| 3rd Gen. Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
06 Cummins
![]() Join Date: Feb 2009
there are over 2,000 on backorder from cummins and the dealer also. There is the plastic blue holder that bolts to your motor and after a while of the engine rattling things around it will loosen this plastic blue holder and make a pin hole in your injector line # 4 and you will have diesel spray all over your motor and smell of diesel fuel inside your trucks for weeks. I was driving my truck home one night and smelled diesel fumes. I pulled over and my whole entire motor is covered in diesel and dripping all over the ground. So guys check your injector #4 first, I believe the plastic blue holder nut is a 6mm to 8mm. Just make sure its tightened. Alot of people been having this same problem and like to warn everybody I can about this problem. Hope this help you guys out.
2006 White, quad cab, auto, slt, TRX4, Smarty S-06 POD, edge juice w/attitude, AIRDOG 150, S&B cold air intake, Silencer Ring MIA, solid steel adj. track bar, upgraded tie-rod kit, bd steering box brace, 6in Mitre Cut Stacks, Transmission built by FLOOR IT DIESEL!!!! 2001 Grey, quad cab, auto |
| The Following 23 Users Say Thank You to mfoster48612 For This Useful Post: | 40chevy (09-28-2009), AMixon (09-27-2009), cmns2500 (09-18-2009), Cummins Cruiser (09-29-2009), custom_c10 (09-16-2009), dodgefarmer2 (09-20-2009), ethan ott (10-10-2009), garystillwell (10-16-2009), greatwhitehope (11-17-2009), Indedave (11-11-2009), JimmyC83 (11-08-2009), lalanscaper0485 (09-16-2009), Magic smoke (10-18-2009), Mopar99360 (09-21-2009), pistazie2500 (09-30-2009), Shagginwagon (09-16-2009), shesacummin (10-20-2009), SmokinTheHippies (09-28-2009), sooter (09-22-2009), tripps1175 (09-16-2009), UNDER-PRESSURE (11-14-2009), underramarmor (09-16-2009), VanillaGorilla (11-16-2009) |
#2 (permalink) |
Super Administrator
![]() Join Date: Jan 2006
Thanks for the heads up.
![]() 03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph) July 2009 Cummins Forum ROTM Winner 95 1500 Sport 2wd Cummins Drag Truck under construction. "In search of the Magic Dyno"
#3 (permalink) |
![]() Join Date: Apr 2007
i check mine every time im under the hood since ive heard about this. good thread!!
06 flame red 2500 thunder road sport sbqc 48re, 4x4, 4.5" lift, 35" toyo mts on black xd hoss', bd steering box stabilizer, fox 2.0 dual stabilizers and shocks, afe stage 2 pro dry, fbd 5" tbe with 7" tip, edge juice w/attitude, debadged , door strips mia, custom night runner head lights, recon smoked cab lights, smoked fogs, custom wood grain delete... |
#4 (permalink) |
just went out and checked all mine. Was able to turn the nut pretty easy with a small 8mm wrench. My question is how tight should they be. Tighten until you cant go any more or just until you have to put slight pressure. Also what happens if it does break does the dealership give you something to drive or are you just without a vehicle indefinitly. Are they giving a time frame for getting part
2006 3500 megacab 4x4 5.9 auto 48re 3:73 gears no upgrades |
#5 (permalink) |
06 Cummins
I was actually lucky and one buddy had one but i had to drive almost 2 hours one way to get. well worth it. National backorder from cummins. The 8mm should be tight. All that happends is the holder becomes loose and wears a pin hole in the injector line and high psi of fuel running through it. So imagine cutting a hole in a garden hose and having the water on. It sprays everywhere. just imagine diesel fuel over everything. it sucks, trust me. there is no time frame on the parts. They'll tell you guys you are basically sol if you dont have a warranty for sure and the 8mm should be tight so it doesn't rattle back loose again. If i can find my old line i will take some pictures of where it is discolored from where the holder had rubbed on it enough to make a leak.
2006 White, quad cab, auto, slt, TRX4, Smarty S-06 POD, edge juice w/attitude, AIRDOG 150, S&B cold air intake, Silencer Ring MIA, solid steel adj. track bar, upgraded tie-rod kit, bd steering box brace, 6in Mitre Cut Stacks, Transmission built by FLOOR IT DIESEL!!!! 2001 Grey, quad cab, auto Last edited by mfoster48612 : 09-16-2009 at 10:01 AM. Reason: add |
#6 (permalink) |
Just replaced mine last week. You are 100% right about smelling like diesel for weeks. Mine still stinks and i've washed the engine and undercarriage. I kept the old fuel line and i'm going to have it brazed. The dealer said I got the last one and they have no idea of when the parts will be coming. Jay
2004 1/2 Dodge Quad Cab 3/4 T 4x4, triple pillar mount w/ auto meter gauges, PSM, aFe pro guard 7, Edge Juice, Weston steps, Snug top shell, carpeted bed, Magnaflow muffler, Chrome grill guard, 2 in. front lift, Bilstein shocks and Sirius radio. |
#7 (permalink) |
Where is #4 and can you see it without taking anything apart?
2005 2500 slt, H.D. 4x4, L.B. auto-48 re, Auto Meter tri pillar gauge stack, EGT probe is pre turbo b/t #5,6, Air Raid filter box(ez fit) with modified air box tube, Edge Cr Ez, no juice, Pusher intake horn, train horns, Side marker lights, Lo Jack w/ early warning. |
#8 (permalink) |
Thanks for the info.....i was hearing some noise that sounded like air leaking.. what it really was, was the blue insulation around the injectors that was vibrating everytime the injector went off... i tighten the #8 bolt... and now no more noise(and hopefully no busted line)
2005 Black Ram 2500 Auto, Edge Juice w/Att, Intake Manifold Horn, K&N Drop in, silencer ring MIA,Toyo Open Country A/T, Autostart Alarm, Blue Gauge Cluster, Hid solutions 6000k Hid Kit |
#9 (permalink) |
just open the hood and it is the fourth injector line from the front and it is not from rubbing a hole in the line it causes the line to crack and you can not believe how much fuel the cp3 can pump in a very short time. the new cummins ones are made from different metal this may stop the problem the new ones have a whiter color metal and have a torx screw instead of the 8mm head bolt for the isolator
063500dually4X4qcg56,dynatrac,bd exhaust brake,donaldson m090535muffler,cfm+,winspeed spacer,smartyjr,taylor wings,luberfiner bypass filter,psm cold air,cool hose,tag,air tab's,pdr cam,ddp50hp injectors,htt 62 65 13ss,ss manifold, turbo and manifold blankets |
#10 (permalink) | |
#12 (permalink) |
last year i lost # 4 also, the blue clamp came off. It didnt wear a hole though, it let the line VIBRATE too much. The line split at the little neck or ridge in it where it goes into the inj. ri\ght at the nut.
09 QC 4X2 BIGHORN DRW G56 3:73 INFERNO RED Timberens B&W GN Dipricol Optix ga.(boost,fuel pr. EGT) , CAT 2 mic remote F/F Smarty17S, stock exhaust in tact. |
