Old 11-07-2009, 04:29 PM   #1 (permalink)
mcwinward's Avatar
Help with Leak!!! Attached pic.
Guys and Gals...Im no mechanic and could use some help!!!Ive developed a leak from this area(see attached pic) what is this and what does it do? Im hoping its just a loose coupling. Any insight would be greatly appreciated. Thanks in adance!!! Marc
2006 Silver Dodge Ram SLT 5.9CTD, AFE Stage 2, MBRP 4" exhaust, Edge Juice w/attitude.
2005 Jayco Eagle 30.5 BHS 5th Wheel
mcwinward is offline   Reply With Quote
Old 11-07-2009, 04:38 PM   #2 (permalink)
looks like some sort of coolant crossover tube is this line goin to the firewall to the heater core by chance? cant realy tell if its oil or coolant though
2004.5 Dodge Ram3500 2WDQCLBSRW.Edge Juice/attitude, AEM Brute Force Intake,BHAF,Straight Piped,Leveling Kit,Silencer Ring MIA,ProComp ES9000 Shocks,S&B Intake Horn,CST Lift,33x12.50 M/T ATZ USN SeaBees "We Build.We Fight" NMCB 5
04Cummin3500 is offline   Reply With Quote
The Following User Says Thank You to 04Cummin3500 For This Useful Post:
mcwinward (11-07-2009)
Old 11-07-2009, 04:53 PM   #3 (permalink)
someguy's Avatar
just tightened mine yesterday, it's a coolant line, apparently a common problem on our trucks. heard there is a replacement available from the dealer to get the ID of the hose right, why they couldn't from the factory is anyone's guess. crank em down tight and they should hold for a bit, and keep an eye it until you have the longterm fix, hope this helps...
2006 - 2500 Mega Laramie 4x4 4"T/C lift, 35's, Juice w/ Attitude, stay tuned...
someguy is offline   Reply With Quote
The Following User Says Thank You to someguy For This Useful Post:
Old 11-07-2009, 05:37 PM   #4 (permalink)
CalebZ400's Avatar
Mine leaked in the same place as well. I usually have to tighten it a little when I change the oil.
2006 3500 Megacab Laramie 4x4 G56 4.10s: Edge Juice w/ attitude-Hot, Quad X2 race, 5k 55w HIDs, F.U. switch, Rev wheels w/ 295/70/17 Nitto Terra Grapplers, Randy Ellis Designs light bar, Lightforce 240s Coming Soon: Southbend 3600DD
CalebZ400 is offline   Reply With Quote
The Following User Says Thank You to CalebZ400 For This Useful Post:
Old 11-07-2009, 08:59 PM   #5 (permalink)
There are plenty of threads on this leak. Do a search.
06 3500 Bighorn Quad 4X4 6-speed LWB DRW 5.9 w/ Edge Juice & Attitude
jay_rm is offline   Reply With Quote
Old 11-07-2009, 10:03 PM   #6 (permalink)
TEX
TEX's Avatar
if they dont know what it is or what it does............how r u going to search it? what would u type in the search bar??????????????????
2006 Mega 3500 DRW 4X4 6spd SLT Optix EGT,Boost,Trans-4510 W/Cool hose kit
2005 VW Passat TDI <----Wife's
Wake Up America
TEX is offline   Reply With Quote
Old 11-08-2009, 01:24 AM   #7 (permalink)
Check out this thread.
mcwinward That is a coolant line. That little hose is there to isolate the engine movement from that fixed line.
Check out the thread in the link below. There is an "improved" part to replace that section of hose. Cost roughly $20. The spring clamps are supposed to be an improvement over the worm gear hose clamps as they can expand and contract as the parts heat up. About half way down is a large picture of the new parts and the part numbers for them.
http://www.dieseltruckresource.com/d...ight=5179114AB
U.S.A.F. 25 yrs MSgt Retired Red, 2005, 2500 Quad-Cab, SB, 48RE, 4x4, 4.10, S&B CAI, Pml Front Diff /Amsoil 75-90, Oasis Ram's Head Rear Diff w/Amsoil, 75-140
Kokalit is offline   Reply With Quote
The Following User Says Thank You to Kokalit For This Useful Post:
mcwinward (11-08-2009)
Old 11-08-2009, 02:12 AM   #8 (permalink)
Camotanker's Avatar
This should be the line that comes from the transmission cooler - so you should have an auto. It will follow the block along the passenger side and route behind it to the driver side where the transmission exchange sits. There is a line that also connects into the heater core.
Not a big deal. You either need to tighten it or replace the clamp.
Monster Rig - (Website Click Here)
2003 CTD - REBORN
Camotanker is offline   Reply With Quote
The Following User Says Thank You to Camotanker For This Useful Post:
