Old 10-28-2009, 09:41 AM   #97 (permalink)
dieselwill's Avatar
I have been working on diesels for twenty years and have seen this on all kinds if the lines are not secured. When I replaced mine about a month ago, the Lithia Dodge Dealer wanted $76, Dodge MSRP is $53, I went to Cummins and got it for $21. The line that I got was an upgrade with a rivet instead of a bolt on the support.
2006 3500 Mega 4X4 Laramie 2001 2500 Quad 4X4 Laramie
1985 GMC K3500 4X4 Cummins 5spd Gear Vendors 35s. I Built this in 1996.HOOKED ON CUMMINS
NOTHING STOCK
dieselwill is offline   Reply With Quote
Old 10-29-2009, 08:36 PM   #98 (permalink)
fydraca2896's Avatar
Angry
I just had all new u joints and new carrier bearing replaced. Before the carrier bearing was replaced (broke almost completely off the mount) the vibration was really bad. I really thought that all of thus originally stemmed from the injector that I thought was misfiring. Well since i tightend all of them up 3,4,5,6 were all lose I know it is not the injector. I am really at a loss. I really can not afford to spend any more money this year just to diagnose a problem. Is there another thread that you guys know of dealing with these issues.
fydraca2896 is offline   Reply With Quote
Old 10-29-2009, 08:46 PM   #99 (permalink)
[quote]Guys, I have the replacement #4 line... do you recommend using a diesel comptaible thread sealant on both ends of the new #4 injector fuel line[quote]
I know when I was taught (years ago) everything got thread sealant. Especially the stainless stell and the aluminum components. The torque, heat and pressures on the systems would cause the threads to lock together causing them to bind up. Without the thread sealant you would never get the parts to come apart without breaking equipment. Even dry fitting to check installation was considered a "dont do".
Old 11-05-2009, 03:16 PM   #100 (permalink)
Just checked mine and all were tight, but then I just bought this from a dealer who may have had it tightend.
Thanks for this thread and this web site!
SF-
2006, 2500 Mega Cab, Laramie, 4x4 with 6" lift and 37x13.5 Toyo Open country and stock 5.9 for now.
2005 Hayabusa with slight modifications, nuff said there.
SF-
Silver Fox is offline   Reply With Quote
Old 11-07-2009, 12:38 AM   #101 (permalink)
quitstrokinstartcummin's Avatar
definitely going to check mine. Thanks guys.
05 3500 quad cab 2wd, auto. High flow 4"mbrp turbo back exhaust, baffle removed stock intake tube, cat deleted. STOCK 5.9 HO 600 series, no programmer......yet. 265/70/17 mud terrain sxt (little more bite for my 2wd) 2 1/2" daystar coil spring spacers.
quitstrokinstartcummin is offline   Reply With Quote
Old 11-07-2009, 11:06 PM   #102 (permalink)
BR1
just tightened up mine........3 were loose, #4 was teh worst.
2003 2500HD, 4x4, 6 speed H.O., quad cab, long box. H2's, 315 cooper discoverer atr's, century royale cap, mopar winterfront, herculiner bed, billet grille, magnaflow stainless muffler, putco boss bars.
BR1 is offline   Reply With Quote
Old 11-11-2009, 10:43 AM   #103 (permalink)
great info...will check later today
hogrider09 is offline   Reply With Quote
Old 11-11-2009, 02:02 PM   #104 (permalink)
Mopard's Avatar
I also had the #4 fuel line fail at around 43K miles and spray diesel all over. Pulled in the driveway and even before I got out I could smell fuel. Shut the truck off and popped the hood and fuel was everywhere. Tried to restart the truck to get a quick look for the leak but the truck would not start again.
The new blue plastic clamp on my new #4 fuel line also has a torx head on the bolt.
Question ... How the heck would one ever get at the #6 fuel line tucked way back there? Is it accessible after you remove the chain lift loop/bracket?
06 Inferno Red - Med. Slate Grey Leather / 2500 HD 4x4 RC/LB / Laramie-H pkg / 3.73 anti-spin diff / 325/610 CTD HO/ 48RE Auto / Mopar molded splash guards / Mopar vent visors / Mopar side-steps / 8-1/2' Curtis / 2" Levelling Kit (CCM Offroad) / Bilstein 5100s all 4 corners / Weathertech floor liners / Took delivery Dec 30/05.
Mopard is offline   Reply With Quote
Old 11-11-2009, 02:11 PM   #105 (permalink)
TECH SPECIALIST
JWH_03_Dodge's Avatar
you can get to it, its just not as nice as the rest
John - 03 QC/LB 4x4 5sp
Visit the Hoosier Truck Club
FTE Diesel FASS giveaway Click here!!!
Originally Posted by Broke Down View Post
come on Steve....my nuts hurt and i am stuck on the couch
JWH_03_Dodge is offline   Reply With Quote
Old 11-11-2009, 02:14 PM   #106 (permalink)
Sandaholic's Avatar
I checked mine a few weeks ago they were all tight. Some on my buddies '06 were loose.
Off Topic: where are you at in Oregon? Check in here if you haven't already
Oregon - Dodge Cummins Diesel Forum
05' QCLB 4x4 NV5600,Spec DD clutch,S-06,5" TBE 6" aussie, airdog 150,modded fuel can.,CAI, techni-cooler,mag hytec rear diff. cover,6" lift on truck and fifthwheel,firestone airbags,16gal. of 200 PSI OBA 421HP/1009TQ moves 8000lbs to a 13.88@97.05 SSW
Sandaholic is offline   Reply With Quote
Old 11-14-2009, 01:41 PM   #107 (permalink)
scj
I found out about this problem the hard way unfortunately.
My truck is at the dealer and they replaced the 4th injector line but cannot get the truck to restart.
The truck died about a mile after the engine light came on. I cranked it over to find out where the fuel was coming from then called the tow truck. It's under warranty so I let them have at it. The dealer called me and said they have been trying to restart it for over an hour with no luck.
Anyone have any tips for getting it to restart? Could there be another issue since I drove it until it died?
scj is offline   Reply With Quote
Old 11-15-2009, 01:15 AM   #108 (permalink)
cummins67L's Avatar
No you did not hurt the engine by driving it with the injector line leaking. BUT you could have caught your truck on fire!!
Sounds like the fuel may have gotten into the wiring connectors.
If they worked on it for one hour and then called you,
Better get a new dealer ,,,
cummins67L is offline   Reply With Quote
