Old 03-29-2007, 03:02 AM   #13 (permalink)
WFO diesel
cummins600isbe's Avatar
turns out it was the CP3, now im runnin a stage 2 from John at Floor-It. Couldnt ask for anything more from him, did an out standing job on walking me through install and removal.
2008 F-350 6.4L King Ranch 4X4,SPARTAN TUNED.
2004.5 Cummins, 2500, 4X4, Full billet, FASS, TST, SMARTY, Flux sticks, cam, Di-Procol (Boost, Boost, EGT, Trans, Rail, Fuel, EOT, ECT), AFE, 5" pipe, and more (893 on fuel )
cummins600isbe is offline   Reply With Quote
Old 03-29-2007, 07:07 AM   #14 (permalink)
Tech Specialist
cool glad you got it fixed up
2004 305/555 6sp.DIY cruise control, 373's, bd short shift,homemade boost elbow,autometer boost and egt, isspro fuel press.,zenon flares,quad race box or sp diesel stage 1 stacked with diablosport predator, modded tone ring,bd pusher pump(and yes the truck still runs if the oem pump dies)afe intake and tt,sp diesel overboost eliminator,DIY modded cp3,
rich2500 is offline   Reply With Quote
Old 07-09-2007, 07:54 PM   #15 (permalink)
synister's Avatar
i have a 2006 cummins, i had a injector go bad, i sent the injectors, and injector pump out to be tested and modified.
now i have stage 3 injectors a stage 1 cp3 pump and a new knock!!!
my knock sounds and acts just like the one described here. mine knocks under very light throttle/load and i hear a slight metallic rattle which i was told was common on '06 common rail engines because of the Y on the valve train. i have adjusted the valves 3 times and made them a little tighter on the the last adjustment, still no change!
the trucks runs very well, fuel economy is 17 to 18 in traffic and 21 on the highway at 80mph it is a mega cab dually at that!
the power is very good, i roll into it once it shifts into second and can hear the rear tires spin!
i have other mods, but my concern was when the injector went bad i had dump a lot of diesel in the engine oil, though i did not run it hard at this time and the knock was not there until after i but the truck back together with the moded injectors and cp3.
no hard starts, no oil loss, my conclusion was the cp3 due to the stage 1 mod?
any thoughts???
synister is offline   Reply With Quote
Old 07-13-2007, 04:22 PM   #16 (permalink)
go back and read the cp3 timing thread.
06 48RE megacab, not cummings equipped but Cummins powered. Edge Juice/Attitude, mod'd intank fuel pump, Fleetguard FS20000 fuel filter and external lift pump regulator, modified intake housing, Goerend tranny/billet input, GDP intake horn.
mthisguy is offline   Reply With Quote
Old 07-13-2007, 05:09 PM   #17 (permalink)
synister's Avatar
can you send a link to that thread?
Old 07-13-2007, 08:51 PM   #18 (permalink)
LynchMob's Avatar
mine has probs with hard starts at time too... most of the time its when it has only run for 10-20 mins then shut it off to get food in the store come back out to start it and truns over for a good while then i stop and try it agian then it starts ....also have notice more of a knocking noise but truck really seems to run fine gets great fuel milage so. maybe im wrong and im not getting the clutch pedal in the exact spot and the motor sounds normal im not sure. but i hate to take it to the dealer b/c they take so long ...and half the time they arent sure of what needs fixed and have to change something 5 times
maybe im just crazy what do you guys think
Mike
LynchMob
06 Reg. Cab, Bright white,tinted ,3500 6 speed pyro/boost gauges, K&N intake tube with Amsoil filter, Edge EZ, MBRP 5 inch turbo back, rhino liner .
LynchMob is offline   Reply With Quote
Old 07-13-2007, 08:53 PM   #19 (permalink)
LynchMob's Avatar
oh and it never does the hard starts in the moring its normally in the after noon when its warmer out so who knows
LynchMob
Old 07-13-2007, 08:55 PM   #20 (permalink)
synister's Avatar
my 06 starts fine everytime. it just gets noise after warming up and the longer it runs, sounds sick but great fuel economy and if i hammer it it runs hard and the noise seems to fade out.
Old 07-14-2007, 01:11 AM   #21 (permalink)
CP3 timing and results
here it is.
Old 08-26-2007, 10:38 PM   #22 (permalink)
synister's Avatar
buddy, i have the same type of knock, i think it is your CP3.
i have a '06 cummins with:
stage 3 injectors
stage 1 CP3
snow stage 3
and other typical bolt ons
my truck did not start making this noise until i had the pump modified and it only does it when it is above 80 degrees or hotter, if it is cooler out then i noticed it is quite.
i do also adjusted the valves about 3 times. hope this helps you
Old 08-26-2007, 11:32 PM   #23 (permalink)
My 06 with 95k started to knock like a injecter but i was told it was my flywheel. Dont know if thats the problem yet but it gets torn down thursday
gsxr1k2 is offline   Reply With Quote
Old 08-26-2007, 11:35 PM   #24 (permalink)
synister's Avatar
the flywheel? hmm you have a 6 speed? this knock i have only happens when it is hot out and my truck is a automatic.
