305hp vs. 325hp injectors? - Dodge Cummins Diesel Forum
post #1 of 25 (permalink) Old 04-26-2007, 05:36 PM Thread Starter
justinduke's Avatar
I have a 305hp truck and was wondering if injectors out of a 325hp truck will work in my truck?
2006 Auto Mega Cab 4wd
RIP - Early 2004 SRW 3500 6spd CTD 4wd
justinduke is offline
post #2 of 25 (permalink) Old 04-26-2007, 06:31 PM
bigpatten86's Avatar
as long as its a 24 valve ctd it should
1996 12v QCLB nv4500 sb3850 dd, 435 new era's, 215pump tweaked a bit, dv's, studded and o-ringed, River city 64-71-14, custom traction bars, 17 degrees of timing, 200 fass with draw straw. Homemade water meth kit. 16x10 american outlaws 305/70/16 courser m/t's
bigpatten86 is offline
post #3 of 25 (permalink) Old 04-26-2007, 06:34 PM
FHRinsp06's Avatar
So I could put the 305's in my 250?
2003 Ram 2500 -
FHRinsp06 is offline
post #4 of 25 (permalink) Old 04-26-2007, 06:39 PM
PA VP ONE TUFF O3
CTD03's Avatar
i really dont know how much this would help out but do you think 50 horse would do that much to the SO
i really aint sure i was looking into stick and if this is possible do i need to get aftermark 40hp sticks?
03 5 speed sponsors
CTD03 is offline
post #5 of 25 (permalink) Old 04-26-2007, 06:42 PM
FHRinsp06's Avatar
I dunno, I turn my predator to the 60 hp+ tow tune, and I can feel a huge difference...I happen to think the SO's are pretty respnsive to things like this.
2003 Ram 2500 -
post #6 of 25 (permalink) Old 04-26-2007, 06:45 PM
PA VP ONE TUFF O3
CTD03's Avatar
i dont know i would really like to find out becasue if so then i am going for it.
but yeah you only need like 40hp to tell a difference
03 5 speed sponsors
CTD03 is offline
post #7 of 25 (permalink) Old 04-26-2007, 07:06 PM Thread Starter
justinduke's Avatar
Anyone else want to confirm this for me?
post #8 of 25 (permalink) Old 04-26-2007, 07:10 PM
Cummins - No excuses
CumminAtcha's Avatar
As far as I know they are the exact same injectors, it is the programming that is different between the engines. You won't gain anything but anger cuz you didn't gain anything.
The factory injectors are capable of quite a bit of power over stock.
Adam -
03 3500 QC/SB 48re sold....
03 2500 NV4500 525hp/996tq 4/14/07 Totaled 12/15/07
99 F250 7.3 PSD sold early 06
CumminAtcha is offline
post #9 of 25 (permalink) Old 04-26-2007, 07:19 PM
Only in a HEMI
BBRam's Avatar
iTrader Score: 13 reviews
I dont believe they are the same.
2012 Ram 2500 5.7L HEMI
2012 Dodge Challenger SRT8 6.4L HEMI
2015 Hellcat, and ya, it's got a HEMI
BBRam is offline
post #10 of 25 (permalink) Old 04-27-2007, 12:07 AM
miwago's Avatar
I asked the shop foreman about the HO motor the other day, and he said the 305 vs the 325 HO are the same motor, tip to tail, except for the stock ECM programming. I could have mine reprogrammed per stock to a 325 HO motor for a few $$.
'03 2500 4x4 HO CTD, BOSCH +100 comp inj's, Airdog fuel prep, K&N w/ Airaid torqe tube & Banks Hi-Ram, Diablosport Predator and Power-puck 64/14 Ind. Inj. turbo, dual remote oil filter, 5" stacks & Vertical mufflers.
miwago is offline
post #11 of 25 (permalink) Old 04-27-2007, 01:08 AM
scrappy's Avatar
There are differences in the engine, the turbo, the injector tips, computer, and there are a few other things are different.
The ECM in the 305 cannot run the program from the 325 because the ECM from the 325 is bigger for emissions reasons.
the injectors should be the same between the 250 and the 305 but you won't gain anything.
The 325 uses different tips on its injectors and you cannot use the 325 tips in a 305 or the other way around. you can use the injectors from the other engine IF you change the tips to match the engine, in other words 325 injectors w/ 305 tips will work in a 305.
2012 RAM 3500 CC/LB dually, Max tow, 4.10's, Laramie Limited, sunroof, mineral gray
scrappy is offline
post #12 of 25 (permalink) Old 04-27-2007, 01:19 AM
Banned
Here's what you should do, go up to your shop foreman and kick him square in the testicles for giving you that BS answer. Many internal parts are different, the piston bowls are larger and non re-entrant, the injectors have 5-holes instead of 8-holes, different turbocharger, different injection pulse, and also the before mentioned ECM parameters. So to answer the initial question of exchanging 305HP injectors with 325hp injectors, NO.
Don Wagner is offline
