need diagram for 2003 5.9 ecm, connectors - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 12-10-2009, 12:25 PM Thread Starter
I need the diagram for a 2003 5.9 cummins ecm, app sensor connector end views. appreciate any help anyone can give. also any info on p2121 and p2123 codes, replaced app sensor and same codes keep getting thrown.
AUTOSOL is offline
post #2 of 3 (permalink) Old 12-10-2009, 01:44 PM
use n force's Avatar
MIL, any combination of Accelerator Pedal Position Sensor (APPS or PPS) fault codes such as P2121, P2122, P2123, P2127, P2128. The engine may intermittently loose throttle response.;There has been recent repairs or modifications to the truck. The ECM was recently replaced or The ECM was recently re-programmed with an aftermarket 'downloader' device. Verify the ECM is programmed with the correct calibration (displayed ECM part number). If the ECM is not calibrated to the correct part number, the ECM will have to be replaced and flashed with the correct calibration (ECM part number). Hope this helps you. I'll see if i can get the diagrams. Also Inspect the engine to body ground strap located between the left rear of the cylinder head and the left side of the bulk head for wire harness contact.
use n force is offline
post #3 of 3 (permalink) Old 12-10-2009, 03:51 PM Thread Starter
thanks, as far as I know there has not been any modifications on this or any aftermarket device. and appreciate the diagram if you can get it. thank you again
AUTOSOL is offline
