for the rear ends and atf+4 in auto tranny synchro in nv 5600
:2003 3500 ctd 4+4 6 sp tran bd td ppe programmer turbo elbow afe air new exhaust golden eye 4' turbo back free flow stainless
2009 polaris rzr
big-c is offline
post #8 of 43 (permalink) Old 12-31-2009, 04:42 PM Thread Starter
layneb's Avatar
Im not realy woried about price as much as i am avlabity has any one run royal purple.
layneb is offline
post #9 of 43 (permalink) Old 12-31-2009, 04:48 PM
Duluth Diesel's Avatar
6 quarts of AMSOIL MTF will cover ya. I also have hand pumps for getting the fluid up in there if you're interested.
-Chuck
Duluth Diesel is offline
post #10 of 43 (permalink) Old 12-31-2009, 07:13 PM
Ram'n It's Avatar
I don't believe that Royal Puke oil makes a MTF 5w-30. Again only Amsoil and Mopar are the only 2 that I'm aware of that makes a fluid for the nv5600.
Ram'n It is offline
post #11 of 43 (permalink) Old 12-31-2009, 11:48 PM
LR11's Avatar
I tried the RP before, I will not go back, My tranny shifts smoother with amsoil than it did with RP. Go ahead and give it a try if you want, some people have had good luck others don't, I am one that will not go back. The RP seemed thinner in weight.
LR11 is offline
The Following User Says Thank You to LR11 For This Useful Post:
post #12 of 43 (permalink) Old 01-01-2010, 07:33 AM
Anthony C's Avatar
I have Castrol SAE 75W90 Synthetic gear oil, would that be a problem. If the OEM is GL5 then it doesn't make a difference. I didn't use the Castrol yet!
I had an F350 FORD with a 5sd standard transmission, and 460 gas motor. The transmission used automatic transmission fluid!!! I was like, WOW!
2005 Dodge Ram 5.9 CTD 4X4 6Spd NV 5600 373 Ratios. Spyn Tec Lockout Hubs. Carli Ball Joints, Control Arms, and Track Bar. 285/70R17E Nitto TG. Complete Banks Power Pack System, cold air intake with scoop. 5" Magnaflow Turbo Back Exhaust.
"TAKE IT EASY WHILE YOU'RE GOING FAST!"
Anthony C is offline
