Pac brake low hold bck - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 02-16-2017, 11:54 PM Thread Starter
allsporthines28's Avatar
Just bought an 04 and it came with a pac brake remote mounted. You can pull toggle and hear brake turn on but when slowing down it doesnt seem to hold the truck back at all. What could cause this?
2000 Quad Cab Short Bed 2500 Auto: Weston 6x.013, borg warner S369xe, Homemade intake with AFE filter and AFE intake horn, 5in. straight pipe to homemade 6in diamond stack, Quad ADR. 1000/4k, Air Dog 150, built auto, and soon
allsporthines28 is offline
post #2 of 7 (permalink) Old 02-17-2017, 12:05 AM
KATOOM's Avatar
Remote mounted exhaust brakes are not as effective as turbo mounted. They take longer to engage due to the larger volume of space between the EB and the engine, and they dont seem to offer the same retarding power. But that said, there may be something wrong with yours and I'd suggest giving Pacbrake a call.
KATOOM is offline
post #3 of 7 (permalink) Old 02-17-2017, 12:53 AM Thread Starter
Ok. I kind of figured remote mount wouldnt be as efficient but this is no more than what not having the EB on does. Ive been in others that were much better. Ill give them a call tomorrow
post #4 of 7 (permalink) Old 02-17-2017, 07:31 AM
I have a PRXB PacBrake mounted in-line and it works just as well / the same as when I had a turbo mount. I don't notice any lag in it's operation between the two. I had to go to the in-line set up when I went to compounds. I would think something's up with your set up/install. Like you said, give PacBrake a call, their service is top notch. Good luck.
04 QCSB 4x4 auto 2500 / MBRP4"duals/HP Tuner -by Firepunk/Fass 150/ II 62/474, ARP 425's /Edge Insight CTS/ 3.5"T.G.C.lift w/steering upgrade/Red Head/ TOYO AT II's Extremes 35's/XD Revolvers 18x9/ PRXB PAC exhaust brake.
'12 TDI Jetta 6spd.
brooklyn 12 is offline
post #5 of 7 (permalink) Old 02-17-2017, 02:04 PM
I have the PRXB PacBrake that I moved from the back of the turbo down the the bottom of the downpipe. I did this when I installed my compounds and it works the same in the new location as it did hooked directly to the back of the turbo. You may have an exhaust leak between the brake and the turbo.
2006,six speed, EFI live by cummins tuner, arp head studs, banks cold air intake with ram scoop, cummins tuner he351/s475 compound, leveled, 35's, amp power steps, muffler delete, isspro ev2 fuel rail pressure, boost and pyro gauges, southbend dd 3250
06cummins1974 is offline
post #6 of 7 (permalink) Old 02-17-2017, 08:46 PM Thread Starter
Well turns out the vband where turbo and downpipe connect is leaking which is why brake is working poorly. Problem is it is so rusted on there i cant budge it
post #7 of 7 (permalink) Old 02-24-2017, 09:34 PM Thread Starter
Well for the life of me i cant get the turbo to downpipe connection to stop leaking. I have the clamp on there super tight and everything looks like it lines up finr but still leaking like crazy
