Wow! Edge Ez Was The Cause Of All My Problems - Dodge Cummins Diesel Forum
post #1 of 30 (permalink) Old 10-01-2009, 06:47 PM Thread Starter
shlab2's Avatar
WELL AFTER 3 YEARS OF OWNING MY TRUCK HOURS AND HOURS OF SEARCHING POSTS HERE TRYING TO FIGURE OUT PROBLEMS WITH MY TRUCK ALL I HAD TO DO WAS UNPLUG THE DAM EDGE CHIP I FEEL KINDA DUMB BUT I NEVER FIGURED A CHIP COULD CAUSE TRANNY PROBLEMS OR FUEL PRESSURE PROBLEMS. I JUST WANTED TO SAY TO EVERYONE IF YOUR TRUCK IS ACTING UP THE FIRST THING YOU SHOULD DO IS UNPLUG YOUR CHIP! I WAS STARTING TO LOOSE FAITH IN DODGE BUT NOW I LOVE MY TRUCK AGAIN IT WASNT HER FAULT. NOW SHE RUNS GREAT AND EVEN SHIFTS PROPERLY FOR THE FIRST TIME SINCE I HAVE OWNED IT
here are the problems the chip caused
i have been shifting my truck manually for the past 3 years because it wouldent downshift into 1st gear in drive.
started running rough and low fuel pressure code came up so i capped the rail, put in a new FCA,cleaned all the grounds i could find, no help and was starting to think injectors or somthing. hope this helps someone
ps; im done with edge thinking about a smarty next
03, 4x4HD, leveled on 35's, cutout stock airbox , str8 piped, edge attitude CS, in tank fuel pump, TCS built 48re, Need a He351 or used 62
shlab2 is offline
post #2 of 30 (permalink) Old 10-01-2009, 07:03 PM
Banned
It's a dumb idea to run a pressure box as your only programmer anyway. Good luck to you.
JDiepstra is offline
post #3 of 30 (permalink) Old 10-01-2009, 07:13 PM Thread Starter
shlab2's Avatar
why do you call it a pressure box and what programer would you suggest for me i dont have tons of money thanks.
shlab2 is offline
post #4 of 30 (permalink) Old 10-01-2009, 07:19 PM
Banned
Cause the Edge EZ raises rail pressure. It wears out injector tips prematurely. Also it doesn't advance timing at all, which is the most efficient way to add power and gain mpg's. Honestly I know you don't like Edge at the moment but if I were you I would get a used Edge Juice w Attitude out of the classifides. You could sell your EZ which would cover about 1/2 the cost of the Juice. With the Juice you can adjust power on the fly, set safety backdowns, and have a whole bunch of gauges all in one unit.
The Following User Says Thank You to JDiepstra For This Useful Post:
maumen456 (02-08-2015)
post #5 of 30 (permalink) Old 10-01-2009, 07:24 PM Thread Starter
shlab2's Avatar
opps guess i could have given you an idea of my truck use.
its my daily driver to work, i barely ever tow becides my camping trailer 3 times a year but its under 5k, i love to spank other trucks and mustangs in the evenings. i also take it to the local 1/8 mile track twice a year it ran a 9.8 at 5000 feet. basically im looking for somthing similar in power to the edge ez maby a little more. ok foresure more. thanks
shlab2 is offline
post #6 of 30 (permalink) Old 10-01-2009, 07:51 PM
Bob Wagner's Avatar
talk to harry at peak diesel in Langley
Smarty Know it all.
Bob Wagner is offline
post #7 of 30 (permalink) Old 10-01-2009, 11:46 PM
BDGibson4's Avatar
Location: Punxsutawney or Pittsburgh, Pa depending on the part of the week
For the Smarty guru
On the other hand though, the Juice/Attitude is a nice plug and play unit man. My buddy has one in his 05. Doesn't pull anything like my Crazy Larry/EZ stack but its a lot nicer than stock. I would check it out for what you say your looking for!
2012 2500 Mega Cab Laramie Limited will all the factory fixins
I'd rather have my straight six, than your BENT eight.
BDGibson4 is offline
post #8 of 30 (permalink) Old 10-01-2009, 11:53 PM
BILLS06's Avatar
Done with Edge here also. 2 Juice modules and 1 EZ.
06 QCSB SLT
Headlight Eyelids Fluidampr EZ Down ATS Converter Fog Lamps Aero Turbine Muffler Reflex Bed Liner
[SIGPIC][/SIGPIC]
BILLS06 is offline
post #9 of 30 (permalink) Old 10-02-2009, 12:02 AM
what else should he have been running?
2006 2500 5.9 Quad Cab | ATS Tranny | CAI | Pusher Intake Horn | FASS Fuel Pump | Straight Pipe |
eHaze is offline
post #10 of 30 (permalink) Old 10-02-2009, 12:05 AM
Banned
Something that adds timing and duration. Think of a pressure box as a supplement to an already modded truck.
post #11 of 30 (permalink) Old 10-02-2009, 12:42 AM
Like the Smarty/MP-8 stack?
Truck is gone. New vehicle; 2006 300C 5.7 Hemi Cool Vanilla
Moparman is offline
post #12 of 30 (permalink) Old 10-02-2009, 08:29 AM
chizwizdiz's Avatar
Yes.
That is just one of the many popular combinations.
You just need one from each column. Some trucks respond differently to the "stack", so some people try different combinations. Don't forget about the supporting mod's!
Tuner: Pressure Box:
Smarty Power Puck
Edge J/A MP-8
Bully Dog TD Edge
PPE DR Performance
OIF-1 Veteran. Proud former 101st Air Assault Soldier
03-04
06
07-08
06 Mega
chizwizdiz is offline
The Following User Says Thank You to chizwizdiz For This Useful Post:
Moparman (10-03-2009)
