Diesel Tune Up - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 12-10-2009, 08:59 PM Thread Starter
Diesel Tune Up
I own my first 2006 dodge cummins 5.9 and was informed of a top end set only have 70000 miles should it be done.
SN 5.9 is offline
post #2 of 12 (permalink) Old 12-10-2009, 11:09 PM
04 Diesel's Avatar
No, I think it is 150,000. But some are having it done sooner.
04 Diesel is offline
post #3 of 12 (permalink) Old 12-10-2009, 11:40 PM
Pretty sure my 07 is 100k, but it never hurts to check them early
2007 5.9, 6speed, Quad Cab 4X4, Amsoil bypass system, Edelbrock Exhaust, Val Air dual disc, Dyna Trac free spin hub conversion, Dyna Trac ball joints, and more to come when the money gods allow
BigTurboCumminsTruck is offline
post #4 of 12 (permalink) Old 12-11-2009, 01:46 AM
RobertEvans's Avatar
iTrader Score: 7 reviews
sorry...can anyone elaborate?
05 2500 5.9L NV5600 4x4 QC/SB 3.73's Atlantic Blue
AFE | Smarty | Bilstein | BD | Fleece | FTE | Magnaflow
RobertEvans is offline
post #5 of 12 (permalink) Old 12-11-2009, 01:50 AM
i think they are talking about checking valve lash
04,3500,auto,silver Quad,4x4,62/475,air boss,TC rail,flux4.5,pusher,magnaflow,firepunk,Fass,gauges , mag hytec diffs and trans,air bags,amp reasearch,FF front bumper,welds,37"toyo MT,ATS flares,coolant bp,UDC,dual CP3,thuren,carli
pullinhard is offline
post #6 of 12 (permalink) Old 12-11-2009, 03:33 AM
Air cooled, Beer Fueled
S0UTS's Avatar
+1
By top end you mean head/valve work? Diesel World <- New guy to the
2006 Triumph Sprint ST ABS 1050
1985 BMW 735i Recently
the
S0UTS is offline
post #7 of 12 (permalink) Old 12-11-2009, 04:45 AM
TECH SPECIALIST
steelhead01's Avatar
depends on how it's ran. 100k miles is too long for some, too soon for many.
pulling 15k+ lb loads all the time; run hard, hot, dirty and put away hot and sweaty. I'd check every 25k>50k or sooner if the top end becomes noisy.
hwy boy toy only on pavement back and forth to office, every 150k or when the top end develops some noise.
if there is an extended warranty in effect, then per the warranty maintenance requirements.
any drastic changes (more than 0.005") in adjustment, look for a loose or worn valve seat or damaged valve face.
valve thru piston is not a fun experience but it is expensive.
: Is your kitty in place?
:You callin me a *****???
steelhead01 is offline
The Following User Says Thank You to steelhead01 For This Useful Post:
SN 5.9 (12-12-2009)
post #8 of 12 (permalink) Old 12-11-2009, 11:19 AM
thanks for the info
post #9 of 12 (permalink) Old 12-11-2009, 01:06 PM
csixer's Avatar
i did mine at about 87k and they were all out but i do alot of towing and it made a world of difference
2015 Ram 3500 Qaud cab srw longhorn, 4x4, 6.7, aisin, stock for now.
csixer is offline
post #10 of 12 (permalink) Old 12-12-2009, 06:32 PM Thread Starter
just like to say thanks to everyone for there reply.
SN 5.9 is offline
post #11 of 12 (permalink) Old 12-12-2009, 06:44 PM
SN welcome to the forum.
I pretty much go by the owners manual and mine says no need to check valve lash before 150K miles. Mine has 120K on it now, but I had the injectors replaced under warranty around 40K miles and asked the tech to run the valves (check lash) when he installed the injectors. I'll be doing it myself at 150K for peace of mind.
2014 2500 Laramie 4x4 CC Long bed black on black, 3.42 gears, 68rfe. Only mods so far are window visors and a tri-fold bed cover.
NickBeek is offline
post #12 of 12 (permalink) Old 12-13-2009, 02:42 AM
I did the valves on my '05 today (@ ~92k miles). The truck has not been used for heavy towing or hauling, but all of the valves were loose (at, or just outside the loose end of spec). So I'd probably err on the side of caution and do them sooner rather than later. It's easy and even if you take your time you can easily do it inside of two hours.
My truck idles a lot quieter now.
2005 Dodge 2500 QC SB 4x4 auto. HBS leveling kit, 35" BFGs, AMSOIL BMK-21.
pace is offline
